what did you do to your 914 today |
falcor75 |
Jul 11 2016, 05:52 AM
Senior Member Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia |
I checked where my 914 was at the moment. It is on its way ! About 2-3 more weeks before I can see it with my own eyes .... Whooohoo, hurry up little boat! I waxed mine for the first time ever in my possession and I've owned it since 2013... (IMG:style_emoticons/default/WTF.gif) |
Cuda911 |
Jul 14 2016, 12:05 AM
Senior Member Group: Members Posts: 1,489 Joined: 20-May 14 From: Oceanside (N. San Diego County), CA Member No.: 17,376 Region Association: Southern California |
Noticed a spot under the car.... gasoline smell. Took the car in to MRD Racing (Vista, CA), and they found a leaking fuel line, up front at the access port. Got it fixed, fortunately didn't go up in flames.
Attached thumbnail(s) |
SKL1 |
Jul 14 2016, 12:59 PM
Senior Member Group: Members Posts: 1,652 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest |
Cuda, I assume you have an extinguisher in the car. NEVER go without one! Many years ago I was starting my car in Porsche Park at Road America and it wouldn't start and had a MAJOR gas smell. One of the fuel lines had come loose. Thank God no one was smoking nearby, but I got a Halon extinguisher right after that and have never not had one in any of our vehicles.
Cheap insurance!!! |
76-914 |
Jul 14 2016, 01:59 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,654 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Cuda, I assume you have an extinguisher in the car. NEVER go without one! Many years ago I was starting my car in Porsche Park at Road America and it wouldn't start and had a MAJOR gas smell. One of the fuel lines had come loose. Thank God no one was smoking nearby, but I got a Halon extinguisher right after that and have never not had one in any of our vehicles. Cheap insurance!!! Good advice The only time I've used mine was on a flaming VW pulled to the side of the road. Some poor guy was yanking off burning parts when I arrived. It was out in less than 8 seconds. Also, read the instructions before using. Most people don't realize there is a correct way to use one. (IMG:style_emoticons/default/beerchug.gif) |
914_teener |
Jul 15 2016, 03:30 PM
914 Guru Group: Members Posts: 5,250 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Got my new drop link arms from Bruce Stone and drove the car today!
To much pre load so I'm gonna put the adjustable arms on and see how it feels. Pics to follow. |
euro911 |
Jul 15 2016, 05:03 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,860 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
Noticed a spot under the car.... gasoline smell. Took the car in to MRD Racing (Vista, CA), and they found a leaking fuel line, up front at the access port. Got it fixed, fortunately didn't go up in flames. Hopefully they replaced all of the hoses in the system with SAE-30R9 (or better) hoses.(IMG:style_emoticons/default/confused24.gif) |
riccorman |
Jul 16 2016, 04:37 AM
Newbie Group: Members Posts: 4 Joined: 22-September 15 From: Oklahoma City USA Member No.: 19,189 Region Association: Southwest Region |
New passenger side mirror
Dion |
Jul 16 2016, 08:27 PM
RN Group: Members Posts: 2,807 Joined: 16-September 04 From: Audubon,PA Member No.: 2,766 Region Association: MidAtlantic Region |
Worked on the Zeniths. All new gaskets. One down one to go...
Dion |
Jul 16 2016, 08:28 PM
Zenith Driverside done.
jeffdon |
Jul 16 2016, 09:41 PM
Got under it and cranked down on my heat echanger bolts. Improved, but a little leaky I think still. Also rigged up some tubing and forced some lube into my new throttle cable. Some folks think its a bad idea, but i went for it. Film at 11.
Mueller |
Jul 16 2016, 10:37 PM
914 Freak! Group: Members Posts: 17,150 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None |
No work on it directly, I started to put together my new mill to make some parts for it!
Top portion weighs 1100+ pounds, base is 500+ pounds. I still need to attach the 10 tool ATC and the power drawbar. |
Mueller |
Jul 16 2016, 10:38 PM
euro911 |
Jul 17 2016, 12:19 AM
No work on it directly, I started to put together my new mill to make some parts for it! ... (IMG:style_emoticons/default/drooley.gif)Top portion weighs 1100+ pounds, base is 500+ pounds. I still need to attach the 10 tool ATC and the power drawbar. |
carr914 |
Jul 17 2016, 05:35 AM
Racer from Birth Group: Members Posts: 122,978 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
Brought her home for the 1st time in 2 years
A&P Mech |
Jul 17 2016, 07:26 AM
Member Group: Members Posts: 401 Joined: 10-September 13 From: United States Member No.: 16,371 Region Association: Rocky Mountains |
No work on it directly, I started to put together my new mill to make some parts for it! Top portion weighs 1100+ pounds, base is 500+ pounds. I still need to attach the 10 tool ATC and the power drawbar. OK Mueller, I am jealous! I have been lusting for a Tormach for years. I can't wait to see the cool parts that will come off that machine. I would love to have a tool changer on my Mill. |
cali914 |
Jul 17 2016, 08:02 AM
cali914 Group: Members Posts: 456 Joined: 26-April 06 From: Berkeley Ca. Member No.: 5,934 Region Association: Northern California |
Worked on my front headlight aesthetics. I tried to drill and cut the yellow lenses
Mueller |
Jul 17 2016, 11:09 AM
No work on it directly, I started to put together my new mill to make some parts for it! Top portion weighs 1100+ pounds, base is 500+ pounds. I still need to attach the 10 tool ATC and the power drawbar. OK Mueller, I am jealous! I have been lusting for a Tormach for years. I can't wait to see the cool parts that will come off that machine. I would love to have a tool changer on my Mill. (IMG:style_emoticons/default/smile.gif) I'm getting this for it as well: https://www.youtube.com/watch?v=TlQgMk6te_Y |
Mike Bellis |
Jul 17 2016, 11:32 AM
Resident Electrician Group: Members Posts: 8,347 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
I lost a fuel pump in the middle of nowhere... At least I had limited cell service, no calls but I could text and surf the web. The PCA guys stopped and were able to drive ahead to call my wife for rescue. I had set her up with tow bar and gear before I left on the cruise. Took her two hours to get out to me and another two hours to get home... I brought my laptop and diagnostic tools with me so troubleshooting was easy, repair was impossible... Now I need a fuel pump.
Luckily I had plenty of water... (IMG:style_emoticons/default/barf.gif) |
rhodyguy |
Jul 17 2016, 11:49 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,207 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Mike (muller), you ever give any thought to making the 4 lug hubs that accomidate the vented rotors again?
VegasRacer |
Jul 17 2016, 11:54 AM
ELVIRA Group: Benefactors Posts: 8,709 Joined: 27-March 03 From: Between Scylla and Charybdis Member No.: 481 Region Association: None |
I noticed that the passenger side sun visor was hanging a bit low. I got out my trusty stubby phillips and tightened the set screw.
I am pleased to report that after a 45 min test drive including full throttle acceleration, threshold breaking and as many 1 g corners I could find, just like an airplane tray table on Viagra, the previously drooping visor remained in it's full upright position. |
Lo-Fi Version | Time is now: 15th January 2025 - 03:33 PM |
