Another brake caliper option |
Trekkor |
Feb 3 2012, 11:30 PM
VW Fox.
1988 is what I'm using. Slight grinding required. 50% bigger than stock. (IMG:http://www.914world.com/bbs2/uploads_offsite/i944.photobucket.com-1413-1328333440.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i944.photobucket.com-1413-1328333440.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i944.photobucket.com-1413-1328333440.3.jpg) The calipers are very low priced. KT |
strawman |
Feb 3 2012, 11:45 PM
Senior Member Group: Members Posts: 881 Joined: 25-January 08 From: Los Osos, CA Member No.: 8,624 Region Association: Central California |
Are there good racing pads available? And please provide details on the extent of grinding necessary.
Geoff (I race against your Mercury in 24 Hours of Lemons in a 1969 Opel GT) |
Trekkor |
Feb 3 2012, 11:50 PM
You have to relieve the caliper about 1/8 inch where the rotor passes through and enlarge the bolt holes to accommodate the 914 bolts.
Doesn't take long. KT |
rohar |
Feb 3 2012, 11:54 PM
Senior Member Group: Members Posts: 924 Joined: 25-October 08 From: spokane Member No.: 9,685 Region Association: None |
Trekkor! How the hell you been doing!?
Interesting, I've been kicking around diving into the VAG parts bin for a lower maintainance rear caliper. I'm guessing the Fox caliper cross refs with Rabbits etc. Maybe Quantums? |
Trekkor |
Feb 4 2012, 12:01 AM
Doing great. This mod allows the use of 13 inch rims. (IMG:http://www.914world.com/bbs2/uploads_offsite/i944.photobucket.com-1413-1328335298.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i944.photobucket.com-1413-1328335299.2.jpg) KT |
Feb 4 2012, 12:15 AM
Resident German Group: Admin Posts: 41,707 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Doing great. It's been a while! (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/bye1.gif) |
rohar |
Feb 4 2012, 12:24 AM
Trekkor |
Feb 4 2012, 12:26 AM
It has been a while, friend,
regarding brake pad options, Porterfield has all the goods. I'm running R4's. KT |
Trekkor |
Feb 4 2012, 12:32 AM
mrbubblehead |
Feb 4 2012, 12:57 AM
Twodollardoug Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
are these a direct bolt on? besides the grinding that needs to be done? what about the parking brake?
rohar |
Feb 4 2012, 10:01 AM
Looks like Trekkor is running 4 front calipers. IIRC the fox had drums on the rears for all years, to that's not a great source for a parking brake.
rohar |
Feb 4 2012, 10:38 AM
Dangit, I just realized the parts from ATE are fairly interchangeable. If the carriers fit on 3" centers, calipers for another car with ATE floating calipers will likely fit.
Trekkor, you wouldn't have a measurement on the distance between the float pins would you? I obviously don't think real fast before coffee. |
rohar |
Feb 4 2012, 11:44 AM
Quick update.
Preface, I don't have the dimensional limitations Trekkor does, so I can go a bit bigger, 15" rims will be minimum for this. I'm running billett hubs up front w/ 11" vented rotors on stock 3" struts. I knew there were some options when Trekkor bolted up FOX calipers. Knowing that G55 calipers would bolt to a fox, I did some quick research and called a couple of VW friends with builds going on. Turns out the girling G60 calipers will interchange with the G55 as far as mounting, but it uses an 11" vented disk. The girling g60 can be found from 1989-1991 Audi 200 turbo quattro, 92-94 Audi turbo quattro, 1990-1994 Audi V8, 1992-1994 Audi 100 V6, 1987-1988 Audi 5000 quattro turbo, 1984-1988 Audi 5000 turbo, and 1993-1995 Audi 90 V6. Piston bore is 60mm. The 1993-1995 Audi 90 V6 uses a 10.86" non vented rear rotor and the caliper uses an integrated parking brake. This isn't ideal, I'll probably have to relieve some of the metal on the rear caliper. .3" at most or come up with a different carrier. It will require a 25mm master to push all those pistons, but it's a complete, balanced system and appears to fit. Thanks Trekkor, now I'm pulling my whole brake system and I blew my allowance at a used parts joint. Again. |
a914622 |
Feb 4 2012, 07:10 PM
Member Group: Members Posts: 316 Joined: 12-August 10 From: northwest Member No.: 12,048 Region Association: Pacific Northwest |
The v6 audis used the 10.86 dia vented rotor and the G57 caliper. The g60s are a duel piston and used a 24mm vented rotor about the same dia as the 84-88 sc. But the g60 bolt spacing is 3.70 not 3.0.
jeff |
rohar |
Feb 4 2012, 07:52 PM
The v6 audis used the 10.86 dia vented rotor and the G57 caliper. The g60s are a duel piston and used a 24mm vented rotor about the same dia as the 84-88 sc. But the g60 bolt spacing is 3.70 not 3.0. jeff Yeah, there's a $100 bracket in there to make the fronts work, the rears should bolt right up. |
Trekkor |
Feb 13 2012, 12:07 AM
Where can I find a bigger master cylinder?
KT |
ConeDodger |
Feb 13 2012, 12:19 AM
Apex killer! Group: Members Posts: 23,631 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Trekkor??? (IMG:style_emoticons/default/blink.gif) Good to see you my friend!
Krieger |
Feb 13 2012, 09:17 AM
Advanced Member Group: Members Posts: 4,733 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
(IMG:style_emoticons/default/agree.gif) Hey dude! I figured this was some old post dug up.
Eric_Shea |
Feb 13 2012, 09:18 AM
PMB Performance Group: Admin Posts: 19,279 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
rohar |
Feb 13 2012, 09:25 AM
Where can I find a bigger master cylinder? KT The master from a VW Transporter from '73 and newer is 23mm and should bolt right up. It should be big enough even with the fox fronts in the rear, but I can't verify it. There's the downside to the watercooled brakes, huge cyls. |
Lo-Fi Version | Time is now: 26th June 2024 - 03:54 AM |
