what did you do to your 914 today |
sb914 |
Aug 6 2017, 08:31 PM
Surf Guru Group: Members Posts: 4,418 Joined: 25-November 12 From: Brookings,Oregon Member No.: 15,191 Region Association: Southern California |
clapeza |
Aug 7 2017, 06:34 AM
Member Group: Members Posts: 229 Joined: 7-February 11 From: South GA Member No.: 12,677 Region Association: South East States |
Replaced the bushings on the accelerator pedal, with the pedal cluster still in the car. Nice and smooth now!
The ground strap on the transmission is corroded and my new throttle cable has been acting as a ground. That sucker was getting HOT! As a temporary measure, I ran a battery cable from an engine case bolt to the battery ground stud. Throttle cable is now cool! |
solex |
Aug 7 2017, 06:48 AM
Senior Member Group: Members Posts: 789 Joined: 12-January 05 From: Long Island, NY Member No.: 3,439 Region Association: North East States |
I installed a new directional indicator
I finally fixed my tail lights, the ground wire was in the wrong place and replaced the brake light bulbs with 1157 and also the marker lights with 4 watt bulbs. Not sure if the 1157 will draw too much power. I also adjusted the brake light switch. I no longer have any electrical problems, everything works ;-) I even got rid of the brake light and turn signal indicator oscillation when the brake and left turn signal was engaged. Also the marker lights would also flash... all fixed now Jeff Bowlsby, you should publish a wiring guide of all your hand drawn diagrams, this is how I diagnosed a problem with my tail lights... I diagnosed the problem with my targa top not fitting correctly. I ordered a new rear seal from 914rubber and will need to modify the latches so it pull the back of the targa lower. I also purchased a pair of elevator bolts that will need serious modification to install my fog lamps, I'm making a custom mount, hopefully better than the original. |
stevend914 |
Aug 7 2017, 01:12 PM
Member Group: Members Posts: 377 Joined: 13-December 16 From: Saint Louis Member No.: 20,670 Region Association: Upper MidWest |
Renewed registration for the next two years. Pulled out the radio to replace the fuse.
JFG |
Aug 7 2017, 01:24 PM
Senior Member Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None |
Very nice dash (IMG:style_emoticons/default/sunglasses.gif) I stripped the rear lights and as they were faded dull Grey's and blacks I wrapped the bulb zones in a chrome reflective wrap. Put the old lenses on and with the garage lights off I shone a torch into each section from the outside and they shine nicely now. I couldn't use the light switch properly as the power isn't yet hooked up. Baby steps! And I found two of the new oil seals in the new push rod tubes are weeping oil. 1 on each side! (IMG:style_emoticons/default/headbang.gif) |
arne |
Aug 7 2017, 01:56 PM
Serial Rescuer of old vehicles... Group: Members Posts: 772 Joined: 31-January 17 From: Eugene, Oregon Member No.: 20,799 Region Association: None |
euro911 |
Aug 7 2017, 05:08 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,860 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
Nice ... (IMG:style_emoticons/default/drooley.gif)
RickS |
Aug 7 2017, 10:02 PM
Senior Member Group: Members Posts: 1,408 Joined: 17-April 06 From: 'False City', WA Member No.: 5,880 Region Association: None |
After replacing the dead starter yesterday, took it for an early evening drive with the Mrs along a couple of forested river roads. 86* was just perfect. At times like that it makes all the wrenching and frustration seem so worth it.
7TPorsh |
Aug 8 2017, 10:02 AM
Went (IMG:style_emoticons/default/driving.gif) over the weekend. Decisions, decisions. Went one way on Saturday and the other on Sunday.
