9xauto |
Newbie ![]() Group: Members Posts: 17 Joined: 13-September 04 From: New York Member No.: 2,751 ![]() |
Does anyone have installed permanent metal roof? If yes. How did it work out? Any feedback will be appreciated. (IMG:style_emoticons/default/driving.gif)
Elliot_Cannon |
Senior Member ![]() ![]() ![]() Group: Retired Members Posts: 1,922 Joined: 26-March 03 From: Orange County Ca Member No.: 480 Region Association: None ![]() |
One of the reasons I like this car so much is the roof can come off and stow in the trunk. Maybe it's the climate difference but why would you want to make your roof permanent?
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,707 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
QUOTE(Elliot Cannon @ Sep 14 2004, 11:07 AM) why would you want to make your roof permanent? so you can tell people it's a 916! more stiffness for the chassis would be one reason. i've never seen one, but i guess you could use a old targa top and lay some sheetmetal over it and hammer it into shape, then weld in (add some side support) ... would be nice to see one done! (IMG:style_emoticons/default/smash.gif) Andy |
Root_Werks |
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,341 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest ![]() ![]() |
I was 18 when I got hold of my first 914-6. There was a guy with a 924 sitting in his yard that was a parts car. granted it had the big s/r in it, but I cut it out. I never had the nerve to do it and traded the 914 for a 911 so the project never got under way. But my father and I trimed the 924 roof piece so it fit just like the targa top did. I think a little creative welding adn it would have looked great! We planed on welding the s/r in place of course, actually, we did that before hand. Even the rain gutters looked good.
Go find a 924/944 and (IMG:style_emoticons/default/sawzall-smiley.gif) the roof man! the curve of the roof is just about perfect. (IMG:style_emoticons/default/cool.gif) |
9xauto |
The reason I'm interested, it will add stiffness to the structure and allow the use of the window net. It will also cut down on the size of the roll cage which I need to install. I do not like the open-roof "caged-out" 914. It destroys the likeness of the car the way it was not intended. (IMG:style_emoticons/default/welder.gif)
Joe Bob |
Retired admin, banned a few times ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None ![]() |
I bolted the f/g one down and use a race net.....but the net clips into the roll cage.
Part Pricer |
Believe everything I post ![]() ![]() ![]() Group: Benefactors Posts: 1,825 Joined: 28-December 02 From: Danbury, CT Member No.: 35 ![]() ![]() |
QUOTE(9xauto @ Sep 14 2004, 03:44 PM) The reason I'm interested, it will add stiffness to the structure and allow the use of the window net. It will also cut down on the size of the roll cage which I need to install. I do not like the open-roof "caged-out" 914. It destroys the likeness of the car the way it was not intended. I'm having a hard time following that one. Most roll cages that I've seen on 914s allow the roof to be on the car. In fact, some organizations require the roof to be on. What are you prepping this car for? |
QUOTE(Paul Heery @ Sep 14 2004, 01:55 PM) Most roll cages that I've seen on 914s allow the roof to be on the car. (IMG:style_emoticons/default/agree.gif) yupp, roof still fits just fine, pas de probleme ... (IMG:http://www.sirandy.com/pix/914/09.01.2002/IMGP0644.JPG) |
Jeroen |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe ![]() |
They reasons you mention for getting a steel roof make no sense at all...
You don't need the added rigidity when you're installing a cage You can clip the window net to the cage or the stock roof A steel roof wouldn't add any extra clearance for a cage compared to a stock roof The only reason to add a steel roof would be if you'd want to build a very good 916 replica But what's the fun if you can no longer drive with the top off... Just MHO |
94teener |
Member ![]() ![]() Group: Members Posts: 209 Joined: 6-February 04 From: Jacksonville, FL Member No.: 1,636 ![]() |
I think you will find that the rear trunk lid, which is significantly larger than the targa top, can be cut to make a rather correctly shaped steel top without too much banging on it.
