mrbubblehead |
Twodollardoug ![]() ![]() ![]() Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California ![]() |
so now that you know what its like driving on the progression circuit (no jet stacks) is your hesitation at the end of the progression? befor the mains tip in? if so, open your air jet one more step. if your hesitation is off idle ore when the accelerater is depressed from a steady state, add a turn or two to your squirters. your almost there.....
mrbubblehead |
.45's are awesome for your idles..... you should get really good gas milage during cruise. then should really come alive when you step on it...
Lo-Fi Version | Time is now: 26th June 2024 - 06:21 AM |