914_7T3 |
Aug 8 2017, 11:24 AM
Please forgive me, I'm new to all of this! Group: Members Posts: 1,872 Joined: 3-April 17 From: Los Angeles, CA Member No.: 20,991 Region Association: Southern California |
Went (IMG:style_emoticons/default/driving.gif) over the weekend. Decisions, decisions. Went one way on Saturday and the other on Sunday. That's what I call a "Win Win!" |
Elliot Cannon |
Aug 8 2017, 05:16 PM
I went to start the car today and when I turned the key I didn't hear the fuel pump running. Raised the car up on the lift, turned on the key, slid under the car, tapped the pump with the big screw driver handle and the pump started right up. Ordered a new one about 20 minutes later. (IMG:style_emoticons/default/biggrin.gif) I like it when things go wrong while the car is in the garage. Better than breaking down in the middle of the Mohave Desert. Ask me how I know. (IMG:style_emoticons/default/av-943.gif)
euro911 |
Aug 8 2017, 08:29 PM
Jeffery, 914 7T3 (the teener formerly know as Calvinator2016) stopped by this afternoon to look at a front trunk lid he wanted to purchase ... and to shoot the shit for a while, of course. He's coming back Thursday to help remove that 'choice' lid from the 'BB' and install another lid (that I have stashed away) on the 'BB' (IMG:style_emoticons/default/smile.gif)
Maybe he can help me with the brake bleeding on the 'BB' too? ... if time allows (IMG:style_emoticons/default/happy11.gif) ... then maybe I'll be able to drive the beast to the SoCal Fun Day in Temecula (IMG:style_emoticons/default/unsure.gif) OT: Received a couple shipments of new parts for the '66 912 too ... F & R brake rotors from AZ Autohaus, and a big box of miscellaneous parts (F & R wheel bearings & seals, brake hoses, suspension bushings, body seals, engine gasket set, etc.) from RMeuropean. Upon taking inventory, it appears to be a partial order. Interesting, all items were stated to be in stock when I placed the order though. First time ordering from RM ... good prices, but not too happy with only getting a partial order (IMG:style_emoticons/default/dry.gif) New KONI strut inserts and rear shocks were ordered from Summit, but a rep at KONI said they won't be shipping out to their vendors until the 3rd week in August. No biggie ... I need to repaint the suspension components anyway, so the timing isn't that critical. |
Fatboy007 |
Aug 8 2017, 11:17 PM
Member Group: Members Posts: 62 Joined: 23-May 17 From: San Diego, ca. Member No.: 21,124 Region Association: Southern California |
Fixed door latch on passenger side. Works great. Love my car (IMG:style_emoticons/default/rolleyes.gif)
ndfrigi |
Aug 9 2017, 12:40 AM
Advanced Member Group: Members Posts: 2,960 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
Fixed door latch on passenger side. Works great. Love my car (IMG:style_emoticons/default/rolleyes.gif) Nice! I do missed my garage baby 75 1.8FI too! hehehe |
euro911 |
Aug 9 2017, 01:25 AM
I went to start the car today and when I turned the key I didn't hear the fuel pump running. Raised the car up on the lift, turned on the key, slid under the car, tapped the pump with the big screw driver handle and the pump started right up. Ordered a new one about 20 minutes later. (IMG:style_emoticons/default/biggrin.gif) I like it when things go wrong while the car is in the garage. Better than breaking down in the middle of the Mohave Desert. Ask me how I know. (IMG:style_emoticons/default/av-943.gif) How long has you car been sitting? ... It may just be gummed-up (IMG:style_emoticons/default/confused24.gif) ... Run some solvent through it and keep it as a spare. I'll probably have the same issue shortly ... haven't started the 'BB' since I got back from the 2015 WCR. Will be draining the tank and rebuilding the carbs too. FYI, AA Performance has IDF rebuild kits for $15. ... I recently bought 4 of them :shades https://aapistons.com/collections/carbureto...-carburetor-kit |
7TPorsh |
Aug 9 2017, 09:03 AM
