effutuo101 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,735 Joined: 10-April 05 From: Lemon Grove Member No.: 3,914 Region Association: Southern California ![]() |
I will have to dig up the link. It is earlier in the thread somewhere.
They were pretty easy to fit, but a slight mistake on the passengers side is going to be difficult to fix. Also, they do come with LED turn indicators. Pretty cool. |
sixnotfour |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,791 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains ![]() ![]() ![]() |
effutuo101 |
Thanks Jeff!
CptTripps |
:: Punch and Pie :: ![]() ![]() ![]() ![]() Group: Members Posts: 3,585 Joined: 26-December 04 From: Tuscaloosa, AL and Akron, OH Member No.: 3,342 Region Association: Upper MidWest ![]() |
I need to look and see if those would be easier to work with than the ones I have from the Pontiac. I'll need to make sure both sides are modified EXACTLY the same. The VF4s may be a lot easier in the long run.
Great tip. Thanks! |
Chris H. |
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,054 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest ![]() ![]() |
Hey there's an LED turn signal version...sweet. Really increases visibility. I'm afraid to take my side markers off until I get something like that since I live in a congested area.
CptTripps |
Adding LEDs is SUPER easy. I have a kit I'll send you if you want. I bought an extra. All you need to do is hit the mirror with a heat gun, remove the glass, tape these things into place, and then replace the glass. The LEDs shine through really easily.
PM me your address Chris. Attached thumbnail(s) ![]() |
Chris H. |
Cool! Thanks man.
effutuo101 |
Doug, you are very generous. I already owe you (IMG:style_emoticons/default/beer3.gif) I actually decided some time ago to put a small 911 style light on the front fender (like my 2nd 914). Thank you for the offer! Attached thumbnail(s) ![]() |
effutuo101 |
Ok, So, work, life and everything got in the way and it is finally time to get going.
Engine harness, relay's and computer are ready to pick up. Also ready is my re enforced and shortened (by 2 inches and steel plate added) oil pan. Then S&S will come down and make final measurements and make braided oil and water lines for my turbo and provide me block off for unused holes in head. To do: add oil to motor and trans. get AN fittings put on the fuel rails Get half shafts completed New exhaust built (the current one hangs down to far) to the turbo. Front brake pads and retainers Start car for the first time...ever. Coming soon: new rear adjustable shocks Peddle cluster bleed out brake and clutch finish up throttle cable. Finalize turbo back exhaust Gauges and pod. Cooling system This should put me at a point where I can at least drive the thing. blegh. It is all money now. |
effutuo101 |
hmmm, a few parts showed up today!
Oil pan shortened 1.75 inches Stinger wireing harness, computer and base program for 2.5L turbo with G20 turbo (tuning time to come later) I guess I know what I will be doing next week! Attached thumbnail(s) ![]() ![]() |
CptTripps |
Way to go man. Let's get yours started so I'm inspired to do the same with mine!
effutuo101 |
Old vs new oil pan depth.
The pictures are dark, but, the new pan now sits level with the floor. Time to get rid of my old (brand new) exhaust and get a custom header. If you are running the newer version of Ian's cradle that uses the stock engine mounts, the engine sits a bit higher, the exhaust should work great. PM me if you are interested. Attached thumbnail(s) ![]() ![]() ![]() |
swooshdave |
Member ![]() ![]() Group: Members Posts: 184 Joined: 11-June 14 From: Portland Member No.: 17,475 Region Association: Pacific Northwest ![]() |
(IMG:http://www.914world.com/bbs2/uploads/post-3914-1389739607_thumb.jpg)
Looks like a /5 sitting back there... |
effutuo101 |
LOL! my wife's /6 with euro tank. 1975! Maybe she will ride it again...
CptTripps |
Can you post a few more pics of the BOV area?
I've decided to mimic your setup for the intercooler. Seems like the best option for me. I'll still mount the radiator for it under the car though. See if I can retain SOME of the trunk space. (IMG:style_emoticons/default/smile.gif) |
CptTripps |
Alright Chris....you and I need to get off dead-center and finish our cars.
I propose we switch. You move to Cleveland for a month to work on mine, and I'll move to SoCal for a month and finish yours. Deal? |
effutuo101 |
LOL! Right?
Got my new clutch install with my wife this last Monday and am now waiting on my half shafts to get finished. Tell you what, my car is headed up the hill as soon as shop space opens to get the radiator work done. Ther will be space in the garage for yours. Bring it and we will get both on the road. The weather is much better here! |
sixnotfour |
QUOTE The weather is much better here! word |
effutuo101 |
914werke |
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,211 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest ![]() ![]() |
QUOTE my car is headed up the hill as soon as shop space opens to get the radiator work done & the fun begins!...Love that color. (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 20th April 2025 - 12:41 AM |
