what did you do to your 914 today |
euro911 |
May 9 2015, 06:03 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,859 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
Morning drive with my granddaughter... Cool. What type of mount are you using? My first GoPro session had too much wind turbulence and isn't much fun to watch (IMG:style_emoticons/default/dry.gif) https://www.youtube.com/watch?v=tZeeZZOLEMY (IMG:style_emoticons/default/driving.gif) Also, are you using the completely closed camera housing? (not hearing any wind noise). Lastly, curious if you were you invited to park your LE on the grass? (IMG:style_emoticons/default/poke.gif) |
poorsche914 |
May 9 2015, 06:11 PM
T4 Supercharged Group: Members Posts: 3,122 Joined: 28-May 09 From: Smoky Mountains Member No.: 10,419 Region Association: South East States |
Cool. What type of mount are you using? My first GoPro session had too much wind turbulence and isn't much fun to watch (IMG:style_emoticons/default/dry.gif) Also, are you using the completely closed camera housing? (not hearing any wind noise). Lastly, curious if you were you invited to park your LE on the grass? (IMG:style_emoticons/default/poke.gif) Using the suction mount with camera inside closed housing. Wind noise was present but not too bad. I masked it somewhat with the music track. As far as parking on the grass... I didn't need an invite (IMG:style_emoticons/default/happy11.gif) (IMG:style_emoticons/default/driving.gif) |
sixnotfour |
May 9 2015, 07:10 PM
914 Wizard Group: Members Posts: 10,661 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Mud Bath...Evidently in Utah 1 inch of rain does things to your soil...1200lbs in the back of the truck didn't help much.. (IMG:style_emoticons/default/beerchug.gif)
Steve |
May 9 2015, 09:07 PM
914 Guru Group: Members Posts: 5,763 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
Installed the heat exchangers and Triad muffler. Tried to start it up no go.. I think my fuel pump is fried. Removed rear pressure hose and whether the pump is on or not, I get the same flow to the gas can. (IMG:style_emoticons/default/confused24.gif) Ordered another fuel pump. Otherwise i am getting spark to the spark plugs. (IMG:style_emoticons/default/piratenanner.gif) |
Cuda911 |
May 9 2015, 09:13 PM
Senior Member Group: Members Posts: 1,489 Joined: 20-May 14 From: Oceanside (N. San Diego County), CA Member No.: 17,376 Region Association: Southern California |
All sorts of fun stuff.
To avoid double posts, here's the link: http://www.914world.com/bbs2/index.php?sho...7472&st=160 |
steuspeed |
May 9 2015, 09:15 PM
Senior Member Group: Members Posts: 1,008 Joined: 12-July 11 From: Portland, Oregon Member No.: 13,308 Region Association: Pacific Northwest |
Found some steel ramps at a garage sale down the street (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/driving.gif) I have some of those. A little exciting backing the teener up on those. Afraid I will go too far (IMG:style_emoticons/default/ohmy.gif) |
Hank914 |
May 9 2015, 09:52 PM
Member Group: Members Posts: 389 Joined: 7-April 14 From: CA and OR Member No.: 17,215 Region Association: None |
Today, I glued up my gear shift knob. Even though cheapie after markets are around $20, my top of knob was nice and clear, so I spent six bucks on some superglue instead. Of course, it broke again, but I had some glue left over.
And since I am a more of a functional kinda guy, rather than an esthetic person, I figured a little bit of glue is good, but a whole lotta glue is better, so I gooped it good. If it breaks again, I'm off to the pelican for a cheapie replacement. And now, I get to do what I bought this thing for: (IMG:style_emoticons/default/driving.gif) |
forrestkhaag |
May 10 2015, 09:08 AM
This week I installed a set of Koni's and Weltmeister springs, powdercoated tin on my new 2.2 mill, added new decals to the Blue Coil, then I plucked the old engine/tranny out of the car, separated the two, dismounted the clutch assembly and bearing etc. removed the exhaust for reuse then crated the engine for shipment far far away from my tiny garage in Laguna.
