anyone know this car?, orange flared factory six in idaho.. |
vortrex |
Sep 11 2004, 01:16 AM
Senior Member Group: Members Posts: 1,687 Joined: 24-December 02 From: SF, CA Member No.: 4 Region Association: None |
not a lot of details in the ad, but looks good. anyone seen it before?
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...2489504255&rd=1 |
Porsche Rescue |
Sep 11 2004, 08:47 AM
Know nothing, but waiting for a reply from the seller (as I be a whole lot of us are!).
i love porsche |
Sep 11 2004, 10:07 AM
Senior Member Group: Members Posts: 1,547 Joined: 6-May 04 From: Nutley, NJ Member No.: 2,030 Region Association: North East States |
my car will look like that when its finished....except for the six part, its gonna have a big four
Bleyseng |
Sep 11 2004, 11:00 AM
Aircooled Baby! Group: Members Posts: 13,036 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Looks like a 74 tan interior to me, whats with that?
Geoff |
Sep 11 2004, 12:54 PM
Resident German Group: Admin Posts: 41,943 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
QUOTE(Bleyseng @ Sep 11 2004, 10:00 AM) Looks like a 74 tan interior to me, whats with that? not only that (moveable pass. seat) but also the later style front trunk reinforcement! repainted as well, i'd like to see more pics of the interior and trunks ... (IMG:style_emoticons/default/wink.gif) Andy |
vortrex |
Sep 11 2004, 02:34 PM
I got the pics, which are small and not great quality. the body needs work. car has glass flares and one (or more?) is cracked really bad. also looks like some rust around the sail panel chrome trim, although hard to tell since he resized the pics so small! the spec sheet looks fairly impressive, but with the body work needed I don't see this car going for a ton.
vortrex |
Sep 11 2004, 02:35 PM
1970 914-6GT
VIN #9140430238 EXTERIOR ALL NEW INSIDE AND OUT, SIGNAL ORANGE PAINT (L 20 E) NEW CHROMED BUMPERS GT FENDER FLARES (GLASS) ALL NEW TAIL AND TURN INDICATOR LENSES NEW FRONT AIR DAM NEW GT ROCKER PANELS INTERIOR ALL NEW CARPETING INCLUDING TRUNK NEW OEM DASH RECONDITIONED SEATS, DOOR PANELS AND DASH FACIA NEW PANASONIC CQ-DP36 REMOVABLE FACE AM-FM CD PLAYER PIONEER 5” 100 WATT SPEAKERSIN STOCK HOUSEINGS UPDATED SHORT SHIFT KIT WITH ALL NEW SHIFT BUSHINGS NEW LEATHER WHEEL COVER ALL NEW BRONZEPEDAL BUSHINGS AND NEW PEDAL PADS NEW INTERSTATE BATTERY WHEELS AND SUSPENSION FUCH ALLOYS WITH BLCK CENTERS POLISHED LIP, CENTER CAP AND LUGS 7 X 15 FRONT WITH NEW BRIDGESTONE RE71 205 X50 X 15 TIRES 8 X 15 REAR WITH NEW BRIDGESTONE RE 71 225 X 50 X 15 TIRES KONI STRUT INSERTS IN FRONT KONI REAR SHOCKS 180 LB REAR SPRINGS 19MM FRONT SWAY BAR TURBO TIE ROD ENDS NEW BRAKE PADS AND FLUID STAINLESS STEEL BRAKE LINES ENGINE 5800 MILES ON COMPLETE (TOP AND BOTTOM) REBUILD 2.2 LITER S (CRANK, RODS, Ps & Cs HEADS) ORIGINAL ENGINE CASE BALANCED TO WITHIN 1 GRAM NEW MAHLE PISTONS AND CYLINDERS CARRERA TENSIONERS ALL MACHINING DONE BY LUKES AND SHORMAN OF ALBANY, CALIFORNIA ALL NEW VALVES (SODIUM FILLED EXHAUST) ALL NEW VALVE GUIDES AND UPDATED STEM SEALS ALL NEW WRIST PIN BUSHINGS REBUILT OIL PUMP TURBO OIL PRESSURE RELIEF VALVE UPDATED OIL PASSAGE MACHINING (RECCOMMENDED BY BRUCE ANDERSON) NEW EXPANDABLE OIL RETURN TUBES PRESSURE FED CHAIN TENSIONEERS RECONDITIONED AND MAGNAFLUXED CRANKSHAFT RECONDITIONED AND MEGNAFLUXED RODS ALL NEW ROD BOLTSAND NUTS RECONDITIONED AND MAGNAFLUXED ROCKER ARMS RECONDITIONED HEADS BOSCH CENTRIFICAL ADVANCE DISTRIBUTOR NEW PLATNUM SPARK PLUGS ALL NEW SPARK PLUG WIRES ALL SHEET METAL POWDER PAINTED SOLAR BLACK SIGNAL ORANGE ENGINE SHROUD REBUILT ALTERNATOR LIKE NEW WEBER 40 IDA CARBURETORS, WITH PMO FUEL PICKUP, BAFFELING AND VENTING MODIFICATIONS) 32MM VENTUIES 130 MAIN JETS 155 IDLE JETS 180 AIR CORRECTION JETS F3 EMULSSION TUBES K& N FILTERS AND RAIN SHIELD COVERS NEW SACHS CENTER SPRING CLUTCH, T/0 BEARING AND PRESSURE PLATE RESURFACED FLYWHEEL WITH NEW FLYWHELL BOLTS REBUILT TRANSMISSION WITH A TIGHT 1ST GEAR AND SYNCRO SWEPCO TRANSMISSION FLUID SOLID TRANSMISSION MOUNTS RECONDITIONED HALF-STAFTS MISCELANIOUS ALL MAINTENANCE RECORDS ALL SERVICE PART INVOICES ALL SUBLET LABOR INVOICES |
Sep 11 2004, 04:40 PM
QUOTE(vortrex @ Sep 11 2004, 01:34 PM) I got the pics so, where are the pix ??? <_< Andy |
vortrex |
Sep 11 2004, 04:48 PM
pic #1
vortrex |
Sep 11 2004, 04:49 PM
pic #2
vortrex |
this is all he sent.
tod914 |
Sep 11 2004, 04:59 PM
Here's a novel idea on how to hide that crack. Cover the car in sail panel vinal, and leave the sail panels painted.
Sep 11 2004, 05:01 PM
QUOTE(vortrex @ Sep 11 2004, 03:49 PM) this is all he sent. call me crazy but i still think there's something "fishy" about this car ... i don't think it's a '70 ... (IMG:style_emoticons/default/idea.gif) Andy |
tod914 |
Sep 11 2004, 05:07 PM
What's going on underneath that sail panel chrome??? The black area I'm refering to.
vortrex |
Sep 11 2004, 06:32 PM
I think that is rust.
vortrex |
Sep 11 2004, 06:36 PM
more pics
vortrex |
more pics
vortrex |
more pics
vortrex |
Sep 11 2004, 06:37 PM
more pics
vortrex |
last one
Lo-Fi Version | Time is now: 26th December 2024 - 05:07 AM |
