862 Pages V « < 346 347 348 349 350 > »
76-914
post Nov 23 2015, 09:41 AM
Post #6941
Found the spot I had inserted my big fat hand and dislodged the spade connector on the starter relay. (IMG:style_emoticons/default/headbang.gif) I had prepared myself for some grand search but it revealed itself so quickly I had time to do Spring Cleaning in my garage. I know, a few months early but it really needed a good scrubbing, literally.
post Nov 23 2015, 12:31 PM
Post #6942
Resident German
(IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/cheer.gif)
Mikedrevguy
post Nov 23 2015, 10:01 PM
Post #6943
QUOTE(hndyhrr @ Nov 21 2015, 05:22 PM) *
Nice crispy sunny day here in so. oregon, took the pumpkin for a nice ride...... topless. I imagine if i had the top on the heater would have baked me out . anyhow great ride.
Scraped Windows this morning on RevWife's 76 914- cleared space in garage this epafternoon.
DRPHIL914
post Nov 24 2015, 07:54 AM
Post #6944
Dr. Phil
drove to work to day, 38 degrees at 6am! glad I have the new heated seats from 914rubber!! BUT several times this morning car hesitated on acceleration. has not done that for a long time- exactly a year ago, when I chased my tail to find a failing MPS and then a month later finally figured out distributor cap was bad. after replacing the cap and rotor I have not had a day where it didn't start or run perfect, so not an official pole but, what are your top 10 reasons for a 75 d-jet 914 to suddenly start to sputter , hesitate intermiitantly? I did just fill tank with ethanol free gas, it first did this a few days ago when I was toward the bottom of the tank, before filling it. SO.... my first thoughts
1. cap and/or rotor
2. points- nope I have hot spark module
3. FI trigger points - had this happen, put new ones in last year
4. plugs and wires - new last year
5. injectors - brand new 2 years ago NOS from Otto's venice
6. F.I. grounds - had this come loose once before - will double check later
7. fuel pressure- pefect
8. CHT- it was defective/out of spec resistance wise so replaced last year
9. MPS- could be, over 6 years ive had 3 fail, it may be time to rebuild one with my tangerine kit...... last one failed electronically and went SUPER LEAN no rich, so it actually would not start, unless you disconnected the vac hose from manifold , then it ran , very rich but ran
10. bad harness - nope brand new 2 years ago from Bowlsby
11. TPS - used to have that 3000rpm bucking, but replaced it with a NOS one from bruce stone and have never seen that since - last year
other thoughts?
bad fuel, fuel filters and lines yes replaced 1 year ago during my last fun episode of "chasing my tail trouble shooting the d-jet" episode.
Have a great day ya'all! (IMG:style_emoticons/default/popcorn[1].gif)
shoguneagle
post Nov 24 2015, 08:11 AM
Post #6945
shoguneagle
After about ten years of building and adjusting to lost theft items, the car is finally on the down side for painting. Started stripping all the parts off the car in preparation for painting. should be done this afternoon, then the labor starts in preparation and sanding.
euro911
post Nov 25 2015, 05:02 AM
Post #6946
Well, my new 2056 is scheduled to be delivered to the local freight terminal later today (IMG:style_emoticons/default/smile.gif) ... so in preparation, I started fabricating a template for a rear engine mounting bar. This is what I came up with (so far) ...
I still need to determine exactly where and how to mount the side tubes - weld them directly to the bar, or weld the tubes to adjustable plates bolted to the bar (allowing for fine-adjustment) (IMG:style_emoticons/default/confused24.gif)
Even though this mock-up is in the '67, I decided to install the T4 motor in my '66 912, and the '68 912/616 motor will go into the '67 (after some underbelly repairs) (IMG:style_emoticons/default/sawzall-smiley.gif) & (IMG:style_emoticons/default/welder.gif)
Earlier in the day, I shot the [recently extended] J-pipes for the '68 616 motor with some of that 2000° BBQ paint.