Today is prep the engine bay for direct-to-metal epoxy primer and topcoat the bay then detail the engine compartment wiring and install the front half of the side shift conversion. tomorrow will be new hard gas lines front to back and sell the 25pound fire extinguisher in favor of a smaller on-board unit..... It has been three days since the car went up on jack stands for the engine swap so I need to get busy around here or lose another week of no-fun-driving my tow vehicle in the place of my Go-vehicle............ Attached image(s) |
shawaii |
May 10 2015, 11:43 PM
Newbie Group: Members Posts: 12 Joined: 6-May 15 From: Hawaii Member No.: 18,711 Region Association: Hawaii |
Finally fixed the tail lights. P.O. Had swapped the neutral for reverse in the left rear housing, which kept the lights on (melting the plastic reflector) so he cut the reverse power wire at the brake pedal. Took me hours studying the wiring diagram and checking every connection to figure this out.
Thought brake lights were not working when all was done, but wife was pushing the clutch pedal instead...crisis averted and I'll cut her slack on Mother's Day. Still trying to find stock tires in Honolulu... |
DRPHIL914 |
May 11 2015, 07:13 AM
Dr. Phil Group: Members Posts: 5,810 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
drove for the first time in over a month since i sold my 14''fuchs, . i will be dropping it off at Bob Woodman's shop for some new performance tires on my new 16'' fuchs!! . Went with Bridgestone 205/55- 16. same tires he runs on his 75 911 track car. i will post pictures when i get the car back. Dr. Phil |
thieuster |
May 11 2015, 03:31 PM
Member Group: Members Posts: 447 Joined: 31-January 15 From: 275 mls NW from Stuttgart. Member No.: 18,384 Region Association: Europe |
Some spray paint: I've blasted and painted the heater blower's housing. And I've tried to clean the hell hole. There's no rust, or worse. It's only a mess with sand, small pebbles trapped in the corner.
Menno |
DRPHIL914 |
May 11 2015, 09:10 PM
Finally have my new tires on the fuchs!
Attached thumbnail(s) |
DRPHIL914 |
May 11 2015, 09:14 PM
These are 205/55 16 on 6" wide 16j's. I have a 1/2 spacer on there and still have room. Bridgestone potenza RE-11.
Now I need my speedometer really calibrated. It's slow by 5 mph. That's what I did today!! Attached thumbnail(s) |
DRPHIL914 |
May 11 2015, 09:23 PM
One last angle. This profile should keep curb rash romantic happening
euro911 |
May 11 2015, 11:23 PM
Lookin' good Phil (IMG:style_emoticons/default/thumb3d.gif)
Received the front LED turn signal kits from Jerry. Gonna install them in the 'BB' temporarily, they'll eventually find a permanent home in the '71 ('Howie'). |
thieuster |
May 11 2015, 11:29 PM
These are 205/55 16 on 6" wide 16j's. I have a 1/2 spacer on there and still have room. Bridgestone potenza RE-11. Now I need my speedometer really calibrated. It's slow by 5 mph. That's what I did today!! These are great types. My wife's previous BMW had them. Far better than the current Michelins she has now on her car. When it's time to replace them, it's going to be Bridgestone again. Menno |
Stapler |
May 12 2015, 12:24 AM
Newbie Group: Members Posts: 11 Joined: 25-November 08 From: NV Member No.: 9,787 Region Association: None |
Andyrew |
May 12 2015, 09:11 AM
Spooling.... Please wait Group: Members Posts: 13,377 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
New toy (IMG:style_emoticons/default/smile.gif)
forrestkhaag |
May 12 2015, 09:33 AM
zambezi |
May 12 2015, 10:13 AM
Senior Member Group: Members Posts: 711 Joined: 14-April 08 From: Lafayette, LA Member No.: 8,920 Region Association: South East States |
Cool toy. The size of the embossing looks about the same as my original key fobs. |
Lo-Fi Version | Time is now: 18th December 2024 - 09:50 PM |