Phil |
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,643 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
QUOTE(9xauto @ Sep 14 2004, 01:44 PM) The reason I'm interested, it will add stiffness to the structure and allow the use of the window net. It will also cut down on the size of the roll cage which I need to install. I do not like the open-roof "caged-out" 914. It destroys the likeness of the car the way it was not intended. (IMG:style_emoticons/default/welder.gif) 9x, you may want the window net attatched only to the cage and not the roof.... I believe SCCA and other orgs may even require this. Its safer that way. brant |
ThinAir |
Best friends ![]() ![]() ![]() ![]() Group: Members Posts: 2,545 Joined: 4-February 03 From: Flagstaff, AZ Member No.: 231 Region Association: Southwest Region ![]() ![]() |
QUOTE(94teener @ Sep 14 2004, 05:46 PM) I think you will find that the rear trunk lid, which is significantly larger than the targa top, can be cut to make a rather correctly shaped steel top without too much banging on it. Phil Hmmm... I hadn't thought of that one. I've got a hood that would do nicely for that. I'm one of those crazy people that never takes the top off the teener. Rolling down the windows is enough for me. I've thought of just such a project for my 72 once I finally get to working on restoring it, but I wasn't sure where to start. I like the idea of a hardtop because it would solve the problem of leaks between the rubber pieces. My 914s are daily drivers so they actually see rain, but I hate having it drip on my arm. |
QUOTE(ErnieDV @ Sep 14 2004, 09:56 PM) I like the idea of a hardtop because it would solve the problem of leaks between the rubber pieces. My 914s are daily drivers so they actually see rain, but I hate having it drip on my arm. and how exactly is a solid roof going to fix that? (IMG:style_emoticons/default/laugh.gif) you still need to seal the window against the top, which is the biggest problem, hard top or not ... (IMG:style_emoticons/default/cool.gif) Andy PS: also, molding a rear trunk lid will only work if you find a way to add the rain "channel" on the sides, otherwise your occasional drip on your arm will turn into a flood on each downpour ... |
ThinAir |
QUOTE(SirAndy @ Sep 14 2004, 10:08 PM) and how exactly is a solid roof going to fix that? Well when I put some RTV between the top-side piece and the angled front piece it took care of the problem until I took the top off and put it back on again. With a permanent roof I would not have to worry about it. Even though the fiberglass roof didn't leak anymore, it still squeeked and a permanent roof would take care of that for sure. |
QUOTE(ErnieDV @ Sep 14 2004, 10:28 PM) Well when I put some RTV between the top-side piece and the angled front piece it took care of the problem until I took the top off and put it back on again. With a permanent roof I would not have to worry about it. Even though the fiberglass roof didn't leak anymore, it still squeeked and a permanent roof would take care of that for sure. oh, i see, so yours leaked where the front seal meets the roof seal. that makes sense. mine just leaks anywhere ... yes, the squeeking can get annoying ... <_< Andy |
redshift |
Bless the Hell out of you! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 ![]() |
Leaks anywhere... (sounds like Zappa 'In France')
(IMG:style_emoticons/default/wink.gif) Your teener has no manners Andy. M |
QUOTE(redshift @ Sep 14 2004, 10:52 PM) Leaks anywhere... (sounds like Zappa 'In France') you're probably going to apprechiate this ... i was once given a Zappa record (remember, those *big black* CDs?). i had no idea what it was but it seemed like a big deal at the time. never listened to it, didn't know what to do with it, soooo, like 2 years later or so, i'm having a party and this guy goes through my records and he's like "oh my god, you got one of those!?!" and i say, yeah, whatever, take it if you like it ... turned out, it was a 1 out of a 100 ever made. and the funny part? i didn't give a damm *bleep*, just gave it away to someone who probably still listens to it ... (IMG:style_emoticons/default/cool.gif) Andy |
BatAc |
Member ![]() ![]() Group: Members Posts: 120 Joined: 9-July 04 From: seattle Member No.: 2,329 ![]() |
I take my roof off as much as possible but it doesn't ever, ever rain in Seattle. Oh yea, maybe it's just to appreciate that big giant yellow orb! (IMG:style_emoticons/default/smoke.gif)
QUOTE(BatAc @ Sep 14 2004, 11:13 PM) I take my roof off as much as possible but it doesn't ever, ever rain in Seattle. Oh yea, maybe it's just to appreciate that big giant yellow orb! (IMG:style_emoticons/default/smoke.gif) funny thing is, the more you get down to where the sun is out all the time the more people think you're a total freak for driving a "convertible" ... on my last trip to phoenix AZ i rented a mustang convertible. you should have seen the looks i got while i was driving down the freeway, top down, of course ... what's wrong with these people ???? (IMG:style_emoticons/default/laugh.gif) Andy |
Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
Their all A/C addicts, Andy.
Lo-Fi Version | Time is now: 26th June 2024 - 06:53 AM |
