what did you do to your 914 today |
914Sixer |
Dec 27 2015, 10:24 PM
914 Guru Group: Members Posts: 9,032 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
New rear license plate lights for the big ugly bumper.
Jake Raby |
Dec 27 2015, 11:01 PM
Engine Surgeon Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
Fitted Fuchs!
RickS |
Dec 27 2015, 11:22 PM
Senior Member Group: Members Posts: 1,408 Joined: 17-April 06 From: 'False City', WA Member No.: 5,880 Region Association: None |
Added Superbright LED brake/tail lights https://www.superbrightleds.com/moreinfo/ta...trofit-car/814/ for a whopping $40 for two. Instant-on brake lights and bright. What I like about them is the look is stock, but brighter and much faster to deploy.
edwin |
Dec 28 2015, 07:30 AM
Member Group: Members Posts: 321 Joined: 20-May 09 From: Australia Member No.: 10,384 Region Association: Australia and New Zealand |
Went for a drive on some country back roads. Cracked the windscreen in the middle.
Going to be fun for the insurance company to find a replacement here in Australia. Any ideas what would cause a break in the middle? I'm thinking old hard butyl. Was also 40 degrees C |
ntmatter |
Dec 28 2015, 05:48 PM
Newbie Group: Members Posts: 46 Joined: 10-May 11 From: Gig Harbor, WA Member No.: 13,049 Region Association: None |
Why do they say helmets are only good for 5 years from the date first worn? http://www.smf.org/standards/sa/2015/SA2015releaseNotes.pdf They get smelly. (IMG:style_emoticons/default/laugh.gif) (IMG:style_emoticons/default/laugh.gif) Let's put it another way, Jason ... Alan and Bill each buy a new helmet. Alan wears his helmet almost every day on his motorcycle commute to work. Bill wears his helmet five times a year - to AX his car. Over the course of five years, Alan wears his helmet more than 300 times, whereas Bill only wears his helmet about 25 times in the same period. Besides the fact that Bill's helmet might smell nicer, it's been used minimally. Alan's helmet has been used 12x the amount of time, so why would both of their helmets be considered unsafe? I 'snell' a rat (IMG:style_emoticons/default/rolleyes.gif) Not quite, some more context: Alan and Bill each buy 4 new tires Alan drives his car to work each day a few miles, accumulating 10K miles per year Bill puts the tires on his car and parks it outside, driving it once per year to autocross At the end of 5 years, Alan's tires are worn down and fully consumed, time for new ones At the end of 5 years, Bill's tires have sat and dried out - they have all their tread left but also need to be replaced. The combination of time, sun, temperature and humidity changes, etc make them cross a threshold where we'd consider them "safe". Even if Bill's particular tires are still good, we need a way to say, "tires that are older than X months are no longer safe enough for track use as our general rule". Now also consider Charlie - he has a set of New-Old-Stock original 914 165-R15 tires that have been sitting in a temperature and humidity controlled vault, lovingly tended, and are conditionally identical to brand new tires. However, they are also outdated for an application like track driving - the technology is dated. So, we'd make a decision to say that Charlie's tires meet the functional spec for which they are designed, but the design spec has been replaced by higher quality radials and better rubber compounds in a modern tire. So, there may also be a date requirement on gear that goes to how "current" it is in the ever improving world of safety gear. (Harnesses and helmets have this in particular). Long story short - it's annoying (stipulated) to have to buy new gear when the old gear still feels good, but ask Dale Earnhardt Sr. about the value a modern helmet. |
pete000 |
Dec 28 2015, 06:12 PM
Senior Member Group: Members Posts: 1,886 Joined: 23-August 10 From: Bradenton Florida Member No.: 12,094 Region Association: South East States |
December 26 went for a drive along the Coast... Cool 62 degrees, clear and sunny.
Car seems happy after adjusting the valves, rebuilt TB, and new Bursch muffler and SSi's. Attached image(s) |
euro911 |
Dec 29 2015, 12:59 AM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,859 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
Not quite, some more context: Again, my question relates to the 'after first worn' statement they made. I've never seen an expiration date on any helmets.Alan and Bill each buy 4 new tires Alan drives his car to work each day a few miles, accumulating 10K miles per year Bill puts the tires on his car and parks it outside, driving it once per year to autocross At the end of 5 years, Alan's tires are worn down and fully consumed, time for new ones At the end of 5 years, Bill's tires have sat and dried out - they have all their tread left but also need to be replaced. The combination of time, sun, temperature and humidity changes, etc make them cross a threshold where we'd consider them "safe". Even if Bill's particular tires are still good, we need a way to say, "tires that are older than X months are no longer safe enough for track use as our general rule". Now also consider Charlie - he has a set of New-Old-Stock original 914 165-R15 tires that have been sitting in a temperature and humidity controlled vault, lovingly tended, and are conditionally identical to brand new tires. However, they are also outdated for an application like track driving - the technology is dated. So, we'd make a decision to say that Charlie's tires meet the functional spec for which they are designed, but the design spec has been replaced by higher quality radials and better rubber compounds in a modern tire. So, there may also be a date requirement on gear that goes to how "current" it is in the ever improving world of safety gear. (Harnesses and helmets have this in particular). Long story short - it's annoying (stipulated) to have to buy new gear when the old gear still feels good, but ask Dale Earnhardt Sr. about the value a modern helmet. How much new technology are in 2015 helmets as compared to 2000 helmets? From what I've read, not much. As for Dale Earnhart's death, there's still some controversy regarding the actual cause, and focuses more on the harness installation. Also, the HANS restraint that NASCAR mandated aren't changes to the helmets design or construction. Regardless, even though well cared for and never damaged, my helmets are pretty old now - guess I'll have to get a new one ... but I won't be spending $600. + for the fancy graphics this go-around. |
sdoolin |
Dec 29 2015, 08:10 AM
Member Group: Members Posts: 384 Joined: 1-May 14 From: LouKY Member No.: 17,299 Region Association: None |
I dug my original bus motor out from under the workbench in my old garage. I've had this engine for probably 25 years now, just waiting for a reason to build it. It came out of my 76 Chromium Yellow Westy and had a dropped valve. No other damage that I could tell (at that time). Happily the crank spins freely. I used the heads in a bus engine build years ago, so will need replacements. Trying hard not to spend all day looking at engine kits on Type IV Store, but it is difficult. Shall I go 2056, or 2270? Hmmmmmm... |
JoeD |
Dec 29 2015, 08:25 AM
Member Group: Members Posts: 156 Joined: 19-July 15 From: Atlanta, GA Member No.: 18,973 Region Association: South East States |
Stripped the interior in preparation for rust repairs to floor pan, and ready to install Mark's new 914Rubber dashpad when back from welder.
