Wiper switch differences, trying to add an elec. washer switch |
Valy |
Mar 1 2012, 12:42 AM
Senior Member Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
Just got an old wiper switch of unknown origin. Plugged it in turn on ignition flick switch, wiper works no problems.... Hm..... Numbers don't make sense but never mind that now. You should'be say you have a replacement (IMG:style_emoticons/default/smile.gif) Take some pictures of the switch guts. Let's see what's wrong. |
jt914-6 |
Mar 1 2012, 07:09 AM
Driving & working on teeners 41 years Group: Members Posts: 1,786 Joined: 3-May 08 From: Bryant, Arkansas Member No.: 9,003 Region Association: South East States |
For those who own a '70-71 (I think that is the years) that have a factory dash mounted wiper switch, I have a replacement that is intermittant and has a hot lead for a 12 volt pump. It is designed for use with Bosch systems and had one on my '74. For those with the steering column switch, this one can be used but it has to be dash mounted. pm me with any questions.... (IMG:style_emoticons/default/smash.gif)
Krieger |
Mar 1 2012, 09:57 AM
Advanced Member Group: Members Posts: 4,769 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
I'l get back into this tonight when I get home.
Krieger |
Mar 1 2012, 09:16 PM
Hey, I'm at it again.
Here are some observations: The old unknown switch works wipers and does not pop fuse when installed in steering assembly as well. The "new" switch works the wipers and does not pop the fuse when it is out of the assembly.... I 'm gonna study these switches and see if I can find out why. |
Valy |
Mar 1 2012, 09:37 PM
Krieger |
Mar 1 2012, 10:01 PM
There was a small "protrusion" I filed it a little put some electrical tape over the corner and it works when installed! All back together and ready to go! Thanks for the help! (IMG:style_emoticons/default/beer3.gif)
Krieger |
Mar 1 2012, 10:07 PM
The protrusion was similar to the top right of your picture. It was not that hard to find the scrape it made inside the metal housing.
Valy |
Mar 1 2012, 11:15 PM
Happy to help (IMG:style_emoticons/default/smile.gif) |
jkb944t |
Jun 20 2018, 10:30 AM
Member Group: Members Posts: 464 Joined: 17-January 05 From: Canton, OH Member No.: 3,459 Region Association: None |
I've done a lot of research on this topic. Here is what I know: Switches: 1. The 4 wire switch does only support low and high speed. The water is activated through a valve. Wipers will not work when the water valve is activated. The connector has 5 terminals but one is not populated. 2. The 5 wire switch adds the timed delay relay option and wipers on when water valve is open. Note that you can't run an electric water pump with this switch. It just triggers the delay relay to operate the wipers when the valve opens. 3. There is a 6 wire switch used in Super Beetle that has an additional wire for the electric pump. This wire doesn't go to the connector and has it's own spade connector that should be routed to the pump (see picture - note that this switch has both the valve and the pump wire so you can use electric or pneumatic washer system) 4. There is an old 924 switch that has the same functionality as (3) but has a larger connector with 7 terminals. It's an extension of the 914 connector with 2 additional terminals, one of them empty. The pump wire is in the extension. (see diagram below) 5. The signal switch has a tab that prevents the wiper switch to go into the intermittent position. That tab must be removed when an extended switch is used. Harness: The 914 harness had the option for intermittent wipers. In some models, everything is in place and an intermittent wiper is installed in the front trunk. If that relay is not there, the wire from the switch (5th terminal) is probably still in place but it's wrapped in the harness to prevent a short. You can add the relay but you'll have to cut the return power from the wiper motor and plug the relay there, together with the said wire and power and ground. My opinion, and this is what I've done to my car as well, is that with all the trouble you go through to add the wiper relay, it's better to add a programmable relay that will permit you to control the wiper interval. I use a VW relay that allows that just by switching the wipers on-off-on once to program the interval. The relay wiring is a bit different but you need to add that relay anyway. I now have the Super Beetle switch with the six wires so that I can have both the intermittent relay option and the electric washer pump. I know that I should use the separate sixth black wire with the spade to trigger the electric washer pump. Is this black wire 12V positive when you pull on the stalk or is it grounded to negative? Jeff B |
Valy |
Jun 20 2018, 10:28 PM
Positive (99% sure but I can't check right now).
Valy |
Jun 21 2018, 01:12 AM
Yes, it's 12v.
Lo-Fi Version | Time is now: 29th December 2024 - 03:12 AM |
