what did you do to your 914 today |
dadaDaveed |
Mar 17 2012, 04:23 PM
Member Group: Members Posts: 111 Joined: 19-February 09 From: San Antonio, TX Member No.: 10,071 Region Association: Southwest Region |
[/quote]From the pix, that looks looks a pretty scary project (IMG:style_emoticons/default/blink.gif)
How long did it take you to do the conversion? ... I'm planning on a similar conversion, but using Engman's kit. [/quote] It looks scary, but it's not hard at all if you're methodical about it. Fortunately, my front harness is all bundled up in the passenger footwell while I finish cutting and welding on the body. I imagine it would be much more tedious trying to do this under the dash. It took me about 40 minutes. It's too cramped to label every wire while it's still attached to the old panel, so I pulled one wire at a time, labeled it... (upper 1, lower 1, upper 2... etc.) then removed the labels just before attaching each wire it to the new panel. |
mrbubblehead |
Mar 17 2012, 04:30 PM
Twodollardoug Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
i finally was able to finish my early doors to late window regulator mod. painted the doors, and the top, and all new window and top rubber and fuzzies from 914rubber.com thanks mark. and not one squeek or rattle to be heard (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif). well ok, i have one tiny rattle. the knob of the window crank does jiggle a bit. but that will be an easy fix. on a side note, on my way to the auto paint supply, i stopped by the county dump for a quick weigh in. i finally broke the one ton mark. it the olympic blue flame weighed in at a meager 1980 lbs. 1/4 tank of fuel and me out of that car. and that was before the early door swap. next im out that way, i'll weigh it again.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i722.photobucket.com-12492-1332023408.1.jpg) |
JStroud |
Mar 17 2012, 04:55 PM
Senior Member Group: Members Posts: 1,463 Joined: 15-January 11 From: Galt, California Member No.: 12,594 Region Association: Northern California |
Decided to change my steering wheel today, then while it was off thought it would be a perfect time to take my gauges out, fix my odometer, clean the dead spiders and cobwebs out of the face, and paint the trim piece.....so I did. Followed the intsructions on pelican got the odometer fixed...and cleaned out. Now just waiting for some paint to dry to put it all back together (IMG:style_emoticons/default/piratenanner.gif)
Also made brakets and finally got speakers mounted in the stock grills, 4 speakers now sounds awesome. (IMG:style_emoticons/default/aktion035.gif) What Rattles... Jeff |
iamchappy |
Mar 17 2012, 04:57 PM
drove it, filled it up with gas...
potomacmidget |
Mar 17 2012, 05:05 PM
I gotta have more cowbell.... Group: Members Posts: 161 Joined: 27-March 11 From: Maryland Member No.: 12,860 Region Association: North East States |
Drove 50 miles today enjoying nice weather in Maryland (IMG:style_emoticons/default/piratenanner.gif)
struckn |
Mar 17 2012, 06:48 PM
Senior Member Group: Members Posts: 1,069 Joined: 9-November 11 From: South Central York Pennsyvania Member No.: 13,764 Region Association: MidAtlantic Region |
Took my 5 year old Grandson for a ride with the top off and Booster Seat in place
He couldn't stop talking and smiling the whole ride. Crossed some R/R Tracks and the horn came on and I had to pull on the Horn rim to get it to stop. Got home and reattached the wire in the Horn ring but I think I might need a new rubber cup to fix it permenently. OR... get a smaller removable steering wheel with horn button in the middle. It would make it easier for me to get in and out of the car. I'm 6'2 and 62 (mentally much younger). |
effutuo101 |
Mar 17 2012, 07:40 PM
Advanced Member Group: Members Posts: 2,735 Joined: 10-April 05 From: Lemon Grove Member No.: 3,914 Region Association: Southern California |
I think filling and sanding is my life....
MikeSpraggi |
Mar 17 2012, 07:46 PM
Senior Member Group: Members Posts: 781 Joined: 7-February 05 From: Silver Spring, Md Member No.: 3,570 Region Association: MidAtlantic Region |
I think filling and sanding is my life.... Then your life is full-filling grasshopper (IMG:style_emoticons/default/biggrin.gif) . |
MikeSpraggi |
Mar 17 2012, 07:48 PM
I heard the track car start up for the first time today (first time for me at least)!
etcmss |
Mar 18 2012, 04:41 AM
etcmss Group: Members Posts: 183 Joined: 20-April 06 From: Lancaster, Ky Member No.: 5,899 Region Association: Upper MidWest |
primer applied, taped for paint --
Haudiosolutions |
Mar 18 2012, 07:07 AM
Member Group: Members Posts: 215 Joined: 19-October 10 From: Sevierville, TN Member No.: 12,284 Region Association: South East States |
Got the new head unit wired up and mounted in the dash. I removed my carpet and when doing so, I noticed a smell of mildew from the drivers side. Removed the sound pad and tar from the floors. Now very clean and painted. Just need to find a glove box, (Think i have a lead on a door) install the new carpet, install the new speakers and pods which are for some reason taking forever to get here.
etcmss |
Mar 18 2012, 04:04 PM
painted
rnellums |
Mar 18 2012, 05:19 PM
Professional Enthusiast Group: Members Posts: 1,646 Joined: 26-November 09 From: Littleton, CO Member No.: 11,072 Region Association: Rocky Mountains |
I changed the transmission and motor oil, adjusted the shift linkage since the change from the weltmeister short shift, and lowered the rear by half an inch(before the picture was taken)
watsonrx13 |
Mar 18 2012, 05:36 PM
Advanced Member Group: Members Posts: 2,735 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States |
Painted my spare rim...
--- Rob |
Haudiosolutions |
Mar 18 2012, 08:58 PM
76-914 |
Mar 18 2012, 10:02 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,634 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I had tried this with tan carpets from my 76 and it didn't work but I thought I would try again with black carpets from the 73. The factory carpets fit like a glove so I thought why not. A few hours to remove the carpet, blast with hose to cleanse, rinse with hot water then soak in 3 gal of hot water, 1 cup of vinegar and one pack of Black Rit dye for 30 minutes. Less than $5. The flash really makes the carpet look lighter than it came out.
Some before's A before and after side by side Finish |
jsayre914 |
Mar 18 2012, 10:16 PM
Speed Up !!! Group: Members Posts: 3,206 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region |
6freak |
Mar 19 2012, 07:34 AM
pnewman |
Mar 19 2012, 09:06 AM
Member Group: Members Posts: 371 Joined: 15-February 05 From: Lincolnshire, IL Member No.: 3,606 Region Association: Upper MidWest |
bulitt |
Mar 19 2012, 09:46 AM
Achtzylinder Group: Members Posts: 4,188 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
Checked the compression on all cylinders.
Sat and looked at my car because I'm waiting for a forum member to send me a left rear caliper which I purchased a week ago- (IMG:style_emoticons/default/confused24.gif) |
Lo-Fi Version | Time is now: 24th November 2024 - 07:50 PM |
