what did you do to your 914 today |
euro911 |
Sep 23 2017, 04:51 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,860 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
I installed the engine lid seal from 914Rubber. A paint stick helps push it in place when your thumb gets sore. You have to cut it to length and this time I got lucky. I was about 1/4" short when I did this on the '72 some time back. Its better to cut it a bit long and then just trim it little by little. Closing the lid pulls a short section of rubber off the metal seam even tho I have the lid as far to the rear as I can without scratching the trunk lid. I'll leave it for today and check it tomorrow. I may have to somehow trim the rubber. And I just may leave the grill off. Surely it will improve airflow (okayyy...) and it makes it easy to retrieve tools left in the engine bay before blasting off on a test drive. (The more I post the less time I have to spend out in the 97F heat! Its a hot one today.) The grille will more than fill that gap. |
JFG |
Sep 25 2017, 12:40 PM
Senior Member Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None |
I span the engine to check for bangs & leaks and to build oil pressure. So far so good. However when I connected the battery I got a fizz noise from the alternator, brand new alternator!!
Next step. Fit the carbs, add fuel and see what it actually runs like. |
jim_hoyland |
Sep 26 2017, 06:25 AM
Get that VIN ? Group: Members Posts: 9,572 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Installed a used Italian Verona Victoria 360mm steering wheel. Evil bay special!! Great looking wheel ! (IMG:style_emoticons/default/smile.gif) |
Steve |
Sep 26 2017, 07:09 AM
914 Guru Group: Members Posts: 5,771 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
Thanks Jim!! I wanted something stock looking without the screw racy look.
RickS |
Sep 26 2017, 10:01 AM
Senior Member Group: Members Posts: 1,408 Joined: 17-April 06 From: 'False City', WA Member No.: 5,880 Region Association: None |
Ran my car out of gas with the gauge showing 3/4 full. Took 15 gals to fill ‘er up. The gauge then showed full and has been acting normally. Replaced the sender last year. Checking all wiring.
SKL1 |
Sep 26 2017, 08:43 PM
Senior Member Group: Members Posts: 1,647 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest |
Took the '73 for a ride to the local Audi dealer- the oil temp sure likes the cooler temps! Weather lately here in north Scottsdale has been near perfect!
JFG |
Sep 28 2017, 03:18 PM
Forgot to fill the gearbox with oil! Luckily I remembered before starting the engine.
Tried to fix some of the electrical gremlins. Partly succeeded. Figured out my carbs and the vac pipes set up, thanks to advice on here. Also fitted the new firewall bush (friction ring) that I picked up from Porsche parts dept. Need to charge the battery for Saturday. Saturday will be the first time I start the car. |
JFG |
76-914 |
Sep 28 2017, 04:30 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,652 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Forgot to fill the gearbox with oil! Luckily I remembered before starting the engine. Tried to fix some of the electrical gremlins. Partly succeeded. Figured out my carbs and the vac pipes set up, thanks to advice on here. Also fitted the new firewall bush (friction ring) that I picked up from Porsche parts dept. Need to charge the battery for Saturday. Saturday will be the first time I start the car. You would have quickly realized it if you'd run it w/o oil. Sounds like a blender full of marbles. (IMG:style_emoticons/default/beerchug.gif) |
StratPlayer |
Sep 28 2017, 06:34 PM
StratPlayer Group: Members Posts: 3,300 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains |
Had new control arms with elephant racing rubber bushing installed, also had new cv joints intalled.
