what did you do to your 914 today |
StratPlayer |
Nov 26 2016, 02:53 PM
StratPlayer Group: Members Posts: 3,305 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains |
Put it away for the winter.....
kid914 |
Nov 26 2016, 03:01 PM
ALWAYS lead...NEVER follow!!!! Group: Members Posts: 2,534 Joined: 9-March 11 From: Canada Member No.: 12,811 Region Association: Canada |
Ditto.. took battery out. (IMG:style_emoticons/default/hissyfit.gif)
sb914 |
Nov 26 2016, 03:40 PM
Surf Guru Group: Members Posts: 4,418 Joined: 25-November 12 From: Brookings,Oregon Member No.: 15,191 Region Association: Southern California |
I drove it (IMG:style_emoticons/default/smile.gif)
forrestkhaag |
Nov 26 2016, 07:01 PM
Nice one Eddy! I drove over to Arizona to the Grand Canyon to test out my carb tuning / got the jets right and wound it up on the open freeway. Cant beat this time of year in a heat-delete 914!!
The semi-dirt road in a pic or two parallels the I-10 out in western AZ/ Eastern Cali. Cheers Sidebar: I picked up four fuked fuchs in AZ and took them to the shop in SoCal this morning / bead blasted both sides, masked and painted one to see if this is the wheel look for the 3.0 GT styled car I am working on. Who Knows..... (IMG:style_emoticons/default/confused24.gif) Attached image(s) |
Cairo94507 |
Nov 26 2016, 10:44 PM
Michael Group: Members Posts: 10,168 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
That wheel looks very nice. (IMG:style_emoticons/default/smilie_pokal.gif)
stugray |
Nov 27 2016, 01:00 AM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
I thought: I should clean the top of the engine off.
Then, this would be easier if I dropped the engine, then those tins are in the way. Did I go too far? (IMG:http://www.914world.com/bbs2/uploads_offsite/i366.photobucket.com-10819-1480230017.1.jpg) Thought this shot was cool: (IMG:http://www.914world.com/bbs2/uploads_offsite/i366.photobucket.com-10819-1480230017.2.jpg) While the heads are off I am getting a valve job, new exhaust valves (old sodium filled were giving up) and dual springs. Now I can bump up the rev limiter to 6500-6800. |
lonewolfe |
Nov 27 2016, 02:57 PM
Senior Member Group: Members Posts: 819 Joined: 12-September 11 From: Oakland, CA Member No.: 13,549 Region Association: Northern California |
I thought: I should clean the top of the engine off. Then, this would be easier if I dropped the engine, then those tins are in the way. Did I go too far? Thought this shot was cool: While the heads are off I am getting a valve job, new exhaust valves (old sodium filled were giving up) and dual springs. Now I can bump up the rev limiter to 6500-6800. What size engine is this and what cam are you running? |
stugray |
Nov 27 2016, 06:04 PM
I thought: I should clean the top of the engine off. Then, this would be easier if I dropped the engine, then those tins are in the way. Did I go too far? Thought this shot was cool: While the heads are off I am getting a valve job, new exhaust valves (old sodium filled were giving up) and dual springs. Now I can bump up the rev limiter to 6500-6800. What size engine is this and what cam are you running? It's a 2.0L (2056) with a webcam 86b. I decided to break it down after ~2 race seasons. Other than a low compression test and questionable exhaust valves, it looked like brand new inside. Even with no headgaskets, 9.2:1 CR and revving the shit out of it (I had it to 7k a couple times accidentally before I got a rev limiter) , I saw no evidence of head leaks. |
warpig |
Nov 27 2016, 07:12 PM
Member Group: Members Posts: 290 Joined: 2-August 10 From: Portland OR Member No.: 12,002 Region Association: Pacific Northwest |
Been over at Carey's shop the last couple of weekends, getting it roadworthy.
Carey and the SuperInLaw are crazy knowledgeable and accommodating. I wouldn't attempt do all this without their expertise and guidance. Thanks guys you rock!! (IMG:style_emoticons/default/aktion035.gif) Already pulled the motor and transmission last week. And this weekend found NO RUST under the rockers!!!! (IMG:style_emoticons/default/piratenanner.gif) Just a lot of dirt. (IMG:style_emoticons/default/smile.gif) Found lots of it under the battery tray though (IMG:style_emoticons/default/barf.gif) Passenger floor pan and outer firewall needs addressing as well. (IMG:style_emoticons/default/hissyfit.gif) Got to work with the cut off wheel (IMG:style_emoticons/default/sawzall-smiley.gif) and made a nice order for Restoration Design and Pelican. Should be here next week Already had the braided brake lines in the stash. (IMG:style_emoticons/default/biggrin.gif) Next job is to repack the CV's and new seals in the leaky engine and transmission. (IMG:style_emoticons/default/cheer.gif) And lots of cleaning. (IMG:style_emoticons/default/dry.gif) |
warpig |
Nov 27 2016, 07:13 PM
double post (IMG:style_emoticons/default/WTF.gif)
JFG |
Nov 28 2016, 03:02 PM
Senior Member Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None |
Tried to repair a paint reaction on the rear bumper. It's a small area approx 2" square at the most.
