Frame rails re-visited, Shock tower re-inforcement |
SteveSr |
Aug 25 2004, 08:37 AM
Member Group: Members Posts: 203 Joined: 7-October 03 From: Knox,In. Member No.: 1,223 |
one more................
Jeroen |
Aug 25 2004, 08:40 AM
QUOTE(SteveSr @ Aug 25 2004, 04:36 PM) here's what I found..........the shock towers not welded to the frame rail!!!! What was the factory thinking (IMG:style_emoticons/default/confused24.gif) I told you you'd be surprised (IMG:style_emoticons/default/biggrin.gif) Glad you took it out huh? |
SteveSr |
Aug 25 2004, 10:34 AM
Yes! very surprised. Now on to the other side (IMG:style_emoticons/default/sawzall-smiley.gif)
SteveSr (IMG:style_emoticons/default/beer.gif) |
SteveSr |
Aug 31 2004, 10:52 AM
Welded up one side lastnite (IMG:style_emoticons/default/welder.gif) ,now to the other side.........
SteveSr Attached image(s) |
brant |
Aug 31 2004, 12:50 PM
914 Wizard Group: Members Posts: 11,828 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Perhaps Chris or one of the other expert welders will chime in...
I'm certainly not an expert. But I've always understood that over-heating a weld joint will make the metal brittle and more prone to cracking.... Thus, you may want to stitch weld when you do the 2nd side. brant |
SteveSr |
Aug 31 2004, 01:34 PM
(IMG:style_emoticons/default/agree.gif) I'm a toolmaker,certainly not an expert welder, any advice would be helpful.
All though I have been told that there is not enough carbon in mild steel to harden the metal surrounding the weld. (IMG:style_emoticons/default/confused24.gif) SteveSr |
maf914 |
Aug 31 2004, 02:43 PM
Steve and Jeroen,
Thanks for the photos and explanations. I think I might finally understand the weak point you and Brad have been talking about for so long. I don't know if I'm going to strip and reweld my street car though! (IMG:style_emoticons/default/laugh.gif) |
Lo-Fi Version | Time is now: 4th January 2025 - 06:43 PM |
