engine size |
engine size |
orangy |
Sep 14 2004, 05:03 PM
Newbie Group: Members Posts: 11 Joined: 7-September 04 Member No.: 2,715 |
where can you find the engine size for a 1973 914? I have the vin number, but all the sites want 17 digets
4732909011 is the vin number thanks |
dan10101 |
Sep 14 2004, 05:06 PM
TORQUE-o-holic Group: Members Posts: 1,140 Joined: 29-April 03 From: Eagle Point, Or Member No.: 626 Region Association: Pacific Northwest |
You have to look on the engine.. By the oil fill neck on the front of the engine it should say GA if its a 2.0.
Do you have pics of your engine? We could also tell from that... |
orangy |
Sep 14 2004, 05:08 PM
its not a 2.0, its either a 1.7 or 1.8, we have been told its a 1.8.
thank you, and i can send pic |
Joe Bob |
Sep 14 2004, 05:12 PM
Carfaxes are only good down to 1981, so no 914s will come up.
1973 had a 1.7 or a 2.0. The ENGINE serial number will tell ya.....but an easy way is to look at the intake where it bolts to the head. Four bolts, one on each side and two in the middle is a 1.7. Three bolts....with only ONE in the middle is the 2.0.... 1.8s came in the 74-75 model years....but THAT DOES NOT mean that someone swapped a 1.8 in there. Take a pic and post it or read the serial number and post that.... |
SLITS |
Sep 14 2004, 05:18 PM
If it's a '73, it will be a 1.7 unless someone has done an engine change. Engine stamping will begin with EA or EB. This will be on the case rib, pass side, near the flywheel (under all the FI stuff and dirt/grease).
The 1.8 didn't start till '74. Damnit Mike (IMG:style_emoticons/default/alfred.gif) |
lapuwali |
Sep 14 2004, 05:21 PM
If it's a '73, it's either a 1.7 or that engine isn't original to the car. No big surprise there, really, but if they swapped engines, there's no telling what else was swapped. A 1.8 should have L-Jet on it, not D-Jet. The easiest way to tell the difference there would be to see if there's a plug on the distributor other than the single green wire to the coil. If there is, it's D-Jet, and it's most likely a 1.7. If there isn't, it's L-Jet.
Unless you have carbs, too... |
Jeroen |
Sep 14 2004, 05:24 PM
Check the "914 info" link at the very top of the page for VIN and engine#'s
Joe Bob |
Sep 14 2004, 05:27 PM
QUOTE(SLITS @ Sep 14 2004, 03:18 PM) If it's a '73, it will be a 1.7 unless someone has done an engine change. Engine stamping will begin with EA or EB. This will be on the case rib, pass side, near the flywheel (under all the FI stuff and dirt/grease). The 1.8 didn't start till '74. Damnit Mike (IMG:style_emoticons/default/alfred.gif) Too slow ya old fart...... :finger2: |
wilchek |
Sep 14 2004, 07:00 PM
Senior Member Group: Members Posts: 506 Joined: 8-June 04 From: Eastern Pennsylvania Member No.: 2,177 |
Just look at the air cleaner see below
wilchek |
Sep 14 2004, 07:40 PM
1.8 L-JET BELOW
Lo-Fi Version | Time is now: 27th September 2024 - 12:54 PM |
