what did you do to your 914 today |
iwanta914-6 |
Oct 14 2015, 11:06 AM
Senior Member Group: Members Posts: 718 Joined: 26-June 09 From: Minnesota Member No.: 10,510 Region Association: None |
$20 91 octane almost 3/4 tank. Used the fuel cap to hold the pump spring so I don't have to hold it while pumping. Lately makes my back hurt when holding the pump spring on one hand and the pump on the other hand. So being in the land of no rain I see wipers are not even needed. |
Oct 14 2015, 11:22 AM
Resident German Group: Admin Posts: 41,935 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
RazorbackFan78 |
Oct 14 2015, 11:42 AM
3 different layers of paint helps protect if from rust Group: Members Posts: 136 Joined: 29-March 13 From: Bentonville, AR Member No.: 15,709 Region Association: South East States |
Replaced the PO's old brass-hinged gas pedal mod. Also found out my upholstery guy can't start on my seats and backpad til end of month so I put the driver seat and seatbelt back in so I could enjoy this great driving weather.
Kansas 914 |
Oct 15 2015, 12:23 PM
I mounted my trailing arms. Next will be the driveshafts.
SKL1 |
Oct 16 2015, 08:11 PM
Senior Member Group: Members Posts: 1,644 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest |
Put on the top for a ride today to warm up oil before changing in anticipation of winter storage... new filter and Brad Penn oil. Ready for winter (IMG:style_emoticons/default/sad.gif)
Silver car that is... red one gets used all winter in AZ!! |
Hank914 |
Oct 17 2015, 06:16 AM
Member Group: Members Posts: 389 Joined: 7-April 14 From: CA and OR Member No.: 17,215 Region Association: None |
Shadowfax |
Oct 17 2015, 11:27 AM
Show us the meaning of haste Group: Members Posts: 509 Joined: 19-January 15 Member No.: 18,340 Region Association: South East States |
DRPHIL914 |
Oct 17 2015, 11:34 AM
Dr. Phil Group: Members Posts: 5,810 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
Very nice!! Looks excellent.
Drove mine to cars n coffee. Attached thumbnail(s) |
DRPHIL914 |
Oct 17 2015, 11:36 AM
Another c&c picture, nice 73 targa with a 3.0 turbo
euro911 |
Oct 17 2015, 12:00 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,859 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
So did you fix your fuse issue?
One of these days I'll get to drive a P-car to the local Pelican C&C. There's also a lot of local 912 BBS guys that regularly attend the events. |
Oct 17 2015, 12:06 PM
DRPHIL914 |
Oct 17 2015, 12:09 PM
So did you fix your fuse issue? One of these days I'll get to drive a P-car to the local Pelican C&C. There's also a lot of local 912 BBS guys that regularly attend the events. You remember I had that going on? I think so. I was looking at the gauge wires to compare to my build off car and tripped the fuse when I moved a connector for the gauge lighting. Turns out the jumper connected to that bulb that was put on there by AL Garcia when he put my l.e.d. lights in was shorting out by touching the edge, since I adjusted it and wrapped it with tape, no more blowing a fuse in that circuit. Now if I can figure out why my fear air fan blows it's fuse I'll be got to go wiring wise. Btw, you have a 912? Guy at c and c today asked me what I k ee about them, because a friend of a friend knows an elderly widow somewhere in AZ that's stashed away, wants to get rid of it, told him I didn't know what it was worth, but I'd check. It's a 69 he thinks, what's it worth, if it's rust free? |
ndfrigi |
Oct 17 2015, 12:28 PM
Advanced Member Group: Members Posts: 2,960 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
So did you fix your fuse issue? One of these days I'll get to drive a P-car to the local Pelican C&C. There's also a lot of local 912 BBS guys that regularly attend the events. You remember I had that going on? I think so. I was looking at the gauge wires to compare to my build off car and tripped the fuse when I moved a connector for the gauge lighting. Turns out the jumper connected to that bulb that was put on there by AL Garcia when he put my l.e.d. lights in was shorting out by touching the edge, since I adjusted it and wrapped it with tape, no more blowing a fuse in that circuit. Now if I can figure out why my fear air fan blows it's fuse I'll be got to go wiring wise. Btw, you have a 912? Guy at c and c today asked me what I k ee about them, because a friend of a friend knows an elderly widow somewhere in AZ that's stashed away, wants to get rid of it, told him I didn't know what it was worth, but I'd check. It's a 69 he thinks, what's it worth, if it's rust free? I think 2 years ago that my 75 1.8 has the 1st time being flat towed because a smoke is coming out from the fresh air vent below the windshield. And I noticed the switch lever for the fan was half way on. So the following day after it was towed, I found out that my fresh air fan blower was stock and hard to turn the blower by hand. The fuse didn't blow up instead the wire for the blower burned. |
DRPHIL914 |
Oct 17 2015, 12:32 PM
Andy, is the googly eye look for the 911 targa? Turns out he live in the same development I do, snout 4 blocks away. Has his own shop here in town with a lift, offered to help out with my project, had been around 911s a lot, flips them mostly,- might be a new Porsche BFF (IMG:style_emoticons/default/laugh.gif) , well nice guy, offered to let me use the lift etc might head over this afternoon to check it out..
