Saturday, 15 March 2025 |
scotty b |
rust free you say ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None ![]() |
Attached image(s) ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
scotty b |
Attached image(s) ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
BajaXJ92 |
Extended Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,146 Joined: 20-April 06 From: Prescott, AZ Member No.: 5,895 Region Association: MidAtlantic Region ![]() |
Mike,
I'll have you know that your car is a slick one! Damn thing kept trying to slip off the trailer on the way back. We had to readjust 2 or 3 times....in the rain. (IMG:style_emoticons/default/headbang.gif) |
MDG |
Wolf in wolf's clothing. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,653 Joined: 3-February 09 From: Toronto Member No.: 10,018 Region Association: None ![]() |
It's always nerve wracking when Scotty is in strip-down mode and he starts using this guy: (IMG:style_emoticons/default/blink.gif)
When he switches to this guy: (IMG:style_emoticons/default/ohmy.gif) . . Don't look. As usual, nice stitching on the flare! Go, Scotty, GO! |
OU8AVW |
Yacht Rigger ![]() ![]() ![]() Group: Members Posts: 1,803 Joined: 1-October 08 From: Granbury, TX Member No.: 9,601 Region Association: Southwest Region ![]() |
I'm speechless.....
scotty b |
mne
Attached image(s) ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
scotty b |
Roll bar was coverd in straight libne scrathches from someone in the past hard blocking it...yet somehow it was still far from straight (IMG:style_emoticons/default/dry.gif) I did all this with only a mudhog and got it flatter and more properly contoured then the p.o. did with a block
Attached image(s) ![]() ![]() ![]() ![]() ![]() |
scotty b |
The plan on Mikes car was to repair the rear 1/4's, smooth the body out a bit more and repaint. Once these bubbles in the hood and trunk were looked into it became clear thet lids needed to be completely stripped. I'm guessing that these are a result of a past chemical stripping that wasn't properly neuitralized (IMG:style_emoticons/default/confused24.gif)
Attached image(s) ![]() ![]() ![]() ![]() |
arkitect |
Senior Member ![]() ![]() ![]() Group: Members Posts: 617 Joined: 3-March 10 From: Stockton, CA Member No.: 11,426 Region Association: None ![]() |
Scotty,
When you replace the rain gutters up front. Do you replace a whole section of the u channel...weld the ends to the exiting? How do you grind it smooth in the channel? Dave |
scotty b |
Scotty, When you replace the rain gutters up front. Do you replace a whole section of the u channel...weld the ends to the exiting? How do you grind it smooth in the channel? Dave Honestly it all depends on the customers budget, how extensive the damage is etc. I've had times where I made a small section from scratch and welded it in, times when I have cut a length out of a donor, and times where the owner didn't have the funds to repair properly so I cleaned it, backed it up with some chrome tape, and wiped J.B. weld over the holes then primed it. As far as grinding down in the channel, the first key is to get a nice flat weld so there is minimal grinding, then there are a variety of ways to get it ground. Flap wheel on a grinder, a 80 grit roloc disc will flex enough to get it done, a die grinder with a tulip cutter etc. I usually cut most of it down with my cut off wheel then clean it up with some other method |
hot_shoe914 |
on ramp passer ![]() ![]() ![]() ![]() Group: Members Posts: 3,806 Joined: 20-November 07 From: Earle, Ar. Member No.: 8,354 Region Association: None ![]() |
OU8AVW |
I am left wondering which category I fit into (IMG:style_emoticons/default/idea.gif)
hot_shoe914 |
I think I am in a category of my own. He just didn't mention it as it is very embarassing. (IMG:style_emoticons/default/post-2-1117899824.gif) |
scotty b |
scotty b |
I think I am in a category of my own. He just didn't mention it as it is very embarassing. (IMG:style_emoticons/default/post-2-1117899824.gif) Your blue car is actually being worked on. the rear trunk is now ready for primer (IMG:style_emoticons/default/slap.gif) |
hot_shoe914 |
QUOTE Your blue car is actually being worked on. the rear trunk is now ready for primer No pics on my build thread? Actually reconsidering what you suggested at Hershey. Also about to list everything 914 I own for sale for one lump sum. |
OU8AVW |
Somewhere in the middle I think.... I do understand that our deal is a bit of a moving target but I'm not so naive to think that a surprise or two won't cost me. (IMG:style_emoticons/default/pray.gif) |
Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,038 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
You heard him, Scotty. Time to up-charge! (IMG:style_emoticons/default/poke.gif) Those breast implants are as good as yours! When can you come to my shop for the install?
scotty b |
Pics not taken include stripping all of the edges on the car, stripping the wheel well lips, stripping the rear trunk channels, sanded down the front fender, sanded the pass door sill blah blah blah. Hood and trunk lid get stripped bare tomorrow (IMG:style_emoticons/default/beerchug.gif)
scotty b |
(IMG:style_emoticons/default/welder.gif) I still have a little bit to do on the rocker patch. The piece of metal I had was just shy of filling in the whole hole, So I will make a small strip to fill in thsat lst bit at the top. I have the passengers side all body worked and ready for primer. Still a little "fine tuning" of the body work on the drivers side, and the front trunk channels to deal with
Attached image(s) ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
Lo-Fi Version | Time is now: 14th March 2025 - 11:14 PM |
