OU8AVW |
Yacht Rigger ![]() ![]() ![]() Group: Members Posts: 1,803 Joined: 1-October 08 From: Granbury, TX Member No.: 9,601 Region Association: Southwest Region ![]() |
OU8AVW |
OU8AVW |
OU8AVW |
OU8AVW |
So, I just got my replacement panel from Restoration Designs for the trunk. What a beautiful part. I was thinking about making the cut just forward of the aft curve of the support, see image. Then using a flange tool to flange the car to accept the new part overlapping the car. This will let me do a better job of welding these pieces together. The rest of the spot welding can be done like the factory from the outside of the rear apron. The original brace can then attach on top of the cross member.
What do you think? (IMG:style_emoticons/default/sawzall-smiley.gif) ![]() |
914itis |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,892 Joined: 9-October 10 From: New York City Member No.: 12,256 Region Association: North East States ![]() |
I played hookie from work yesterday and continued prepping for paint. I got a doner floor pan that I'm going to use for some patchwork on the driver's side. All and all not too bad. How did you approach these rust holes? Did you replace the panel or just clean and weld using small pieces? |
OU8AVW |
I played hookie from work yesterday and continued prepping for paint. I got a doner floor pan that I'm going to use for some patchwork on the driver's side. All and all not too bad. How did you approach these rust holes? Did you replace the panel or just clean and weld using small pieces? I cleaned and welded small patches. The pans were in fair shape, just a three spots that had rust-through. I cut out the sections and then used them as a template for cutting a doner I bought on this board. Not the best way to do it, but cost effective and easier than whole pans. I'm building this car to be a fun driver so it works for me. Carpet and undercoating will cover the patches..... |
OU8AVW |
OU8AVW |
I had some time this weekend and got the rear trunk pan removed. I cut along the trailing edge of the trans support. An air saw got the aft end of the pan removed close enough to the welds that I could grind down the remaining material with little effort.
![]() Attached thumbnail(s) ![]() |
FourBlades |
From Wreck to Rockin ![]() ![]() ![]() ![]() Group: Members Posts: 2,056 Joined: 3-December 07 From: Brevard, FL Member No.: 8,414 Region Association: South East States ![]() ![]() |
OU8AVW |
OU8AVW |
OU8AVW |
OU8AVW |
FourBlades |
It is dirt in the splines holding it in. Turn it vertical and shoot some PB blaster down there. Wait a few hours then turn it over and wiggle it and whack it. It should come out. John |
boogie_man |
Member ![]() ![]() Group: Members Posts: 308 Joined: 22-April 11 From: So Cal Member No.: 12,969 Region Association: Southern California ![]() |
Nice work, that is going to look awesome. Keep the pix coming....
nathansnathan |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,052 Joined: 31-May 10 From: Laguna Beach, CA Member No.: 11,782 Region Association: None ![]() |
914 post count there (IMG:style_emoticons/default/smile.gif) , awesome job on the trunk floor.
OU8AVW |
Working on the restoration of the front suspension. Removing the torsion bars and bushings....
The torsion bars were pretty frozen so I drilled out the forward caps with an anular ring cutter and used a Mini Inductor to heat things up. ![]() Cool tool! It uses an electrical field to heat metal to white hot is seconds. The tool itself stays cool to the touch as does any non-metallic items in the field. ![]() Heats up in less than 30 seconds ![]() Then a little pressure with the press. ![]() |
OU8AVW |
I had a strut cap walk away (IMG:style_emoticons/default/dry.gif)
I have asked Rich is he has one, I may be in the market. You know it's going to turn up the second a replacement arrives.... ![]() |
OU8AVW |
Lo-Fi Version | Time is now: 14th March 2025 - 12:20 PM |
