A brief one car exhibit, 71 3.0 |
computers4kids |
Feb 1 2012, 09:07 AM
Love these little cars! Group: Members Posts: 2,443 Joined: 11-June 05 From: Port Townsend, WA Member No.: 4,253 Region Association: None |
Rick,
Your car looks great. I love the sleek stock look and I be it's a blast when you open it up on the canyons. Way to go (IMG:style_emoticons/default/beerchug.gif) Mark |
RickS |
Feb 1 2012, 01:49 PM
Senior Member Group: Members Posts: 1,408 Joined: 17-April 06 From: 'False City', WA Member No.: 5,880 Region Association: None |
Thanks for the compliments. There are so many beautiful (or soon to be beautiful) cars on this site, it's nice to get the acks.
The quad gauge is from Vintage USA, but it is pretty much a knock off of the GT version. They include the right sender for pressure, just tell them what u are running. Hope to do the PCA AX practice just to help sort it out. Maybe will see some of you there |
JmuRiz |
Feb 1 2012, 02:58 PM
914 Guru Group: Members Posts: 5,487 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
Do you have any special air diverters to get air from the horn grills to the cooler? Or is it just drawn through normally?
It's a really cool cooler setup and not as intrusive as other front cooler setups. I'll either do this or one in the rear under the trunk floor. |
RickS |
Feb 1 2012, 04:40 PM
Do you have any special air diverters to get air from the horn grills to the cooler? Or is it just drawn through normally? The cooler was installed 2 weeks ago with no special ducting to channel the air to the (=======) elongated oval opening cut into the nose of the car in front of the cooler. I am not a fluid dynamics or air flow specialist (nor do I play one on TV) but the thought was that the air will flow from an area of high pressure - the grill areas, to an area of lower pressure - the hole in the floor behind the air dam creating low pressure. So far it is working and maybe too well. Before installing the cooler setup, the car would over heat on the interstate in 5 minutes - now it has a difficult time getting up to proper operating temp - which is probably more a function of the thermostat as well as: a mile of oil lines, 4 additional quarts of oil, and of course the cooler. The proof on the setup and whether ducts from the grills will need to be run to the opening in front of the cooler, or surgery will need to be performed on the air dam/spoiler will be a nice hot 80*+ day, which we won't have up here for months. The exception may be taking her to a DE day and seeing how she does at WOT for 20 mins. Edit: The thought is to take it one step at a time and see if the current solution works. If not, use ducts. If ducts are not sufficient, either cut 4 round holes in the air dam in front of the cooler OR have an air scoop fabbed which will go in the more recessed area of the air dam which will divert the air up and into the gaping oval maw. |
JmuRiz |
Feb 1 2012, 07:11 PM
Very smart, doing stuff in steps makes perfect sense. Maybe an airdam like the one renegade sells would work great...if needed.
Needless to say, I'll be following your progress, as you are a year or so ahead of me. |
TC 914-8 |
Feb 1 2012, 09:05 PM
Senior Member Group: Members Posts: 812 Joined: 23-May 08 From: Sequim, WA Member No.: 9,090 Region Association: Pacific Northwest |
Beautiful Car Rick, I see another COTM coming from the PNW!!! (IMG:style_emoticons/default/first.gif)
Come spring, time the Teener Tuesday will be on Friday-Saturday on the Olympic Pennisula (at my house) I'm waiting for Troy to clear his schedule and coordinate it with the Seattle clan. (IMG:style_emoticons/default/poke.gif) Silver is a great color, you did a fine job!! T |
RickS |
Feb 1 2012, 10:10 PM
Beautiful Car Rick, I see another COM coming from the PNW!!! (IMG:style_emoticons/default/first.gif) Come spring, time the Teener Tuesday will be on Friday-Saturday on the Olympic Pennisula (at my house) I'm waiting for Troy to clear his schedule and coordinate it with the Seattle clan. (IMG:style_emoticons/default/poke.gif) Silver is a great color, you did a fine job!! T Totally cool, once it gets set up I will definitely be there. More than ready to check out the rides. Any one have an e-mail list set up for notifying the locals when and where the next gayla festivity will be held or is it just keep checking the wold's longest thread? Not a bad looking product from Renegade... hmmmmmm |
scooterseattle |
Feb 2 2012, 01:27 AM
Newbie Group: Members Posts: 10 Joined: 18-September 11 From: Austin, TX Member No.: 13,574 Region Association: Southwest Region |
I can attest to the fact that Rick's car is indeed a very fine example of a 914-6 conversion. I congratulate Rick on the final result and give props to Bernie for his mad skills. (IMG:style_emoticons/default/smile.gif)
Cohibra45 |
Feb 2 2012, 09:22 AM
Newbie Group: Members Posts: 34 Joined: 12-January 08 From: Melbourne, Florida Member No.: 8,564 |
Rick,
I see you have 6x16 and 7x16 wheels.....what size tires are you running? Thanks, Kelly |
RickS |
Feb 2 2012, 08:35 PM
Rick, I see you have 6x16 and 7x16 wheels.....what size tires are you running? Thanks, Kelly Actually Kelly they are 15 by 6 and 7. I refinished the 6s to more resemble the paint scheme of the 7s and now people thing they are 16s. Tires are 205/55/15 front and rear. Thanks Scott for the compliments - you know the car all too well. I am sure that when yours is done it will not only meet but well exceed mine with your attention to detail. More new pics: |
Lo-Fi Version | Time is now: 16th September 2024 - 01:11 PM |
