what did you do to your 914 today |
Coondog |
Dec 17 2015, 08:06 PM
Advanced Member Group: Members Posts: 2,089 Joined: 24-September 15 From: Apple Valley Calif Member No.: 19,195 Region Association: Southern California |
DRPHIL914 |
Dec 19 2015, 09:40 PM
Dr. Phil Group: Members Posts: 5,810 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
Drove it to cars and coffee Hilton head, saw a nice '69 911E signal orange. Owner has a handful of 911, and a sunflower yellow 914, 74 appearance group car, ver nice but he is convinced it is a rare "s" model (IMG:style_emoticons/default/lol-2.gif)
Wanted to argue about the validity of that claim, so I asked if his coa confirmed this, and that was the end of that, btw he has boxes of parts, and I asked if he had any good h.e's. He didn't know what that was (IMG:style_emoticons/default/blink.gif) , so. Offered to sort thru his stash. |
914_teener |
Dec 20 2015, 01:37 AM
914 Guru Group: Members Posts: 5,250 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
BillC |
Dec 20 2015, 04:49 PM
Senior Member Group: Members Posts: 573 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region |
BIGKAT_83 |
Dec 20 2015, 05:38 PM
Senior Member Group: Members Posts: 1,798 Joined: 25-January 03 From: Way down south Bogart,GA Member No.: 194 Region Association: South East States |
Nice video! |
76-914 |
Dec 21 2015, 11:23 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,646 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Ran the Ortega, saw a nice black 356 convertible on the side of the road. Pulled over to ask if needed help. It's not every day that you see a 914 pulling over to offer assistance. (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/av-943.gif) Said he was waiting on the wrecker. Back home and on the lift again to continue measurements on the new exhaust system.
Red72 |
Dec 22 2015, 02:07 PM
Newbie Group: Members Posts: 25 Joined: 26-January 15 From: Simcoe, Ontario Member No.: 18,358 Region Association: Canada |
Working on making a horn button...had a buddy turn a domed wood disc, which is in a 914rubber.com button...and laser engraved the logo.
The rest of the wheel still needs some refurbishing before it's all done...but that's what winter is for! Attached thumbnail(s) |
lonewolfe |
Dec 22 2015, 02:20 PM
Senior Member Group: Members Posts: 819 Joined: 12-September 11 From: Oakland, CA Member No.: 13,549 Region Association: Northern California |
Working on making a horn button...had a buddy turn a domed wood disc, which is in a 914rubber.com button...and laser engraved the logo. The rest of the wheel still needs some refurbishing before it's all done...but that's what winter is for! Very cool one of a kind horn button. I love the grain of the wood! |
wndsnd |
Dec 22 2015, 06:00 PM
You wanted a horse, but got a goat. Nobody wants a goat.... Group: Members Posts: 2,861 Joined: 12-February 12 From: North Shore, MA Member No.: 14,124 Region Association: North East States |
Worked on deck height and shim selection.
Tedious, got one side done. |
DRPHIL914 |
Dec 24 2015, 12:33 AM
Opened up 2 043 mps units, one just needed new seal, but the copper diaphragm was fine,
But second one was not holding vac, had never been opened, so the rivets were removed and the diaphragm was torn, so it got a new seals, paper gasket and diaphragm. Now holds vac! Tests out o.k. electronically so it will get road tested to.orrow. the epoxy seal was not touched, and I left it alone, so that the depth of the inner screw would be the same. Thanks to Chris Foley for producing these!. One thing, the one with a good diaphragm had been tampered with by a p.o. the inner screw was turned quite a ways out or counter clockwise, and I measured the depth it had been set was about 3 turns further out than the one that was untouched. So no wonder it would not work for us.for anyone who has messed with one of these you know that even a quarter turn will make a huge difference., so this was way off I hope now it's close enough that I can make a minor adjustment and get it set back to where it should be. My Attached thumbnail(s) |
sb914 |
Dec 24 2015, 03:27 PM
Surf Guru Group: Members Posts: 4,410 Joined: 25-November 12 From: Brookings,Oregon Member No.: 15,191 Region Association: Southern California |
I installed rennline pedal set and new coco Matt's that I got for my b day (IMG:style_emoticons/default/aktion035.gif)
Hank914 |
Dec 24 2015, 05:24 PM
Member Group: Members Posts: 389 Joined: 7-April 14 From: CA and OR Member No.: 17,215 Region Association: None |
Porschef |
Dec 25 2015, 11:25 AM
How you doin' Group: Members Posts: 2,180 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
wndsnd |
Dec 25 2015, 05:37 PM
dangrouche |
Dec 25 2015, 07:44 PM
dangrouche Group: Members Posts: 550 Joined: 1-May 04 From: San Francisco Bay Area Member No.: 2,012 Region Association: None |
I attached a pair of inexpensive light bars to the top of the fog light grilles with zip ties, but modded them today, 1/17/16, using machine screws and fender washers for a cleaner look.
