what did you do to your 914 today |
cary |
Apr 23 2016, 09:35 PM
I'm finally in a position where I could take a Saturday an attend the Rally America, Oregon Trail Rally. So at 7am I head to Goldendale, Washington. I make a quick stop at the Parc Ferme in The Dalles at 9am. Here's a shot of our local Hoosier race tire service owner Garth Ankeny's new car.
I was pleasantly surprised at the amount of folks at Spectator Area #1. My motorsports career started in SCCA Pro Rally in the late seventies. Nothing to exciting, service member and car builder. But back then it was just us participants. I arrived at Area #2 a little too late. Lesson learned for next year. The walk in was about a mile downhill. All my phone pictures were pretty crappy. Here's a shot of Garth and David Higgins last years winner. At the end of the day I covered 354 miles in my 73 appearance group DD. For some reason the fuse to radio blew after crossing the Sandy River at Troutdale. Come find out I had the radio tied to the 7.5 amp #2 fuse. Oh yeah, this was a solo trip so all I had for entertainment was the hum of my self built 2056. What a beautiful thing. Stats: Averaged 70-80 mph Oil pressure 60 psi 195 degrees 36.7 mpg (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/cheer.gif) Before WCR projects: Reset rear braking venting Bleed brakes and or adjust brake push rod Tires rebalanced, bad spot 63-67 mph Move shift rod back just a smidgen, need a little deeper shift into 1st. |
Larmo63 |
Apr 23 2016, 11:22 PM
Advanced Member Group: Members Posts: 4,267 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California |
I dropped the 2.0 /4 motor yesterday afternoon, I think it took about an hour and a half. Split the motor trans today, and finally made up my mind to go /6 power.
I will be selling the GA motor complete with FI. Great motor, excellent compression, but a rod bearing or main bearing let go. I can make a good deal to someone who is looking for an early 2.0 /4 GA block engine. Shouldn't be too hard to fix. I'm onto my six build, which is where I wanted to end up anyway. (IMG:style_emoticons/default/driving.gif) |
porschetub |
Apr 23 2016, 11:32 PM
Advanced Member Group: Members Posts: 4,764 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
I dropped the 2.0 /4 motor yesterday afternoon, I think it took about an hour and a half. Split the motor trans today, and finally made up my mind to go /6 power. I will be selling the GA motor complete with FI. Great motor, excellent compression, but a rod bearing or main bearing let go. I can make a good deal to someone who is looking for an early 2.0 /4 GA block engine. Shouldn't be too hard to fix. I'm onto my six build, which is where I wanted to end up anyway. (IMG:style_emoticons/default/driving.gif) thought you sold your six parts,whatever go for it (IMG:style_emoticons/default/smile.gif) |
cary |
Apr 24 2016, 04:32 PM
At the end of the day I covered 354 miles in my 73 appearance group DD. For some reason the fuse to radio blew after crossing the Sandy River at Troutdale. Come find out I had the radio tied to the 7.5 amp #2 fuse. Oh yeah, this was a solo trip so all I had for entertainment was the hum of my self built 2056. What a beautiful thing. Before WCR projects: Tires rebalanced, bad spot 63-67 mph |
Larmo63 |
Apr 24 2016, 05:04 PM
I dropped the 2.0 /4 motor yesterday afternoon, I think it took about an hour and a half. Split the motor trans today, and finally made up my mind to go /6 power. I will be selling the GA motor complete with FI. Great motor, excellent compression, but a rod bearing or main bearing let go. I can make a good deal to someone who is looking for an early 2.0 /4 GA block engine. Shouldn't be too hard to fix. I'm onto my six build, which is where I wanted to end up anyway. (IMG:style_emoticons/default/driving.gif) thought you sold your six parts,whatever go for it (IMG:style_emoticons/default/smile.gif) I sold the pull clutch transmission, I'm building the '69 911E block into a twin plug 2.0. |
Chris914n6 |
Apr 24 2016, 05:34 PM
Jackstands are my life. Group: Members Posts: 3,431 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
db9146 |
Apr 24 2016, 07:36 PM
Senior Member Group: Members Posts: 953 Joined: 21-December 04 From: Atlanta, GA Member No.: 3,315 Region Association: None |
I added the 3 meter version of BlazeCut for an added measure of protection besides carrying a halon extinguisher. I added some 3/16" rubber padding to the BlazeCut anywhere it touches metal to add some protection against any vibration damage to the BlazeCut tubing and then anchored it securely using zip ties (since I didn't want to drill any holes).
