Front hood scoop |
Front hood scoop |
wingnut86 |
Jan 5 2012, 09:03 PM
...boola la boo boola boo... Group: Members Posts: 1,053 Joined: 22-April 10 From: South Carolina Member No.: 11,645 Region Association: South East States |
Hand made or re-purposed?
Vented Carbon Fiber Louvers...works awesome. (IMG:http://a3.sphotos.ak.fbcdn.net/hphotos-ak-ash2/181041_1538642912578_1430063084_31131848_4143754_n.jpg) (IMG:http://a5.sphotos.ak.fbcdn.net/hphotos-ak-ash2/179487_1538642992580_1430063084_31131849_4365397_n.jpg) -Britain |
Mike Bellis |
Jan 5 2012, 11:48 PM
The first adds a lot of hot air under the car, the second adds a lot of hot air onto the front brakes. The hot air on the brakes at 180-190F is cooler than hot brakes. It can actually act as cooling on the track when you are on the brakes a lot. I think cooling through the fender wells is the most proven cooling design for a street car. |
Britain Smith |
Jan 5 2012, 11:53 PM
Nano Member Group: Members Posts: 2,354 Joined: 27-February 03 From: Hillsboro, OR Member No.: 364 |
I got those vents from here:
http://www.genesisparts.com/index.cfm?tpc=...;action=product They weren't cheap, but serve the purpose. I am not a fan of the air vents in the wheel wells, that is the last place I want air to go at high speed. -Britain |
szuccaro |
Jan 6 2012, 12:01 AM
ZUKE Group: Members Posts: 200 Joined: 27-June 03 From: Cameron Park, CA Member No.: 862 Region Association: Northern California |
Here's my idea... taken from the late model turbo T-bird... Steve
szuccaro |
Jan 6 2012, 12:05 AM
and applied to the side, looks like this.
brant |
Jan 6 2012, 12:10 AM
914 Wizard Group: Members Posts: 11,645 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
do you have a cooler under there?...
szuccaro |
Jan 6 2012, 12:53 AM
Elliot Cannon |
Jan 6 2012, 01:33 AM
It looks like their function is to cause aerodynamic drag. (IMG:style_emoticons/default/happy11.gif) |
Jan 6 2012, 01:39 AM
Resident German Group: Admin Posts: 41,711 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
The first adds a lot of hot air under the car, the second adds a lot of hot air onto the front brakes. The hot air on the brakes at 180-190F is cooler than hot brakes. It can actually act as cooling on the track when you are on the brakes a lot. I think cooling through the fender wells is the most proven cooling design for a street car. Proven by what exactly? I'd rather have fresh air to cool my brakes. (IMG:style_emoticons/default/confused24.gif) |
Stonepilot |
Jan 6 2012, 06:22 AM
Newbie Group: Members Posts: 20 Joined: 6-December 11 From: Pensacola, Florida Member No.: 13,863 Region Association: South East States |
pcar916 |
Jan 6 2012, 08:04 AM
Here's mine. It's illegal in SCCA track events though.
Good luck |
wingnut86 |
Jan 6 2012, 08:10 AM
I looked through the rules previously, but, why do they say no to that design?
are there other in-hood venting designs they say yes to? |
brant |
Jan 6 2012, 09:25 AM
cross post from my street car thread:
Attached thumbnail(s) Attached image(s) |
pcar916 |
Jan 6 2012, 09:41 AM
... why do they say no to that design? are there other in-hood venting designs they say yes to? It wasn't part of the original design of the car, and they consider it an air diverting structure, as if air through a big cooler would add downforce to the front of the car. It also wasn't part of the original design of the car. To be fair it's been years since I looked into it so this is now second hand info to me. Anyone who knows this has changed can chime away. I first evacuated the exhaust under the car but not only did it not cool the oil very well (inlet too small... my design error) but I figured it was simply heating air back to the engine. The 993 engine needs a full-time cooler since engine cooler behind cylinder #6 was deleted. |
Jan 6 2012, 01:14 PM
as if air through a big cooler would add downforce to the front of the car. If i recall correctly, the guy that did all the air flow tests on modified 914 chassis a while back reported a significant increase in downforce with a hood vent. From my armchair physics perspective, that would make sense. (IMG:style_emoticons/default/shades.gif) |
Andyrew |
Jan 6 2012, 01:16 PM
^ I would agree with this as well.
It might not make much of a difference at 60mph, but at 100mph it would probably be fairly noticeable. |
Britain Smith |
Jan 6 2012, 01:21 PM
I have been thru the fight with the SCCA guys on hood venting, what I did with the louvers was the best I could do within the rules for Autocross. There can be no actual ducting underneath either.
-Britain |
Jan 6 2012, 02:29 PM
I have been thru the fight with the SCCA guys on hood venting, what I did with the louvers was the best I could do within the rules for Autocross. There can be no actual ducting underneath either. On that note, one of the 911 guys that runs in the Toyo spec class with PRC here locally showed up with a hood exit vent for his front mounted oil cooler last summer. (Pretty well known guy too) When i asked the officials about the obvious rule violation, i got the following answer: "He's too slow anyways. Once he starts winning, we'll worry about that." Gotta love those guys! (IMG:style_emoticons/default/laugh.gif) |
bulitt |
Jan 6 2012, 03:09 PM
Achtzylinder Group: Members Posts: 4,188 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
MDG |
Jan 6 2012, 03:10 PM
Wolf in wolf's clothing. Group: Members Posts: 8,652 Joined: 3-February 09 From: Toronto Member No.: 10,018 Region Association: None |
Hood scoop from the lastest Ferrari GTO concept on a random pic of a 914
Lo-Fi Version | Time is now: 29th June 2024 - 03:10 AM |