here is the eBay product purchased: http://www.ebay.com/itm/171961642045?_trks...K%3AMEBIDX%3AIT this is an update of my previous mod where I changed out the interior components of the OE fog light bulbs to LEDs. (here is that old link) http://www.914world.com/bbs2/index.php?showtopic=230504 1/17/16, update on attachment method to eliminate zip ties (lots of work but cleaner appearance and protects the LED light bar.) You will need two drill bits, 1/8" and 1/4". a. Drill the smaller hole through both sides of edge moulding, (gotten at local TAP plastics store) 10x19mm/ The plastic edging is flexible and is soft enough and matches the gentle curve of the grille, and flexes nicely as the machine screw tightens up onto back of the grille. b. Drill a larger hole on the side that faces forward. Place a putty knife in between the molding to avoid drilling through the other side c. insert the machine screws into the molding d. insert the LED strip into the molding e. add shrink wrap to the end of the completed assembly f. 914 fog grills need only a 3/4" long machine screws and a fender washer. As seen in these added pics, I needed 2 inch screws to attach this to my Lexus quite inexpensive: pair of LEDs $2, hardware $3, plastic edging, sorry, unknown$$ bought it 10 years ago. all told, less than $10, out the door. Attached thumbnail(s) |
Porschef |
Dec 26 2015, 07:10 AM
Interesting, I had some LED strips left over from a defective Robern med cabinet. I found they sat right in that spot in the grille but didn't have any weather protection so I put the small project on the back shelf.. Sometimes more light is better. Looks good.
(IMG:style_emoticons/default/beerchug.gif) |
wndsnd |
Dec 26 2015, 09:28 AM
I attached a pair of inexpensive light bars to the top of the fog light grilles with zip ties here is the eBay product purchased: http://www.ebay.com/itm/171961642045?_trks...K%3AMEBIDX%3AIT this is an update of my previous mod where I changed out the interior compoents of the OE fog light bulbs to LEDs. (here is that old link) http://www.914world.com/bbs2/index.php?showtopic=230504 During daylight hours, top pic shows what drivers see in their rear view bottom pic show what drivers see in their rear view if I switch on the fog lights Hmmmmm. Remove the fogs, multiple strips to match the grill pattern. Look cool? |
dangrouche |
Dec 26 2015, 10:39 AM
I attached a pair of inexpensive light bars to the top of the fog light grilles with zip ties here is the eBay product purchased: http://www.ebay.com/itm/171961642045?_trks...K%3AMEBIDX%3AIT this is an update of my previous mod where I changed out the interior compoents of the OE fog light bulbs to LEDs. (here is that old link) http://www.914world.com/bbs2/index.php?showtopic=230504 During daylight hours, top pic shows what drivers see in their rear view bottom pic show what drivers see in their rear view if I switch on the fog lights Hmmmmm. Remove the fogs, multiple strips to match the grill pattern. Look cool? That sound appealing. I did buy another pair, as spares, so I will try that out. It will blaze at night, but in daytime they do look cheesy. |
Dec 26 2015, 10:43 AM
914-6 GT in waiting Group: Members Posts: 19,640 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Amazing how they can sell led lights and include shipping from China for $2.09.
Larmo63 |
Dec 27 2015, 10:15 PM
Advanced Member Group: Members Posts: 4,267 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California |
Lo-Fi Version | Time is now: 20th December 2024 - 11:19 PM |