So he does have the original 2.7 to go in that car, been rebuilt recently, the 3.0 might be coming out, going to find out what he's asking for the 3.0 (IMG:style_emoticons/default/idea.gif) |
Oct 17 2015, 12:41 PM
Andy, is the googly eye look for the 911 targa? Nope, it means that all i did to my 914 today was looking at it as i was taking out the trash ... (IMG:style_emoticons/default/biggrin.gif) |
Madswede |
Oct 17 2015, 04:03 PM
Flat Out Driver Group: Members Posts: 853 Joined: 13-September 06 From: Rio Rancho NM Member No.: 6,831 Region Association: Rocky Mountains |
NEWS FLASH: I drove my car today. I mean REALLY drove it. It's a long story, but it's finally running as it was when Joe O'Brien delivered it (though not as rich (IMG:style_emoticons/default/laugh.gif) )
Man o man, this thing is a monster. There's still some tweaking to do, it's not quite making full HP at WOT, probably need to adjust acceleration enrichment and then work on EGO controller programming. But I say, DAYUM SHE BE QUICK!! (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/w00t.gif) You couldn't get this grin off my face with a sledgehammer! |
euro911 |
Oct 17 2015, 04:45 PM
(IMG:style_emoticons/default/laugh.gif) - Andy ...
Phil, just as with any car, it's hard to place a value without looking at it, but ('65 ~ '69) 912 values have been rapidly increasing recently (even the '76 912Es). I've seen pristine examples go for as high as $75k. (IMG:style_emoticons/default/blink.gif) Average decent drivers are from the mid to high teens to the high 20's. Really nice drivers are in the $30k ~ $45k range. EDIT: Here's a link to the 912 BBS classifieds: Link Yep, currently working on two 912s ... '66 in the foreground ... '67 on the rack: |
914Next |
Oct 17 2015, 07:47 PM
Senior Member Group: Members Posts: 705 Joined: 28-July 14 From: Ephraim Wisconsin Member No.: 17,695 Region Association: Upper MidWest |
Drove up with Harve (57Liincolnman) to Euro Auto Fest in Greenville SC. Great show but disappointing that out of over 400 cars we were the only two 914's
And this one is likely the most beautiful car I've ever seen: |
kid914 |
Oct 17 2015, 08:49 PM
ALWAYS lead...NEVER follow!!!! Group: Members Posts: 2,534 Joined: 9-March 11 From: Canada Member No.: 12,811 Region Association: Canada |
Finished installing the 914rubber dash top. Looks pretty good. Had a chance to reglue the basketweave material on the glove box and dash and also some general cleaning (dash vents, instruments, etc.) Before After Look very nice. Is this just a glued dash (cap)? I need to do the same. (IMG:style_emoticons/default/smash.gif) |
euro911 |
Oct 17 2015, 09:04 PM
And this one is likely the most beautiful car I've ever seen: (IMG:style_emoticons/default/agree.gif) Nice lines. Do you happen to know what it is? |
Lo-Fi Version | Time is now: 19th December 2024 - 10:10 PM |
