Boxster Calipers, got them installed today! |
jim_hoyland |
May 31 2012, 08:13 AM
Get that VIN ? Group: Members Posts: 9,516 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
I have not mounted those adapters. They are in a drawer.... (IMG:style_emoticons/default/smile.gif)
Luke M |
Jul 9 2012, 06:47 AM
Senior Member Group: Members Posts: 1,394 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States |
I have the same setup as Andy but I installed the early 911 e-brakes on the rear.
It wasn't too bad had to measure alot to get things just right with the lever mounts. I also had to make a small cable to attach to the 914 e brake cable. I took a look at my caliper pistons like Aaron brought up . The rear calipers bolt right up ( small piston to the top ) as for the fronts they need to be flipped ( right now larger piston is on top ) . Attached thumbnail(s) Attached image(s) |
CptTripps |
Aug 30 2013, 01:28 PM
:: Punch and Pie :: Group: Members Posts: 3,584 Joined: 26-December 04 From: Mentor, OH Member No.: 3,342 Region Association: Upper MidWest |
So here I go digging up an old thread, and digging into minutia.
I know that the calipers that start with 996 are newer than 986, but does anyone have an idea on the next three numbers? Rich said to stay away from the .352. calipers but I can't for the life of me see a difference when I have them in my hand. I'm on the hunt for: 986/996.351.421 986/996.351.422 986/996.351.424 986/996.351.425 Everywhere I turn, I'm finding sets that have 1 or 2 .352. calipers in the mix. Can they really be that different? |
Luke M |
Aug 30 2013, 04:00 PM
I just checked my calipers and this is what I have for #'s.
Fronts are : 986 351 421 & 986 351 422 Rears are : 996 352 421 & 996 352 442 Why stay away from the .352 # ? I have the standard Boxster calipers but there's also a Boxster S calipers which is different from what I hear. |
CptTripps |
Aug 30 2013, 05:15 PM
I think you may have a set of fronts on the rear...
Luke M |
Aug 30 2013, 05:38 PM
From the Pelican site.
http://www.pelicanparts.com/catalog/shopca..._BRKprf_pg1.htm The part numbers for the Boxster calipers required for this kit: Front left: 986-351-421-03 Front right: 986-351-422-03 Rear left: 986-352-423-01 Rear right: 986-352-424-01 The part numbers for the brake rotors required for this kit: Front Carrera: 911-351-041-22 Rear 911SC: 901-352-041-14 The part numbers for the brake pads required for this kit: Front: 986-351-939-15 Rear: 986-352-939-10 |
Jeff Hail |
Aug 30 2013, 06:01 PM
Senior Member Group: Members Posts: 1,141 Joined: 3-May 07 From: LA/ CA Member No.: 7,712 |
From the Pelican site. http://www.pelicanparts.com/catalog/shopca..._BRKprf_pg1.htm The part numbers for the Boxster calipers required for this kit: Front left: 986-351-421-03 Front right: 986-351-422-03 Rear left: 986-352-423-01 Rear right: 986-352-424-01 The part numbers for the brake rotors required for this kit: Front Carrera: 911-351-041-22 Rear 911SC: 901-352-041-14 The part numbers for the brake pads required for this kit: Front: 986-351-939-15 Rear: 986-352-939-10 Yes- Those are the correct PN's for the calipers you should be using. Attached image(s) |
Jeff Hail |
Aug 30 2013, 06:10 PM
and pads
CptTripps |
Aug 30 2013, 07:08 PM
Hmmm...
I've got another set on the way. So I'll have to see what the part numbers are when they arrive. I KNOW the last set was wrong. (They shipped 3 rears and 1 front.) Thanks gang. |
Bates |
May 8 2015, 04:47 AM
Bates Group: Members Posts: 68 Joined: 27-December 13 From: Madison, Virginia Member No.: 16,800 Region Association: MidAtlantic Region |
Will the Boxster calipers fit under 15" Fuchs?