I went to start the car today and when I turned the key I didn't hear the fuel pump running. Raised the car up on the lift, turned on the key, slid under the car, tapped the pump with the big screw driver handle and the pump started right up. Ordered a new one about 20 minutes later. (IMG:style_emoticons/default/biggrin.gif) I like it when things go wrong while the car is in the garage. Better than breaking down in the middle of the Mohave Desert. Ask me how I know. (IMG:style_emoticons/default/av-943.gif) How long has you car been sitting? ... It may just be gummed-up (IMG:style_emoticons/default/confused24.gif) ... Run some solvent through it and keep it as a spare. I'll probably have the same issue shortly ... haven't started the 'BB' since I got back from the 2015 WCR. Will be draining the tank and rebuilding the carbs too. FYI, AA Performance has IDF rebuild kits for $15. ... I recently bought 4 of them :shades https://aapistons.com/collections/carbureto...-carburetor-kit Sold out: I need these! |
ndfrigi |
Aug 9 2017, 10:13 AM
I went to start the car today and when I turned the key I didn't hear the fuel pump running. Raised the car up on the lift, turned on the key, slid under the car, tapped the pump with the big screw driver handle and the pump started right up. Ordered a new one about 20 minutes later. (IMG:style_emoticons/default/biggrin.gif) I like it when things go wrong while the car is in the garage. Better than breaking down in the middle of the Mohave Desert. Ask me how I know. (IMG:style_emoticons/default/av-943.gif) How long has you car been sitting? ... It may just be gummed-up (IMG:style_emoticons/default/confused24.gif) ... Run some solvent through it and keep it as a spare. I'll probably have the same issue shortly ... haven't started the 'BB' since I got back from the 2015 WCR. Will be draining the tank and rebuilding the carbs too. FYI, AA Performance has IDF rebuild kits for $15. ... I recently bought 4 of them :shades https://aapistons.com/collections/carbureto...-carburetor-kit I need 1 set too but again it is sold out. |
Elliot Cannon |
Aug 9 2017, 11:33 AM
I went to start the car today and when I turned the key I didn't hear the fuel pump running. Raised the car up on the lift, turned on the key, slid under the car, tapped the pump with the big screw driver handle and the pump started right up. Ordered a new one about 20 minutes later. (IMG:style_emoticons/default/biggrin.gif) I like it when things go wrong while the car is in the garage. Better than breaking down in the middle of the Mohave Desert. Ask me how I know. (IMG:style_emoticons/default/av-943.gif) How long has you car been sitting? ... It may just be gummed-up (IMG:style_emoticons/default/confused24.gif) ... Run some solvent through it and keep it as a spare. I'll probably have the same issue shortly ... haven't started the 'BB' since I got back from the 2015 WCR. Will be draining the tank and rebuilding the carbs too. FYI, AA Performance has IDF rebuild kits for $15. ... I recently bought 4 of them :shades https://aapistons.com/collections/carbureto...-carburetor-kit I'll try running solvent through the old one and as you suggested, keep it as a spare. Why haven't I heard of AA Performance before? Are they new? (IMG:style_emoticons/default/confused24.gif) Mostly type I stuff? |
euro911 |
Aug 9 2017, 12:03 PM
I'll try running solvent through the old one and as you suggested, keep it as a spare. Why haven't I heard of AA Performance before? Are they new? (IMG:style_emoticons/default/confused24.gif) Mostly type I stuff? Mostly T-1 and T-4, but some 356/912, 911 and wasser-boxer too (IMG:style_emoticons/default/smile.gif) |
Michael N |
Aug 9 2017, 01:51 PM
Certifiable Group: Members Posts: 1,426 Joined: 6-June 04 From: San Jose, Ca Member No.: 2,164 Region Association: Northern California |
Changed the hood springs with the Restoration Designs new hood springs. Lubed the pivot points on the hood. Now the hood opens all the way up and no longer squeaks. I had to place the new springs in the second notch to get them to hold correctly. Great product.
Lo-Fi Version | Time is now: 9th January 2025 - 05:09 PM |
