jzdu |
Member ![]() ![]() Group: Members Posts: 69 Joined: 7-July 08 From: Medford, Or Member No.: 9,268 Region Association: Pacific Northwest ![]() |
I've decided to part with my 73. I bought this car in 2007 with a bad paint job and some rust in the hell hole. I tore it down to a roller and had the hell hole repaired with pieces from restoration designs. Also had some rust in the rear trunk, which was repaired using used panels from Camp914. All rockers panels and engine grilles powder coated black. After paint the car sat in may garage for a couple years, as I ran out of money. Finally in 2010 I got going again. New windshield installed with rubber trim moulding. Engine was rebuilt by Dave's Import service here in Southern Oregon. He utilized the original pistons, but replaced all bearings, seals and all intake/exhaust valves. New cam and lifters while he was in there. Dave also did the final hook up of the D-jet and test ran the engine for the first time. He installed a new fuel pump and replaced all rubber fuel & vacuum lines. New flywheel and clutch installed. New SS fuel lines. I had all tin powder coated black and re-installed the engine/trans. Trans was resealed & I replaced all shift bushings. All wheels bearings replaced, CVs repacked and new boots installed, and new front brake pads. Triad muffler. Several weatherstrips and rubber seals have been replaced (too many to list). 5 real Fuchs mounted on 205/50/15 tires. I replaced the engine bay sound pad with a lighter one and added sound deadner to the interior (fire wall & floor). New carpet and reupholtered seats. Cloth down the center of the seats with seat heaters from Camp914. I've purchased several other items like billet wheel center caps, new shift knob, Optima battery, umbrella cover, new door panels, etc. I'm sure I have forgotten to mention some items, but I've got a pile of receipts to look through. 134,000 miles on car, 900 since restoration.
The front heater blower doesn't work. 4 rock chips in hood that I have touched up. Stereo not hooked up and no speakers installed. Bumpers have a few dings & bumper tops are not perfect. The sail panel vinyl I installed is peeling slightly on the passenders side (visable in photo). I've spent approx 14k in restoration, not including the $3800 I paid for the car. I didn't bring it back to completely stock, but close enough that it could be put that way (Triad & seat upholtery). I'm located in Eagle Point Oregon. 50 miles from the California border. $9900 for the car. Let me know if you have questions. Brian (541) 261-4105. Attached image(s) ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
Lo-Fi Version | Time is now: 26th June 2024 - 12:59 AM |
