RiqueMar |
Enrique Allen Mar ![]() ![]() ![]() ![]() Group: Members Posts: 2,220 Joined: 28-August 08 From: San Diego, CA Member No.: 9,478 Region Association: Southern California ![]() ![]() |
I'm not a fan of side air intakes, but that's looking awesome!
Love that blue, too! (IMG:style_emoticons/default/wub.gif) Keep it up! (IMG:style_emoticons/default/beerchug.gif) |
effutuo101 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,735 Joined: 10-April 05 From: Lemon Grove Member No.: 3,914 Region Association: Southern California ![]() |
Stitch...Mostly evil...
gothspeed |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None ![]() |
Wow (IMG:style_emoticons/default/smile.gif)!!! Does the lizard skin need carpet or paint to protect it? or is it robust enough to stand on its own?
I am considering second skin audio butyl mats or bedliner with carpet over it or something like this lizard skin. Your experience will be much appreciated! (IMG:style_emoticons/default/smile.gif) |
jim_hoyland |
Get that VIN ? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,676 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California ![]() ![]() |
Looking good ! (IMG:style_emoticons/default/smile.gif) Thanks for shaing. I like the side air intakes. The aftermarket convertible 914s had those, they located aft the door handle, IIRC
effutuo101 |
The final texture is just like rhino lining. I am sure it would stand up. But, the nice thing is you can paint right over it. I will probably add some sound material to the low spots just to even out the floor as well as the back panel.
There are 4 layers on the fire wall. Two sound and two heat on each side. Only two layers of sound and heat on the floor. my rear bumper just arrived. But, I have to go do some work downtown. Maybe a mock up later today... |
effutuo101 |
@ Jim, yes, I almost did the same. But, given the size, I had to drop them down a bit. They have 3 inch intakes behind them. Same with the NACAducts. The brake intake are 2 inch.
effutuo101 |
And now my doors are back from the sand blasters. primer and seal as well....
Ferg |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None ![]() ![]() |
Wow, Cool! (IMG:style_emoticons/default/w00t.gif)
gothspeed |
Thanks for the info effutuo101 (IMG:style_emoticons/default/smile.gif)!! I think I will put some deadener mats on the big flat spots, go over everything (including the mats) with that lizard skin then paint it black.
You are doing a great job man!!!! (IMG:style_emoticons/default/beerchug.gif) |
effutuo101 |
@ Ferg! (IMG:style_emoticons/default/pray.gif)
any new projects? @ goth. spray lizard skin first. then put on matting. it must be sprayed on primer or paint. Jeggs has it cheap. the gun is really cheap. Also, for what you are doing, you might want to find somebody to go in with you and share the product. It comes in 2 gallon containers. |
audio_file |
Member ![]() ![]() Group: Members Posts: 295 Joined: 6-August 11 From: Everett, Wa Member No.: 13,409 Region Association: Pacific Northwest ![]() |
Looking great man! If you need an extra pair of hands for anything, shoot me a pm, I'm close!
(IMG:style_emoticons/default/beerchug.gif) the other Chris in Everett... |
jcambo7 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,691 Joined: 24-December 08 From: Graham, WA Member No.: 9,867 Region Association: Pacific Northwest ![]() |
Sweet! Finally! (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/popcorn[1].gif)
gothspeed |
................. @ goth. spray lizard skin first. then put on matting. it must be sprayed on primer or paint. Jeggs has it cheap. the gun is really cheap. Also, for what you are doing, you might want to find somebody to go in with you and share the product. It comes in 2 gallon containers. Ok so the lizard skin must go on pretty smooth then? ........ if so, what you recommend sounds like a good aproach ..... the deadener mat I will be using is the damplifier pro ................ thanks man!! (IMG:style_emoticons/default/beerchug.gif) |
Ferg |
@ Ferg! (IMG:style_emoticons/default/pray.gif) any new projects? @ goth. spray lizard skin first. then put on matting. it must be sprayed on primer or paint. Jeggs has it cheap. the gun is really cheap. Also, for what you are doing, you might want to find somebody to go in with you and share the product. It comes in 2 gallon containers. No projects, just watching you guys hammer out some sweet 914's. I'll buy one soon enough... Ferg |
effutuo101 |
................. @ goth. spray lizard skin first. then put on matting. it must be sprayed on primer or paint. Jeggs has it cheap. the gun is really cheap. Also, for what you are doing, you might want to find somebody to go in with you and share the product. It comes in 2 gallon containers. Ok so the lizard skin must go on pretty smooth then? ........ if so, what you recommend sounds like a good aproach ..... the deadener mat I will be using is the damplifier pro ................ thanks man!! (IMG:style_emoticons/default/beerchug.gif) Not really. It depends on how you adjust the fun. It goes on a lot like Rhino with a serious texture. Not smooth like paint. More like a textured wall in your house. |
mrbubblehead |
Twodollardoug ![]() ![]() ![]() Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California ![]() |
nice work chris, how did you attach the fiberglass to the steel? i see the clecoes, but i asume those are for alingment of the panels...
Socalandy |
Its got to be Yellow!!! ![]() ![]() ![]() ![]() Group: Members Posts: 2,432 Joined: 29-August 09 From: Orange Member No.: 10,742 Region Association: Southern California ![]() ![]() |
Very cool
effutuo101 |
There is an adhesive that has to go on bare metal and the fiberglass. I will ping Jon for the name. Once set it has to be ground off. It has a dual piston calking gun that mixes the chemicals as you pump the trigger
PeeGreen 914 |
Just when you think you're done...wait, there is more..lol ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest ![]() ![]() |
I don't recall what it's called. One of my good friends that runs an autobody supply shop told us what to use for this.
Gint |
Mike Ginter ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,096 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains ![]() ![]() |
That's killer Chris! How ya doin?
Lo-Fi Version | Time is now: 19th April 2025 - 12:25 PM |
