effutuo101 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,735 Joined: 10-April 05 From: Lemon Grove Member No.: 3,914 Region Association: Southern California ![]() |
Got these foodies in the mail. Thank you PMB!
Attached thumbnail(s) ![]() |
effutuo101 |
Life got in the way. Back to incremental progress!
Rear brake and clutch lines all run. Peddle cluster mounted. Have to get another clutch soft line made. Incorrect fitting on one side. Now on to the front brake lines and a couple of block off plates to tidy things up. Brake/clutch Fluid resivior mounted and lines run. Built the last segment of my fuel line. That goes in tomorrow after coffee. New seat brackets are exactly what the doctor ordered! I will post some pictures once I tidy up. |
effutuo101 |
Peddle cluster in and mounted. Brake fluid in the rear brake and clutch lines and resiviors. Time to ramp up the pressure, check for leaks and see what else needs done.
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,698 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
Looking good. Your pretty damned close now. Been sitting in it making Vroom noises yet? (IMG:style_emoticons/default/beerchug.gif)
effutuo101 |
Hahaha! Nope! But the wife wants to know when it will be ready to drive. She gives me grief about how long this has taken. I think she wants to drive it more than I do! (IMG:style_emoticons/default/biggrin.gif)
76-914 |
Hahaha! Nope! But the wife wants to know when it will be ready to drive. She gives me grief about how long this has taken. I think she wants to drive it more than I do! (IMG:style_emoticons/default/biggrin.gif) That's the nice thing about a conversion. Anyone can drive your car. No more pre-drive conversations of "do this, don't do that". After I got mine sorted, I handed the keys to my BiL and told him to depress the clutch when starting and to drive it. He's 70 and loved it. If he drove my stock 914 he'd have needed a 1 hour forum before hand. (IMG:style_emoticons/default/lol-2.gif) |
theer |
Senior Member ![]() ![]() ![]() Group: Members Posts: 691 Joined: 31-July 15 From: Dover, MA Member No.: 19,014 Region Association: North East States ![]() ![]() |
More center console.just a couple of things to sort it for wiring. 1 more fitting and the fuel lines are done! Then on to finishing up the tank ( had to go back to stock location and tank). Then pressurize and test. Nice! Where did you find those center console switches? |
effutuo101 |
Ha! West Marine. The come in grey and can be painted.
https://www.westmarine.com/?Ntt=blue+sea+switch+panel Blue sea will build to specification and color if you want to. |
effutuo101 |
There be clutch and rear brake pressure! I don’t know how many years since the car last had brakes as I got it as a shell.
Amenson |
That's opposite lock!! ![]() ![]() ![]() Group: Members Posts: 645 Joined: 27-May 05 From: Dublin, OH Member No.: 4,154 Region Association: None ![]() ![]() |
Keep up the progress, the beauty will be on the road in no time.
Cheers, Scott |
effutuo101 |
Front brakes installed and pressure tested. Still have to get them rebuilt, but it can’t go to get dyno work with out brakes.
Next x fuel level sending unit and evaporate tank. |
jcambo7 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,691 Joined: 24-December 08 From: Graham, WA Member No.: 9,867 Region Association: Pacific Northwest ![]() |
Front brakes installed and pressure tested. Still have to get them rebuilt, but it can’t go to get dyno work with out brakes. Next x fuel level sending unit and evaporate tank. (IMG:style_emoticons/default/beerchug.gif) I'm looking forward to the finale! I finally got my 914 dialed in quite well. Hopefully I can keep her running longer and drive her more this year! |
effutuo101 |
Front brakes installed and pressure tested. Still have to get them rebuilt, but it can’t go to get dyno work with out brakes. Next x fuel level sending unit and evaporate tank. (IMG:style_emoticons/default/beerchug.gif) I'm looking forward to the finale! I finally got my 914 dialed in quite well. Hopefully I can keep her running longer and drive her more this year! Sweet! Hope to her this beast start mid month. It all depends on work, schedules and coin. |
Ferg |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None ![]() ![]() |
Good news, I want a ride when it's done and I'm not getting any younger (IMG:style_emoticons/default/shades.gif) (IMG:style_emoticons/default/laugh.gif)
effutuo101 |
Good news, I want a ride when it's done and I'm not getting any younger (IMG:style_emoticons/default/shades.gif) (IMG:style_emoticons/default/laugh.gif) Ha! My wife said the same thing! She asked if I, when working late, sit in the car and make vroom vroom noises. |
914work |
Member ![]() ![]() Group: Members Posts: 291 Joined: 9-November 11 Member No.: 13,762 Region Association: None ![]() |
Ha! My wife said the same thing! She asked if I, when working late, sit in the car and make vroom vroom noises. I figured that was a given! (IMG:style_emoticons/default/biggrin.gif) |
effutuo101 |
Thank you Rich for the fuel level sender! I so owe you!
One step forward two steps back! Finally back to where I was a month ago. 3 more boxes of stuff sorted through and either put in play or repacked for a future day. Nothing more I own will go on the car. From here on out is it fabrication time. And all motor/cooling related. Post build list is being thought about. 1. Have Eric refresh all brakes ( just to be 100% on them.) 2. rear cross drilled disks 3. cross drilled vented front disks It is really odd seeing the car on the roller jacks and not be missing any pieces... |
914work |
effutuo101 |
Rear brakes ordered.
Battery location changed. Battery tray mints, new cables run, cables connected. Transmission oil done. Removed oil heater and installed filter. Removed collant lines that ran to the oil filter. Engine oil done. A few minor odds and ends that I am waiting for from the welder. Then fuel and coolant. Swapping my side intakes and mirrors. Almost time to pressure test all fluid systems. |
76-914 |
What the Hell? (IMG:style_emoticons/default/poke.gif) Did your camera break? (IMG:style_emoticons/default/confused24.gif) We demand pics of these conversions. (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 19th April 2025 - 05:49 PM |