Mike Bellis |
Apr 24 2016, 07:46 PM
Resident Electrician Group: Members Posts: 8,347 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
I drove it... (IMG:style_emoticons/default/driving.gif)
Then I hooked up my flat tow setup and dragged it around the neighborhood... Tows good but I wish I didn't have locking steering. At least I have a battery cutoff switch. (IMG:style_emoticons/default/smile.gif) |
ThinAir |
Apr 24 2016, 08:33 PM
Best friends Group: Members Posts: 2,555 Joined: 4-February 03 From: Flagstaff, AZ Member No.: 231 Region Association: Southwest Region |
Engine and transmission got reinstalled in the car today. Installed the front turn signal buckets too. Still lots of work before it's back on the road, but I'm getting close!
Gunn1 |
Apr 24 2016, 09:04 PM
Senior Member Group: Members Posts: 1,021 Joined: 14-February 16 From: Minnesota Member No.: 19,670 Region Association: None |
Continued disassembling the first of four cars. Cleaning and taking inventory as I go.
The intent is to make two cars out of the four. Thanks |
lonewolfe |
Apr 24 2016, 09:05 PM
Senior Member Group: Members Posts: 819 Joined: 12-September 11 From: Oakland, CA Member No.: 13,549 Region Association: Northern California |
I added the 3 meter version of BlazeCut for an added measure of protection besides carrying a halon extinguisher. I added some 3/16" rubber padding to the BlazeCut anywhere it touches metal to add some protection against any vibration damage to the BlazeCut tubing and then anchored it securely using zip ties (since I didn't want to drill any holes). Looks like a wise move. What name is the 3M product? Where can one buy it? |
76-914 |
Apr 25 2016, 09:44 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,655 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Cleaned and polished my Fuch's. (IMG:style_emoticons/default/FERG.gif)
JFG |
Apr 25 2016, 12:58 PM
Senior Member Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None |
continued the strip down today. Just about ready to take it outside to jet wash the dirt off the internals (except the cab section) so that i can see if there is any welding needed before getting those areas painted. Then the engine/box can go back in and it's off to the paint shop!!
ndfrigi |
Apr 27 2016, 10:04 AM
Advanced Member Group: Members Posts: 2,960 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
DRPHIL914 |
Apr 27 2016, 11:03 AM
Dr. Phil Group: Members Posts: 5,811 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
replaced an injector after isolating an intermittent short at #1,
drove to work, ran perfect- appears the injector, not the harness is ithe issue. will keep test driving just to make sure, ... (IMG:style_emoticons/default/driving.gif) |
Apr 27 2016, 11:17 AM
Resident German Group: Admin Posts: 41,973 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Kansas 914 |
Apr 27 2016, 03:28 PM
I just finished detailing the '75 just to drive in the rain for 3 days... (IMG:style_emoticons/default/screwy.gif)
It will be worth it just to get together at Route 66 Classic starting in Flagstaff, AZ and ending up in Prescott, AZ. |
Larmo63 |
Apr 27 2016, 04:01 PM
Apr 27 2016, 04:44 PM
snakemain |
Apr 29 2016, 09:35 PM
Ronin Member Group: Members Posts: 581 Joined: 14-January 10 From: Aviano, Italy Member No.: 11,232 Region Association: None |
I investigated the reason why I seem to only be running on 75% power. I may have found at least part of the problem.
Unfortunately, it's now at about 85% power under load. Wondering if it's a carb issue or something more serious. It pulled like a tractor until it all of a sudden started having problems. |
Lo-Fi Version | Time is now: 16th January 2025 - 03:57 PM |