And off she goes, once again on the back of a flatbed... |
Hank914 |
Dec 30 2015, 11:55 AM
Member Group: Members Posts: 389 Joined: 7-April 14 From: CA and OR Member No.: 17,215 Region Association: None |
Then I changed the engine and transmission oils. 3K and 25K miles, respectively. The wooden blocks are safety backups to the cylinderr Jack stands, which are pretty fail safe. But I'll need the wooden ones if I ever go to the new rachet Jack stands after losing my mind. Or if I'm ever doing an oil change after (IMG:style_emoticons/default/beer3.gif) |
Michael N |
Dec 30 2015, 12:14 PM
Certifiable Group: Members Posts: 1,426 Joined: 6-June 04 From: San Jose, Ca Member No.: 2,164 Region Association: Northern California |
Keeping the battery charged by driving over to check the surf in Santa Cruz. (IMG:style_emoticons/default/driving.gif)
matthepcat |
Dec 30 2015, 12:46 PM
Meat Popsicle Group: Members Posts: 1,462 Joined: 13-December 09 From: Saratoga CA Member No.: 11,125 Region Association: Northern California |
Seems like no one is working this week.
(IMG:style_emoticons/default/idea.gif) Keeping the battery charged by driving over to check the surf in Santa Cruz. (IMG:style_emoticons/default/driving.gif) |
mgp4591 |
Dec 30 2015, 01:47 PM
914 Guru Group: Members Posts: 5,501 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region |
Seems like no one is working this week. (IMG:style_emoticons/default/idea.gif) Keeping the battery charged by driving over to check the surf in Santa Cruz. (IMG:style_emoticons/default/driving.gif) I'm working and happy to be after 7 months off... but if I could drive from San Jose to Santa Cruz whether to check out the surf or the calamari on the pier I'd do it in a heartbeat- love that drive! (IMG:style_emoticons/default/driving.gif) |
ntmatter |
Dec 31 2015, 03:05 AM
Gas tank out and sealed, wasn't has hard as I'd feared. Was going to put the SS lines in but figured I might as well wait until the car is painted first.
Attached thumbnail(s) |
Michael N |
Jan 1 2016, 07:57 PM
xperu |
Jan 1 2016, 08:16 PM
TEXAS Group: Members Posts: 597 Joined: 13-June 06 From: League City Texas Member No.: 6,213 Region Association: None |
December 26 went for a drive along the Coast... Cool 62 degrees, clear and sunny. Car seems happy after adjusting the valves, rebuilt TB, and new Bursch muffler and SSi's. Very nice looking car. Mike (IMG:style_emoticons/default/driving.gif) |
kid914 |
Jan 1 2016, 08:17 PM
ALWAYS lead...NEVER follow!!!! Group: Members Posts: 2,534 Joined: 9-March 11 From: Canada Member No.: 12,811 Region Association: Canada |
Just admired it. (IMG:style_emoticons/default/wub.gif)
euro911 |
Jan 1 2016, 08:38 PM
Drove it in the snow sitting 3 wide on the Livermore Porsche New Years drive. I'll be sad when Mikayla and Nolan get to big too sit this way. Even with little sleep last night, we still had a blast. Yeah, maybe a Panamera is in your future (IMG:style_emoticons/default/shades.gif) |
ericoneal |
Jan 1 2016, 08:41 PM
Member Group: Members Posts: 320 Joined: 13-August 12 From: Crestwood, KY Member No.: 14,795 Region Association: South East States |
oakpark |
Jan 1 2016, 09:11 PM
Oak Park 914 Group: Members Posts: 47 Joined: 6-December 04 From: Oak Park, IL Member No.: 3,236 Region Association: Upper MidWest |
December 26 went for a drive along the Coast... Cool 62 degrees, clear and sunny. Car seems happy after adjusting the valves, rebuilt TB, and new Bursch muffler and SSi's. I'm very jealous. Mine is zipped up in its storage bag for the winter (Chicago) and I'll see it by the middle of March. Very nice looking car. |
Lo-Fi Version | Time is now: 20th December 2024 - 10:48 PM |
