862 Pages V « < 349 350 351 352 353 > »
euro911
post Dec 7 2015, 01:18 PM
Post #7001
QUOTE(Coondog @ Dec 7 2015, 07:40 AM) *
Deal of the year....... (IMG:style_emoticons/default/agree.gif)
More like - deal of a lifetime (IMG:style_emoticons/default/aktion035.gif)
shoguneagle
post Dec 7 2015, 02:36 PM
Post #7002
shoguneagle
Finished taking the 914 a part for future painting next year. Everything pulled and starting the initial sanding, chip repair, and build primer. Have some work to finish the sheetmetal around the front air/oil cooler; add hydraulic clutch, and a couple other small projects on the car.
Temperature around 50 degrees and raining; someone else will be applying the build primer, primer/sealer, and paint. Ten years and one theft later, the car is finally headed to the "podium" to be used next summer.
VegasRacer
post Dec 7 2015, 11:27 PM
Post #7003
ELVIRA
. . . . more for the 914 than to the 914.
I ordered a new SA 2015 (Bell K.1 Pro) helmet. Now I will be legal to pass tech and go play on the track. (IMG:style_emoticons/default/MDB2.gif)
euro911
post Dec 8 2015, 12:26 AM
Post #7004
Why do they say helmets are only good for 5 years from the date first worn?
http://www.smf.org/standards/sa/2015/SA2015releaseNotes.pdf
AZ914
post Dec 8 2015, 07:45 AM
Post #7005
914 Dumbass
QUOTE(euro911 @ Dec 7 2015, 11:26 PM) *
They get smelly. (IMG:style_emoticons/default/laugh.gif)
SKL1
post Dec 8 2015, 09:27 AM
Post #7006
$800???? For that, I'm surprised it wouldn't break in half when you hit with the pressure washer!!
Great deal!!! Even if it is a big bumper car!!
euro911
post Dec 8 2015, 02:22 PM
Post #7007
QUOTE(AZ914 @ Dec 8 2015, 05:45 AM) *
Let's put it another way, Jason ...
Alan and Bill each buy a new helmet.
Alan wears his helmet almost every day on his motorcycle commute to work.
Bill wears his helmet five times a year - to AX his car.
Over the course of five years, Alan wears his helmet more than 300 times, whereas Bill only wears his helmet about 25 times in the same period.
Besides the fact that Bill's helmet might smell nicer, it's been used minimally. Alan's helmet has been used 12x the amount of time, so why would both of their helmets be considered unsafe?
I 'snell' a rat (IMG:style_emoticons/default/rolleyes.gif)
lonewolfe
post Dec 8 2015, 03:49 PM
Post #7008
Materials have a lifespan to be guaranteed over a term to be 100% effective. Laminates and adhesives degrade over time.
euro911
post Dec 8 2015, 05:44 PM
Post #7009
I have read that the Styrofoam liners can break down from body (hair) oil, but I typically strap on a clean head-wrap before inserting my head into a helmet.
Something I don't quite grasp is this:
"Snell urges everyone to replace their Snell certified helmets routinely no later than five years after the helmet is first worn."
What about this scenario: If a helmet manufactured in 2010 isn't put into use (not worn) until 2015 is it still no longer safe to wear?
It's the "first worn" part of the statement doesn't make sense to me. I would be nice if they would elaborate.
Where did you get the info, Mark?
Chaznaster
post Dec 8 2015, 07:11 PM
Post #7010
Every time I had a family member ask what I wanted for Christmas, I asked for a car part, tool or testing device. It seems today was a big day to close out one's Christmas shopping. All for the 914 so related, right? C.
lonewolfe
post Dec 8 2015, 08:32 PM
Post #7011
I make the same requests for Christmas gifts every year and not once have I ever received a car related gift. Not even a screw driver. I no longer make any requests. It's never going to happen. I'm totally on my own when it comes to my hobbies.
euro911
post Dec 9 2015, 03:34 AM
Post #7012
Yeah, I usually have to buy what I want, then have my wife creatively wrap it so I look surprised when I get to open it on Christmas morn (IMG:style_emoticons/default/dry.gif)
(IMG:style_emoticons/default/santa_smiley.gif)
9fourteen14
post Dec 9 2015, 09:18 AM
Post #7013
PORSCHE LUVA
QUOTE(JawjaPorsche @ Dec 7 2015, 05:35 AM) *
QUOTE(alfadoc @ Dec 7 2015, 04:17 AM) *
Brought this gem home. Bought it from the original owner, with full service records. $800. Pretty minimal rust, all things considered. Been sitting 5 years. Had it running and took it for a drive in 1.5 hours.
[attachmentid=530
588]
Nice Score! (IMG:style_emoticons/default/beerchug.gif)
Awesome. I thought I had a deal. I'll buy it from ya triple your money. 2400
1stworks
post Dec 9 2015, 09:46 AM
Post #7014
Installed Roth Sport quick release with hub.
I need to find collar to cover up 1" gap.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i1315.photobucket.com-15718-1449675962.1.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i1315.photobucket.com-15718-1449675962.2.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i1315.photobucket.com-15718-1449675962.3.jpg)
post Dec 9 2015, 12:11 PM
Post #7015
Resident German
nuttin ... (IMG:style_emoticons/default/sad.gif)
cary
post Dec 10 2015, 06:45 AM
Post #7016
Bought a metal case at HF for my MPS adjusting tools.
cary
post Dec 10 2015, 07:04 AM
Post #7017
While I'm letting the SPI epoxy cure for 24 hours on my rustoration. So I set about rebuilding the door straps on my white car.
Started with the right side. At the end of the day it still clicked a bit. Built new pin from a long 1/4" bolt, still clicks a tiny bit. Plan to cut a custom sized bolt with the die set so I can use a nylock nut to keep it tight. A couple threads say this does the trick.
Both sides are getting new scrapers.
http://shop.914rubber.com/914-outer-window...f-2-914ODS2.htm
Both sides are getting new end caps.
http://shop.914rubber.com/914-Late-door-en...ght-914LDEC.htm
Drivers side is getting a new inner fuzzy.
http://shop.914rubber.com/914-Inner-door-f...of-2-914IDF.htm
Coondog
post Dec 10 2015, 05:01 PM
Post #7018
Well i didn't do this but i had the want and the $$$$
914 almost done with 1st phase of going 6
Work done by PMS
Was going to resize but i like the effect
stevegm
post Dec 12 2015, 04:41 PM
Post #7019
Got the front turn signal housings ready to go in tomorrow, and finally took the tape off of the wring from when we painted the trunks. Time to get the car going.
sb914
post Dec 12 2015, 06:19 PM
Post #7020
Surf Guru
I looked at all the parts I have to install! (IMG:style_emoticons/default/headbang.gif)
- Lo-Fi Version Time is now: 20th December 2024 - 09:19 PM