Cairo94507 |
Sep 28 2017, 09:07 PM
Michael Group: Members Posts: 10,147 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Those are pretty. (IMG:style_emoticons/default/beerchug.gif)
jfort |
Sep 29 2017, 09:40 AM
Senior Member Group: Members Posts: 1,144 Joined: 5-May 03 From: Findlay, OH Member No.: 652 Region Association: Upper MidWest |
took the engine out. for the first time doing it, it went smoothly.
it was missing. turns out there is only 75% compression in cylinder #1 and leaking into carb. Inlet valve, valve guide? it's coming apart on Tuesday with the guidance of a great air-cooled mechanic, Jay Kjoller who thankfully lives close by. |
mgp4591 |
Sep 30 2017, 01:23 AM
914 Guru Group: Members Posts: 5,519 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region |
Got slightly creative because I had a rotted center console and didn't want to run the hoses under the car. This is just mocked up now but things are fitting well and getting something, anything done is a good thing. I should have a roller before the snow falls and just in time to roll in the donor for the winter.
Maltese Falcon |
Sep 30 2017, 10:39 PM
Advanced Member Group: Members Posts: 4,909 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None |
Made a set ( and a few extras) of these laser cut Stainless Steel housing covers, aka Lager-Deckel #914 331 213 00, which attach and hold down the axle- bearing on the trailing arm. Stock is an 11gauge c/r metal stamping. My design is 3/16" thick which will give better bearing protection for HD track work with the big v8 hp on board.
Porschef |
Oct 1 2017, 10:22 AM
How you doin' Group: Members Posts: 2,180 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
JFG |
Oct 1 2017, 10:58 AM
I started the engine for the first time since buying the car in may 2016 (IMG:style_emoticons/default/piratenanner.gif)
Michael N |
Oct 1 2017, 02:36 PM
Certifiable Group: Members Posts: 1,426 Joined: 6-June 04 From: San Jose, Ca Member No.: 2,164 Region Association: Northern California |
The wife hadn't driven her car in 6 months so I thought I would take it out to keep it from entirely drying out and causing leaks etc.
First problem was the battery was dead. I mistakenly unplugged the extention cord attached to battery tender a while back. I charged the battery. Once charged I was going to still take it out on a drive etc. As I was backing out of drive way, my wife asks what was dripping under car. Pulled back in an discovered cracked fuel injector. Luckily I have spares in parts bin. Changed injector and went for a drive up hwy 9 to skyline. Car ran great. Wife has been scolded for not driving car regularly. |
porschetub |
Oct 1 2017, 03:10 PM
Advanced Member Group: Members Posts: 4,763 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Finished building my big 'kick as'' trailer so finally got back to the 914.
Fitted drivers side rocker panel cover with rivets @ the top,so good not having a leak down the rear from the tank suction (IMG:style_emoticons/default/piratenanner.gif) . Started stripping down my Bosch 911E 2.4 "003" dizzy ready for machining down the body to suit my crankcase,it need turning down to 27mm which is standard early 911/T4 and type 1 size. I don't have the use of a lathe so have a mate that will do it for me...very clever machinist (IMG:style_emoticons/default/biggrin.gif) . Lots of small jobs to do and a few majors but most steeps are forward and I really enjoy working on it (IMG:style_emoticons/default/beer.gif) . |
porschetub |
Oct 1 2017, 03:45 PM
took the engine out. for the first time doing it, it went smoothly. it was missing. turns out there is only 75% compression in cylinder #1 and leaking into carb. Inlet valve, valve guide? it's coming apart on Tuesday with the guidance of a great air-cooled mechanic, Jay Kjoller who thankfully lives close by. Are you looking @ a top overhaul @ this stage ? |
michael7810 |
Oct 1 2017, 06:06 PM
Senior Member Group: Members Posts: 1,082 Joined: 6-June 11 From: Scottsdale, AZ Member No.: 13,164 Region Association: Southwest Region |
Fixed a broken oil temp sender wire and got it ready to take to Flagstaff for a week on Tuesday. Used 1/2 quart of oil in 2,700 miles since the last oil change...not bad.
Not my car but helped a friend start his car and break-in the cam. First time it's ran since he bought it 5 years ago. I'll get some pictures next time I see it but he had it painted Bahama yellow and it looks great. Still lots of reassembly and sorting to do but hopefully he will have it ready for Rt 66 -2018. |
Lo-Fi Version | Time is now: 6th January 2025 - 07:22 PM |