I promise to do some work on a 914 soon (IMG:style_emoticons/default/rolleyes.gif)
ndfrigi
post Nov 25 2015, 02:32 PM
Post #6947
yesterday my friend dropped his car to my place (family living for family vacation) to be pick up by a member here from Ohio this thursday and drive it back home.
Love the color and classic look with those wheels and narrow tires.
euro911
post Nov 25 2015, 06:34 PM
Post #6948
I see you're already prepared for the impending oil change on it in the morning (IMG:style_emoticons/default/biggrin.gif)
I picked up the 'new' [to me] 2056 from FedEx this am. Got it over to the shop and hoisted it up onto an engine stand. That's about all ...
ndfrigi
post Nov 25 2015, 06:53 PM
Post #6949
QUOTE(euro911 @ Nov 25 2015, 04:34 PM) *
Yes sir Mark! Thomas is flying tonight and tomorrow we will do some adjustments and change oil before they (with his wife) start their journey back home to Ohio.
sb914
post Nov 25 2015, 07:04 PM
Post #6950
Surf Guru
I drove it.Attached Image
ndfrigi
post Nov 25 2015, 07:31 PM
Post #6951
Sir Mark, if you're available tomorrow morning, to hang out with us before Thomas and his wife live and drive this car to Ohio.
post Nov 26 2015, 10:20 AM
Post #6952
QUOTE(euro911 @ Nov 25 2015, 03:02 AM) *
Mark, you should probably be posting this over at Type4 Forums. There have been a lot of Type 1 to 4 conversions documented there. One very clever one using 7/8" turn buckle adjusters. No welding required.
euro911
post Nov 26 2015, 11:25 AM
Post #6953
This Type-4 Forum? ... http://personalitycafe.com/type-4-forum-individualist/ (IMG:style_emoticons/default/confused24.gif)
(IMG:style_emoticons/default/WTF.gif) ... (IMG:style_emoticons/default/slap.gif)
I posted on the 912BBS Renegade forum
VegasRacer
post Nov 27 2015, 11:40 AM
Post #6954
ELVIRA
It is getting so brutally cold here that I had to winterize the car. (IMG:style_emoticons/default/bruce.gif) I put the roof back on.
ndfrigi
post Nov 27 2015, 12:33 PM
Post #6955
Yesterday morning pick up Thomas and his wife from their hotel. Then started to do the change oil/filter, adjust clutch, install speedo angle drive of the 73 1.7 they bought here in SoCal. Few nice 914 owners or member came to join us. Jim, Abe and Bob. And finally I was able to drive for the 1st time a 914-6 of Jim's car, a real blast car!!
Yesterday afternoon, the couple started their journey to check some SoCal places and drove to Vegas for their 1st nyt stop. And this morning they are currently in Arizona area. This couple will do a few days trip heading home to Ohio with their newly purchased 73.
Take care always Thomas and Karah-Lyn!
Enjoy and God bless your journey/trip!
euro911
post Nov 27 2015, 12:41 PM
Post #6956
(IMG:style_emoticons/default/thumb3d.gif) Glad to see it went well - sorry I couldn't make it down there (IMG:style_emoticons/default/dry.gif)
ndfrigi
post Nov 27 2015, 12:42 PM
Post #6957
QUOTE(euro911 @ Nov 27 2015, 10:41 AM) *
No problem sir Mark! family first specially for a thanksgiving day!
Coondog
post Nov 27 2015, 06:34 PM
Post #6958
Stopped by PMS to check on the progress. Front and rear prepped for back date bumpers also had side markers removed. 911 goodies get installed next.
Cairo94507
post Nov 28 2015, 08:10 AM
Post #6959
Michael
Excellent. I personally do not appreciate the BUBS and love to see these cars correctly converted to early bumpers.
Eric and his crew do very nice work. No surprise really if you know Eric and have seen his cars.
Congratulations on having this work done. Your car is going to be a head turner.
sb914
post Nov 28 2015, 10:55 AM
Post #6960
Surf Guru
I drove it Attached Image
- Lo-Fi Version Time is now: 20th December 2024 - 02:25 PM