Rubbed it down. Panel wipe, primer and it reacted again. Rubbed it down again. Water wiped and primed again. Same reaction. Rubbed it down again. Dry wiped with dry tissue and yet again it reacted but slightly different. Have walked away for tonight. Tomorrow i'll speak to a paint guy and show him the pics. Also put the roof latches in a bowl of coke to work it's magic on the rust. |
forrestkhaag |
Nov 28 2016, 04:23 PM
Now i'm on the fence as to finish//// the all pecan hull blasted look has an appeal to me in that they are super easy to take care of - simply reshoot w/ tire on to get back to the look of the left hand wheel. The one on the right in the photo is how I received them.... Then again , i may go with all black centers and blasted rings / the GT's apparently had no standard finish but very little chrome if any on their wheels in the old days.... (IMG:style_emoticons/default/confused24.gif)
Attached thumbnail(s) |
turk22 |
Nov 28 2016, 10:19 PM
Treetop Flyer Group: Members Posts: 735 Joined: 27-July 12 From: Cincinnati OH Member No.: 14,725 Region Association: Upper MidWest |
cary |
Nov 28 2016, 10:41 PM
Took the day off from Rothsport and headed out to North Portland to pickup my hot water pressure washer. I took it in for a once over.
She now works like she was brand new. It was then time to cut the embedded, cooked and cracked on grease off Mikes engine and tranny. Victim #1 Victim #2 It even blasted off the undercoating on the tranny. |
lonewolfe |
Nov 28 2016, 10:59 PM
Now i'm on the fence as to finish//// the all pecan hull blasted look has an appeal to me in that they are super easy to take care of - simply reshoot w/ tire on to get back to the look of the left hand wheel. The one on the right in the photo is how I received them.... Then again , i may go with all black centers and blasted rings / the GT's apparently had no standard finish but very little chrome if any on their wheels in the old days.... (IMG:style_emoticons/default/confused24.gif) I really like the look of the blasted wheel. Why did you use walnut shells instead of glass beads? I know there's a good reason. I always thought the walnut shells were for removing paint from metal panels but what do I know? |
Mueller |
Nov 28 2016, 11:05 PM
914 Freak! Group: Members Posts: 17,150 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None |
Played with my new 40watt Chinese import laser cutter/engraver.
1st test part on anodized aluminum tonight. Not perfect, but it was my 1st time playing with an EPS file and Corel Draw (student/home version) Also laser etched some hardboard with the 4 lug modular wheel center I drew a few months back. About 4" in diameter. I like the crisp lines on the anodized part (scrap part laying around) |
warpig |
Nov 28 2016, 11:27 PM
Took the day off from Rothsport and headed out to North Portland to pickup my hot water pressure washer. I took it in for a once over. She now works like she was brand new. It was then time to cut the embedded, cooked and cracked on grease off Mikes engine and tranny. Victim #1 Victim #2 It even blasted off the undercoating on the tranny. WOW!!! SHINEY (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/w00t.gif) |
mgp4591 |
Nov 29 2016, 12:01 AM
914 Guru Group: Members Posts: 5,528 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region |
Played with my new 40watt Chinese import laser cutter/engraver. 1st test part on anodized aluminum tonight. Not perfect, but it was my 1st time playing with an EPS file and Corel Draw (student/home version) Also laser etched some hardboard with the 4 lug modular wheel center I drew a few months back. About 4" in diameter. I like the crisp lines on the anodized part (scrap part laying around) Looks like a great design for a Fuchs replica bottle opener or key fob thingy?? (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/popcorn[1].gif) |
Spoke |
Nov 29 2016, 09:08 AM
Jerry Group: Members Posts: 7,116 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Installed one of CFR Racing's catch can. Excellent quality and a perfect fit. Instead of a filter exhausting to outside air (and back into the cabin for heat (IMG:style_emoticons/default/dry.gif) ), the bypass air is directed back into the intake.
euro911 |
Nov 30 2016, 12:48 AM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,860 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
Took the day off from Rothsport and headed out to North Portland to pickup my hot water pressure washer. I took it in for a once over. That has to be the greasiest engine and trans I've ever seen (IMG:style_emoticons/default/yikes.gif)She now works like she was brand new. It was then time to cut the embedded, cooked and cracked on grease off Mikes engine and tranny. Victim #1 Victim #2 It even blasted off the undercoating on the tranny. Good job on the clean up (IMG:style_emoticons/default/aktion035.gif) |
Lo-Fi Version | Time is now: 13th January 2025 - 01:53 AM |
