862 Pages V « < 320 321 322 323 324 > »
Phoenix914
post Aug 11 2015, 06:40 AM
Post #6421
Last night I vacuumed all the loose crud from the engine bay and removed the rear and side (original) seals. The front engine bay seal is still intact, but I should probably replace it too while the engine is out.
The next step is to clean decades of grime from the engine bay and figure out what to do with a little rust damage on the battery tray and hell hole. The lower fuel pump mount hole rusted out, but the upper one is fine. Otherwise, there is some surface scaling but no apparent structural damage.
Cairo94507
post Aug 11 2015, 06:45 AM
Post #6422
Michael
MJHanna - Nice. Are you planning to add the black plastic shields over the metal tabs that hold the wiring harness in place so the metal does not damage the wire?
MJHanna
post Aug 11 2015, 07:28 AM
Post #6423
Does this 911 make my butt look big?
QUOTE(Cairo94507 @ Aug 11 2015, 07:45 AM) *
Yes if you look to the right side to the coils thats new wiring, the wiring to the left of center was done by the PO.
Olympic 914
post Aug 11 2015, 05:08 PM
Post #6424
Took my doors off to sand and paint the area. thinking of having the doors soda blasted along with the trunk lids.
Just moving along..
we need a sanding emoticon...
post Aug 11 2015, 05:35 PM
Post #6425
Resident German
Got my battery charger today so she might be running again this weekend!
(IMG:style_emoticons/default/cheer.gif)
Cuda911
post Aug 12 2015, 12:42 AM
Post #6426
Fixed the rear view mirror (found that the screw had come loose). Then drove down the coast to Cardiff, had dinner at a restaurant, and drove home.
post Aug 12 2015, 11:23 AM
Post #6427
Resident German
(IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/cheer.gif)
Larmo63
post Aug 12 2015, 11:32 PM
Post #6428
I ordered a book on building 911 engines from Amazon.
I'm going to try to understand a bit more about the mysterious 911 Porsche motor and make an attempt at re-building mine. (IMG:style_emoticons/default/idea.gif)
euro911
post Aug 13 2015, 01:38 AM
Post #6429
What book did you order, Goob?
Maltese Falcon
post Aug 13 2015, 02:03 AM
Post #6430
Fabb'd up some receiving plates for the aero - latch assemblys Attached Image
Maltese Falcon
post Aug 13 2015, 02:09 AM
Post #6431
....another at the other side, 4 hold downs in total for the trunk lidAttached Image
Maltese Falcon
post Aug 13 2015, 02:16 AM
Post #6432
Test fit of the SafeCraft Racing cage netAttached Image
post Aug 13 2015, 11:07 AM
Post #6433
Resident German
(IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/aktion035.gif)
forrestkhaag
post Aug 13 2015, 06:32 PM
Post #6434
I located the timing mark on the fan on the backside and marked it on the easy-read-side with my lovely wife's fingernail polish.. she is outa town in Seattle with our Daughter and first Grandson born last night at 1:37... the marks are good and I am already planning his first ridealong.... Not sure if I picked the right color however....
I went with red...
carr914
post Aug 13 2015, 07:33 PM
Post #6435
Racer from Birth
QUOTE(carr914 @ Aug 9 2015, 07:11 PM) *
Got the 2.8 Twin-Plug ready for Dyno-Time!
Thinking about this - Opinions?
Michael N
post Aug 13 2015, 11:15 PM
Post #6436
Certifiable
Packed both trucks with gear and went camping in Monterey. Nolan met the Gas Monkey guys while we we there today. He was stoked.
matthepcat
post Aug 14 2015, 12:22 AM
Post #6437
Meat Popsicle
Cool Mike! Where?
euro911
post Aug 14 2015, 04:42 AM
Post #6438
Thursday night, I pulled the barrels off of my wife's 1.7L motor. Marked them and stuck them in the hot tank. They actually looked pretty good, could still see cross-hatch marks in them ... then de-greased the 3~4 side of the case.
Hoping to clean up the 1/2 side on Friday or Saturday ... maybe spit the case too? (IMG:style_emoticons/default/confused24.gif)
Also, worked on a 1.6L 912 (type 616) motor. Torqued the recently installed 3~4 head, installed the rocker arm assembly and adjusted the valve clearances. The PO also forgot to install wave washers under the (7) rocker arm nuts when he rebuilt this motor (IMG:style_emoticons/default/screwy.gif) ... luckily I had a jar full of extras.
Now I get to disassemble and check the 1~2 side ... then install new push rod tube seals the missing lower deflector shield. If it's anything like the other side, it's probably missing head stud washers and O-rings, and wave washers for the rocker assembly as well (IMG:style_emoticons/default/confused24.gif)
Still haven't found the misplaced fan housing yet either (IMG:style_emoticons/default/mad.gif)
cali914
post Aug 14 2015, 09:13 AM
Post #6439
cali914
(IMG:style_emoticons/default/headbang.gif) tried my hand with body work. I think I am going to leave this to the pros LOLAttached Image Attached ImageAttached Image
Cairo94507
post Aug 14 2015, 09:33 AM
Post #6440
Michael
Smart call. A man has got to know his limitations.
- Lo-Fi Version Time is now: 18th December 2024 - 02:16 PM