May 8 2015, 10:23 AM
Resident German Group: Admin Posts: 41,892 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Will the Boxster calipers fit under 15" Fuchs? They should, i run them under 15" cookie cutters ... (IMG:style_emoticons/default/idea.gif) |
ClayPerrine |
May 12 2015, 09:12 PM
Life's been good to me so far..... Group: Admin Posts: 15,902 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Will the Boxster calipers fit under 15" Fuchs? They should, i run them under 15" cookie cutters ... (IMG:style_emoticons/default/idea.gif) Don't try to run one of the collapsible spares with the Boxster calipers. The offset is wrong and the caliper locks against the wheel (BTDT) I bought a Boxster spare rim so I don't have to worry about it. |
May 13 2015, 10:57 AM
Will the Boxster calipers fit under 15" Fuchs? They should, i run them under 15" cookie cutters ... (IMG:style_emoticons/default/idea.gif) Don't try to run one of the collapsible spares with the Boxster calipers. The offset is wrong and the caliper locks against the wheel (BTDT) I bought a Boxster spare rim so I don't have to worry about it. I got a full size 7" cookie cutter as a spare wheel, so no problems there. (IMG:style_emoticons/default/smile.gif) |
madmax914 |
May 13 2015, 03:13 PM
Member Group: Members Posts: 204 Joined: 16-February 14 From: Salem, Oregon Member No.: 17,007 Region Association: Pacific Northwest |
Andy, can you pass on Rick Johnson's information, his adapters look so much "beefier" than the other adapters I've seen.
GermermanCarGuy |
May 13 2015, 03:53 PM
GermanCarGuy Group: Members Posts: 81 Joined: 13-May 14 From: Rapid City, SD Member No.: 17,346 Region Association: Upper MidWest |
Andy, can you pass on Rick Johnson's information, his adapters look so much "beefier" than the other adapters I've seen. (IMG:style_emoticons/default/agree.gif) Better than what I've been trying to work out. If he's making sets, I'd be in for some. Rob |
May 13 2015, 05:46 PM
Andy, can you pass on Rick Johnson's information, his adapters look so much "beefier" than the other adapters I've seen. You can find his contact info here: http://www.914world.com/bbs2/index.php?showtopic=4319 Or send him a PM: a914guy (IMG:style_emoticons/default/smile.gif) |
amallagh |
Mar 17 2019, 06:58 PM
Member Group: Members Posts: 103 Joined: 4-September 06 From: Cheshire, England Member No.: 6,767 |
What happens if you use the 996 part number rear calipers (still non S) ?
i.e. part numbers 996 352 421 & 996 352 422, (rather than 986-352-423-01 & 986-352-424-01 as stated below) ? I see Luke asked this question way back then but I don't see an answer. ( I have some of these 996 part number rear calipers and need to know if I can use the adaptors and whether to use SC 20mm rotors or 24mm Carrera ones on the rear. Regards Andrew From the Pelican site. http://www.pelicanparts.com/catalog/shopca..._BRKprf_pg1.htm The part numbers for the Boxster calipers required for this kit: Front left: 986-351-421-03 Front right: 986-351-422-03 Rear left: 986-352-423-01 Rear right: 986-352-424-01 The part numbers for the brake rotors required for this kit: Front Carrera: 911-351-041-22 Rear 911SC: 901-352-041-14 The part numbers for the brake pads required for this kit: Front: 986-351-939-15 Rear: 986-352-939-10 |
Retroracer |
Mar 17 2019, 07:51 PM
Senior Member Group: Members Posts: 621 Joined: 7-July 13 From: Bend OR Member No.: 16,100 Region Association: Pacific Northwest |
Andy - did you flip the link lines and the bleeders on the front brakes so that the larger cylinder is at the bottom? Recall that on the Boxster the calipers are the other side of the strut (inboard).
I've seen some expensive 911 builds where people have forgotten (or were unaware) of this. Not sure it makes a huge difference to stopping power, probably just uneven pad wear.... Anyway, - Tony PS. Looking back through the thread, I see the issue has been brought up already; oops. |
Retroracer |
Mar 17 2019, 07:53 PM
roblav1 |
Nov 1 2019, 08:01 PM
Senior Member Group: Members Posts: 528 Joined: 18-September 12 From: KY Member No.: 14,943 Region Association: MidAtlantic Region |
I just put this setup on my car yesterday:
- Carrera front rotors / Boxster front calipers - SC vented rear rotors / Boxster rear calipers The front calipers are swapped left to right and vv. 7X15 and 8X15 Fuchs easily fit. Someone mentioned bolts not mounted in shear... all are mounted in shear, yes. I set up the rear E-Brake with 69-73 type 911 shoes. Cables will run to the bottom, not through the trailing arm nor with a lever mechanism. I welded parking brake brackets in a new location. This alteration was easy. Anyway, I highly recommend this setup. |
Lo-Fi Version | Time is now: 24th November 2024 - 04:37 PM |
