Glove Box, Trying to get the lock to work |
jim_hoyland |
Sep 11 2004, 08:18 PM
Get that VIN ? Group: Members Posts: 9,557 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
After getting a new key for the glove box, the lock worked perfect. Over time I ca no longer get the lock to work. Waht is the trick to this ???
Sep 11 2004, 08:20 PM
Resident German Group: Admin Posts: 41,943 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
QUOTE(jim_hoyland @ Sep 11 2004, 07:18 PM) After getting a new key for the glove box, the lock worked perfect. Over time I ca no longer get the lock to work. Waht is the trick to this ??? sometimes, they rattle lose and you can't turn them anymore. make sure the nut on the backside holding the lock is tight ... (IMG:style_emoticons/default/wink.gif) Andy |
jim_hoyland |
Sep 11 2004, 08:23 PM
The lock nut is tight, the cam turns correctly when I turn the key. When the door is closed, the cam is hitting something.
Sep 11 2004, 09:03 PM
QUOTE(jim_hoyland @ Sep 11 2004, 07:23 PM) The lock nut is tight, the cam turns correctly when I turn the key. When the door is closed, the cam is hitting something. there's not much play in there, maybe you bend the glove box door hinge? it has a little tab that is supposed to hit the lock part when the lock is in closed position, if that tab is bent it might prevent the lock from turning ... (IMG:style_emoticons/default/wink.gif) Andy |
Lo-Fi Version | Time is now: 26th December 2024 - 10:15 AM |
