862 Pages V « < 300 301 302 303 304 > »
SKL1
post May 24 2015, 06:38 PM
Post #6021
Nothing, too busy watching Monaco F1 and Indy!!
Larmo63
post May 24 2015, 06:39 PM
Post #6022
i'm weird…..
(IMG:http://www.914world.com/bbs2/uploads_offsite/i983.photobucket.com-17068-1432514360.1.jpg)
Cuda911
post May 24 2015, 07:28 PM
Post #6023
^^^^ So, I spend my hard-earned cash to finally buy some "proper" mirrors due to all the bitching, and now this????
Yesterday I was in a bicycle shop and saw some bicycle mirrors that I think may work well.
infraredcalvin
post May 26 2015, 10:51 PM
Post #6024
Distracted Member
Moved into position... Was thinking about cutting the cage out of the Olympic Blue and install in the Diamond Silver... Now considering repairing the OB tub for the race car and hot rodding the DS for street. Hmmmm... Too many projects, not enough time or $$$.
forrestkhaag
post May 27 2015, 09:29 AM
Post #6025
I finished the placement of my thru-hood tank cap assembly by fine-tuning the alignment of the tank shims and then installed three-way 911-sounding air horns that actuall can be heard (just before one is squashed like a bug on the freeway......) two on the driver side and one trumpet on the passenger side.....
Bossman
post May 27 2015, 09:03 PM
Post #6026
QUOTE(forrestkhaag @ May 27 2015, 08:29 AM) *
You going to add fancy trunk latches next?
Larmo63
post May 27 2015, 09:12 PM
Post #6027
Looks familiar.
Blue6
post May 27 2015, 11:32 PM
Post #6028
Forrest, that thru-hood tank cap looks great. Was that your idea and design? (IMG:style_emoticons/default/biggrin.gif)
euro911
post May 28 2015, 01:26 AM
Post #6029
Someone told me it had something to do with monkeys, whatever that means (IMG:style_emoticons/default/confused24.gif)
(IMG:style_emoticons/default/poke.gif)
bulitt
post May 28 2015, 04:32 AM
Post #6030
Achtzylinder
If the air horns are ineffective possibly a recumbent bike flag would help also?
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.pigasusgrove.net-13632-1432809144.1.jpg)
(IMG:style_emoticons/default/lol-2.gif)
whatever works....
post May 28 2015, 07:45 AM
Post #6031
QUOTE(Blue6 @ May 27 2015, 10:32 PM) *
Yes Dave, it was Forest's design. You see Larmo was concerned about the dirt that accumulates beneath the tank so he asked our resident Welder , Forest, if he could design something to keep this area clean. It was then that Forest realized if he cut a big old hole in his hood the rain would run into, thru and beneath the tank (and a few related areas) thereby cleansing the area of concern. I hope this helped. (IMG:style_emoticons/default/beerchug.gif)
Porschef
post May 29 2015, 09:01 PM
Post #6032
How you doin'
Finished the last step in the oil cooler install by hooking up the hose from the NACA duct to the plenum I made for the cooler. Looking forward to giving it a decent run tomorrow, and putting it in a little traffic to see temps.
iamchappy
post May 29 2015, 09:15 PM
Post #6033
It all happens so fast!
Put on a new air filter....
914itis
post May 29 2015, 09:24 PM
Post #6034
Joe of you are not bz , maybe we can meet half way and grab lumch tomorrow.
Pm me .
thieuster
post May 30 2015, 09:48 AM
Post #6035
Region Association: Europe
I took all the interior parts out this morning. That wasn't too difficult! I had the intention to remove 43 yrs of previous ownership from the carpets and seats!
I went to my local hardware store and found there a few industrial cleaning products for carpets and upholstery. And they did the job; they worked perfectly on my Teener's interior. The seats look like new, the carpets have changed from a brownish color into the original grey/black color. Sadly, the carpet piece that sits in front of the pedals has a hole in it. Oh well, not everything looks like new after so many years...
I've sanded the seat postitioning handles and put a new coat of shiny black paint on them. Tomorrow a second and third coat and they will look like new!
Menno
DRPHIL914
post May 30 2015, 08:20 PM
Post #6036
Dr. Phil
Went for a drive this evening. No more bad star issues since replacing the cap and rotor. Thought I had a bad set of f.i. trigger points. Any way car is running great except idle is a bit low , especially when hot after running for a while. And I don't seem to be able to effect the idle with ecumenical adjustment so I probably have to check the tips setting? I set it according to Rich's picture and I can say since putting this new tps in front Bruce Stone my acceleration has been perfectly smooth with no bucking .. so back to recheck in and fine tuning.
Mike Bellis
post May 30 2015, 08:55 PM
Post #6037
Resident Electrician
I ripped out my radiator... (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/welder.gif) (IMG:style_emoticons/default/headbang.gif)
Porschef
post May 31 2015, 08:11 AM
Post #6038
How you doin'
Installed the right side engine tin I picked up from Garold at Hershey. (IMG:style_emoticons/default/smile.gif) Had to run a tap thru the heat exchanger, I guess it had been a while since any screw was in there. It's a 6mm x 1.0 thread.
So now that after all this work is done, and the car's running very well, I'm thinking it's near time to do a valve adjustment.
The circle continues... (IMG:style_emoticons/default/rolleyes.gif)
Harpo
post May 31 2015, 08:59 AM
Post #6039
I got my rebuilt 3.0 brembo calipers back from PMB and my lowered struts back from Tangerine.
Harpo
post May 31 2015, 09:08 AM
Post #6040
QUOTE(19732.0 @ May 17 2015, 06:22 PM) *
Finally got around to putting on my new rear brakes from PMB, by which I mean: I finally got the damn retaining screws out of the old rotors.
If you use stainless steel instead of the zinc screws you will never have trouble removing them. Where are you located in Detroit?
DAvid
- Lo-Fi Version Time is now: 18th December 2024 - 03:48 PM
