what did you do to your 914 today |
sixaddict |
Mar 11 2017, 05:29 PM
Senior Member Group: Members Posts: 870 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States |
Lets see...drove to track last night ...Got 3 1/2 laps before pressure plate or clutch failed making this 0 for 2 at track events...Was just apart for LSD install so not so much fun .....Tires were not even hot (IMG:style_emoticons/default/headbang.gif)
keely444 |
Mar 11 2017, 06:32 PM
Member Group: Members Posts: 103 Joined: 4-May 15 From: santa cruz Member No.: 18,702 Region Association: None |
jim_hoyland |
Mar 11 2017, 06:45 PM
Get that VIN ? Group: Members Posts: 9,575 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Replaced thermostat with new one from Awsome Powdercoat. Now, the cooling system works as it should and the engine warms up much faster. You can see that old leaking thermostat failed in the fully open position. New t-stat below. Are those two slightly different; top one has 10 chambers and bottom one appears to have 12 ? |
drem914 |
Mar 11 2017, 08:02 PM
Senior Member Group: Members Posts: 1,051 Joined: 16-May 08 From: Trabuco Canyon, CA Member No.: 9,062 Region Association: Southern California |
De-greased 42 years of oil, road dirt and grime from my SS heat exchangers, while the engine is out of the car. Didn't know they were stainless. Who knew they were so shiny when clean. (IMG:style_emoticons/default/biggrin.gif)
simonjb |
Mar 12 2017, 05:16 PM
KiwiMan Group: Members Posts: 563 Joined: 18-October 16 From: Stamford, Connecticut Member No.: 20,505 Region Association: North East States |
clapeza |
Mar 12 2017, 06:59 PM
Member Group: Members Posts: 229 Joined: 7-February 11 From: South GA Member No.: 12,677 Region Association: South East States |
Got the fuel tank back in the car after putting in Racer Chris's stainless fuel lines!
Tunnel lines connected to tank! |
SKL1 |
Mar 13 2017, 06:42 PM
Senior Member Group: Members Posts: 1,649 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest |
forrestkhaag |
Mar 13 2017, 06:44 PM
No turning back / I just ground off the motor mounts for the type 4 bars / Oil system make-up is this and next week.
The 6 will have sex with the 71 body after months of anticipation in two weeks if all goes well. Just wait Honey.... It will be worth it.... Rt66 is still on the radar and if it starts, runs, and the break-in goes ok as to seating rings, I will drive it balls out to our place in AZ as a summer test of the oil cooling system then join the motley crew in Idyllwild... Lots of moving parts now. Most of them... controllable with enough cash thrown at the solution... And Kent: I am fixin to be done with you smokin my type 4 and all the rest of them on the open road / and I don't care about snapped axles or sheared CV bolts. Bring that problem on. Sidebar: After the complexities of building a 911 carbed and cam-ed motor and cobbling together a respectable conversion, I am going back to what I know and can do in my sleep... I am buying acreage in Scottsdale for another outland home project. Heck. The outcome is a known quantity of fantastic views, weather, and security - unlike Cali now. The profit is guaranteed. And the sleepless nights are not based on BS parts scores in a back alley or swap meet trinkets secured FOR CASH LARMO somewhere. So tomorrow its back to the engine bay and engine mount welding. Attached image(s) |
forrestkhaag |
Mar 13 2017, 06:56 PM
And I helped Keith get his engine into his car this afternoon just prior to buying catfood for my kitty..
euro911 |
Mar 13 2017, 08:38 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,860 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
Ordered some 912 parts (while thinking about 914s), and finished putting the XT back together (while thinking about 914s) (IMG:style_emoticons/default/laugh.gif)
The seat is also back on and the first kick started her up (IMG:style_emoticons/default/mueba.gif) ... Heading up to the Mojave for a few days (IMG:style_emoticons/default/biggrin.gif) |
mark04usa |
Mar 13 2017, 10:32 PM
'70 1.7 Tangerine Group: Members Posts: 352 Joined: 14-September 09 From: Austin TX Member No.: 10,805 Region Association: Southwest Region |
Replaced thermostat with new one from Awsome Powdercoat. Now, the cooling system works as it should and the engine warms up much faster. You can see that old leaking thermostat failed in the fully open position. New t-stat below. Are those two slightly different; top one has 10 chambers and bottom one appears to have 12 ? Jim, It is really just one chamber, different # of "pleats" to the accordion. The thermostat is rated at correct temp for type IV and it works as it should so far... |
SKL1 |
Mar 14 2017, 08:43 PM
forrestkhaag |
Mar 14 2017, 09:14 PM
finished the engine bay clean up and repositioning of the brake valve out of the way for the Rich J. Motor Mount / going in tomorrow.... unless the parts come in from Pelican for sealing the tranny...
(IMG:style_emoticons/default/beerchug.gif) |
euro911 |
Mar 14 2017, 10:47 PM
Mounted the ext oil cooler- Will see if this is enough as I have a fan for it but haven't installed it yet. I know it's hot under there but less plumbing and plenty of space. Stu - looks like your oil lines run pretty much parallel with the head pipes. If you don't see a significant amount of cooling, you could install a heat shield above that section of the pipes, or wrap the pipes, or wrap the oil lines ... just a thought.Should help just getting some oil to circulate out of the engine... |
SKL1 |
Mar 14 2017, 11:15 PM
Good point Mark- I should wrap the lines, but they look so damned nice! (IMG:style_emoticons/default/smile.gif)
(Gonna start it tomorrow and see if I have any leaks !!) |
euro911 |
Mar 15 2017, 07:01 PM
I know what you mean - the whole installation looks nice. Maybe you can get away with wrapping the head pipes then? (IMG:style_emoticons/default/confused24.gif)
Carry on ... |
jim_hoyland |
Mar 15 2017, 07:35 PM
Drilled hole and installed ignition lock - what a mess... (IMG:style_emoticons/default/sad.gif)
Minerva's 914 |
Mar 15 2017, 07:48 PM
Member Group: Members Posts: 378 Joined: 24-December 15 From: Chapel Hill, NC Member No.: 19,489 Region Association: South East States |
Spent about an hour sanding and prepping with 220 grit wet sandpaper my wiper arms for paint. I know, I could have bought new replacements for $40-ish a piece, but it beats watching the tube or listening to political BS plus I enjoyed it
rangrbob |
Mar 16 2017, 03:01 PM
Member Group: Members Posts: 171 Joined: 11-October 12 From: Loveland, CO Member No.: 15,027 Region Association: Rocky Mountains |
Took it and it's big brother out for a couple short drives while the weather was so nice.
SKL1 |
Mar 16 2017, 04:56 PM
Nice long hood- no crest?
Lo-Fi Version | Time is now: 11th January 2025 - 11:29 PM |
