8 Pages V « < 4 5 6 7 8 >
> Group Buy for 4 channel CHT Gauge Kit, ---ARRIVED--- Shipping Thursday 4/26/12
mrbubblehead
post Apr 5 2012, 11:15 AM
Post #101
Twodollardoug
i found a cool angled mounting plate for the gauge. http://www.aircraftspruce.com/catalog/inpa...angledmount.php
falconfp2001
post Apr 5 2012, 11:35 AM
Post #102
Pancho Pantera
QUOTE(rwilner @ Apr 5 2012, 06:34 AM) *
QUOTE(falconfp2001 @ Apr 4 2012, 09:36 PM) *
Just purchased online the panel for mounting the gauge. Hopefully everything is timely.
which one did you get?
I got the three panel that you listed earlier. they show a single and a double on the site so we will see what they send. I'll mount a single on top of the tunnel or maybe the double off the ashtray mount where I have the O2 gauge. I'll have to make a plug for the O2 gauge to fit the larger hole but I think Aircraft Spruce may sell that also.
mrbubblehead
post Apr 5 2012, 11:38 AM
Post #103
Twodollardoug
QUOTE(falconfp2001 @ Apr 5 2012, 10:35 AM) *
they do. they make an adapter. i saw it when i was browsing.
rwilner
post Apr 5 2012, 12:59 PM
Post #104
No Ghosts in the Machine
QUOTE(mrbubblehead @ Apr 5 2012, 01:15 PM) *
I saw this thing too. This reduces the 3 1/8" opening to a 2 1/4" opening, so it won't place our new CHT gauges at an angle the way I think you're expecting.
mrbubblehead
post Apr 5 2012, 01:02 PM
Post #105
Twodollardoug
QUOTE(rwilner @ Apr 5 2012, 11:59 AM) *
your right, thanks. i need to call and cancel. dont know how i missed that.
falconfp2001
post Apr 5 2012, 01:47 PM
Post #106
Pancho Pantera
How hard is it to remove tin with the engine in?
rnellums
post Apr 5 2012, 03:40 PM
Post #107
Professional Enthusiast
No cake walk, But it can be done. Of course last time I did it the engine had carbs, and i didn't care about scratching the cooling tin or bending it a bit...
rwilner
post Apr 6 2012, 07:36 AM
Post #108
QUOTE(falconfp2001 @ Apr 5 2012, 03:47 PM) *
having done this recently I think it would probably take less time to remove the engine to remove the tin than to attempt tin removal with the engine installed...especially if you still have the slotted cheeseheads. You are guaranteed to strip at least one.
Removing the engine is no big deal. The challenge is putting it back in...not because reinstallation is tough, but because when the engine is out, you're going to find 10,000 other things to do!
"While I'm in there" -- the 4 scariest words for any teener owner.
Just my opinion (IMG:style_emoticons/default/biggrin.gif)
Jake Raby
post Apr 6 2012, 07:46 AM
Post #109
Engine Surgeon
You guys are blowing this one up way bigger than it needs to be. Its not that difficult to do at all.
ww914
post Apr 6 2012, 08:25 AM
Post #110
914 Convert
QUOTE(Jake Raby @ Apr 6 2012, 06:46 AM) *
Maybe not for the experienced guy who has done it many times, but it might be a challenge to the first timer. I have dropped mine twice now and installed it once. I think I would opt to drop it for the tin thing.
And yes, figure on doing many other things if you drop the engine. That is an absolute for sure statement.
Jake Raby
post Apr 6 2012, 08:50 AM
Post #111
Engine Surgeon
Its just common sense and patience. If you lack both of those, I'd not even try it.
VaccaRabite
post Apr 6 2012, 08:52 AM
Post #112
En Garde!
On the 3/4 side, as mentioned, you can run through the existing hole for the CHT, which should have a grommet in place already. This is how I did mine when I was only probing #3. The 1/2 side going under may be best - I trust Chris on that. As I have not done it yet I can't say the best way.
If you engine is dropped, this is really easy.
My heads are off already, so I will do a little grinding to make install and removal easier. #3 already had this done, not hard at all. In the past I have removed that washer from the spark plug on the sensor plug. I don't know that you HAVE to do it, but I did.
rwilner
post Apr 6 2012, 09:23 AM
Post #113
QUOTE(Jake Raby @ Apr 6 2012, 10:50 AM) *
Jake
What are you talking about? Not try what?
jsayre914
post Apr 6 2012, 10:15 AM
Post #114
Speed Up !!!
Got word from MGL yesterday, they said our order will be shipped within the next 10 days or less (IMG:style_emoticons/default/sad.gif) They are a little behind.
Looks like it pushes us back a week (IMG:style_emoticons/default/headbang.gif)
Stay positive. He did say "or less" (IMG:style_emoticons/default/biggrin.gif)
p.s. The order for the gauges was placed 3/22/12 and paid in full
falconfp2001
post Apr 6 2012, 01:00 PM
Post #115
Pancho Pantera
Just got my Panel mount for the gauge from Aircraft Spruce.
http://www.aircraftspruce.com/catalog/inpa...instpnlbrkt.php
Here are some picks of it. It is a single gauge panel. I don't know exactly how I'm going to mount it but I may just mount it off the ash tray.
falconfp2001
post Apr 6 2012, 01:03 PM
Post #116
Pancho Pantera
QUOTE(falconfp2001 @ Apr 6 2012, 12:00 PM) *
Anyone know where I can get the CHT grommet?
Rand
post Apr 6 2012, 01:05 PM
Post #117
Cross Member
QUOTE(falconfp2001 @ Apr 6 2012, 12:03 PM) *
Any decent hardware store. Just measure the hole diameter. Doesn't need to have a Porsche part# (IMG:style_emoticons/default/tongue.gif)
http://www.harborfreight.com/180-piece-har...-set-67582.html
mrbubblehead
post Apr 6 2012, 01:44 PM
Post #118
Twodollardoug
QUOTE(jsayre914 @ Apr 6 2012, 09:15 AM) *
mine is on back order also.
ww914
post Apr 6 2012, 01:55 PM
Post #119
914 Convert
....or you can get almost any size grommet you want from these guys
VaccaRabite
post Apr 7 2012, 04:09 PM
Post #120
En Garde!
The CHT grommet is special and has a little flap to keep in the cooling air.
39 User(s) are reading this topic (39 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 27th November 2024 - 06:36 AM
