what did you do to your 914 today |
Steve |
Sep 26 2016, 07:06 AM
914 Guru Group: Members Posts: 5,780 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
Nope. different bellcrank.... (IMG:style_emoticons/default/sheeplove.gif) (IMG:style_emoticons/default/beerchug.gif) I would just buy the rich Johnson kit. It's also easy to fabricate an "L" bracket and use the stock cable. The difference is that the stock cable will come into the engine compartment at an odd angle which will make the pedal slightly harder to push. |
Chaznaster |
Sep 26 2016, 12:03 PM
Member Group: Members Posts: 325 Joined: 22-November 15 From: Concord, MA Member No.: 19,389 Region Association: North East States |
87m491 |
Sep 26 2016, 03:21 PM
Member Group: Members Posts: 327 Joined: 29-July 12 From: Portland, the original! Member No.: 14,731 Region Association: North East States |
Were the calipers that clean to start with or did you spruce them up as well?
Pulled right front caliper, blew out the pistons with air (per Haynes - what a simple solution) and rebuilt the unit. Clips that stop the pistons from rotating were missing from both front calipers and got those at 20deg. One more caliper to go then new brake pads ... |
Chaznaster |
Sep 27 2016, 07:37 AM
They were in solid shape but rusty. The brake fluid that spilled all over them as I was working on them seems to have improved their look!
Were the calipers that clean to start with or did you spruce them up as well? Pulled right front caliper, blew out the pistons with air (per Haynes - what a simple solution) and rebuilt the unit. Clips that stop the pistons from rotating were missing from both front calipers and got those at 20deg. One more caliper to go then new brake pads ... |
jd74914 |
Sep 27 2016, 07:47 AM
Its alive Group: Members Posts: 4,823 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
SKL1 |
Sep 27 2016, 05:46 PM
Senior Member Group: Members Posts: 1,652 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest |
mgp4591 |
Sep 27 2016, 09:21 PM
914 Guru Group: Members Posts: 5,529 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region |
Uh, I'll gladly take that 65 GTO convertible off someones hands.... (IMG:style_emoticons/default/drooley.gif) (IMG:style_emoticons/default/wub.gif)
Michael N |
Sep 28 2016, 08:05 AM
Certifiable Group: Members Posts: 1,426 Joined: 6-June 04 From: San Jose, Ca Member No.: 2,164 Region Association: Northern California |
76-914 |
Sep 28 2016, 09:00 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,654 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I confirmed that the headers I bought from Larmo yesterday would fit my heads and studs for my 3.0SC motor (verses a corvair trick) and then I went to the shop and sand blasted them prior to ceramic coating. After missing out on a bid for the 914-6 lower linkage yesterday, it occurred to me that if the bellcrank is a duplicate of the 911 upper linkage bellcrank (and it looks like it might be) this is a part-set that could easily be fabricated and sold at half the going rate. Research underway... Your letting others do the work? (IMG:style_emoticons/default/huh.gif) |
Larmo63 |
Sep 28 2016, 09:15 AM
Advanced Member Group: Members Posts: 4,267 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California |
Sold the white '73 and my 2.7 motor arrived. My wallet is a lot lighter from the Patrick Motorsports order. Who said a /6 conversion was cheap/easy?
No one. |
SKL1 |
Sep 29 2016, 04:14 PM
keely444 |
Sep 29 2016, 04:35 PM
Member Group: Members Posts: 103 Joined: 4-May 15 From: santa cruz Member No.: 18,702 Region Association: None |
SKL1 |
Sep 29 2016, 06:37 PM
Thanks. Almost as sentimental as my '71. One of my best friends owned it from 1974- we used to autocross together and went to many races at Road America in it or my car.
He died of a rare illness in the early 2000's and his widow said he wanted me to have it. He hadn't driven it for neary 12 years and it needed a total restoration. It's now better than new and a nice tribute to him- I think of him and all the fun we had over the years every time I drive it! |
keely444 |
Sep 29 2016, 07:08 PM
Great to keep his memory alive. Makes it even more special. Again it is one of the nicest looking 914 I have seen.
JustinMeier |
Sep 29 2016, 07:45 PM
Member Group: Members Posts: 244 Joined: 3-August 16 From: Scottsdale Member No.: 20,258 Region Association: None |
Gorgeous cars! I'll have to keep an eye out for you.
If you see a dark grey 914 around North Scottsdale, honk (IMG:style_emoticons/default/smile.gif) |
JustinMeier |
Sep 29 2016, 07:46 PM
Great to keep his memory alive. Makes it even more special. Again it is one of the nicest looking 914 I have seen. Exactly why I want to keep Dad's car around. (IMG:style_emoticons/default/beerchug.gif) |
SKL1 |
Sep 29 2016, 09:55 PM
Actually I saw a darker colour 914 going north on north Pima a couple days ago- may have been you! I was in our white Q5 though...
BTW, my dad got his bahia red '71 914 six months after I got mine way back when. Wish we'd kept that in the family! |
SKL1 |
Sep 29 2016, 10:00 PM
cali914 |
Sep 29 2016, 10:49 PM
cali914 Group: Members Posts: 456 Joined: 26-April 06 From: Berkeley Ca. Member No.: 5,934 Region Association: Northern California |
kkid |
Sep 30 2016, 07:00 PM
Member Group: Members Posts: 343 Joined: 18-December 07 From: Oakland, CA Member No.: 8,483 Region Association: Northern California |
Yes, it's a Porsche!
Installed a negative side decal. Will do other side tomorrow. Thanks Mikey for the stickers. It's easier to handle this one than the one from ebay. kkid (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 15th January 2025 - 12:10 AM |
