8 Pages V < 1 2 3 4 > »
> Group Buy for 4 channel CHT Gauge Kit, ---ARRIVED--- Shipping Thursday 4/26/12
Jake Raby
post Mar 17 2012, 11:24 AM
Post #21
Engine Surgeon
I am in for one, need to update the westach unit on the engine dyno. How about 12mm senders? We don't use 14mm plugs here.
rwilner
post Mar 18 2012, 06:54 AM
Post #22
No Ghosts in the Machine
Are we at 10 yet?
falconfp2001
post Mar 18 2012, 10:36 AM
Post #23
Pancho Pantera
QUOTE(rwilner @ Mar 18 2012, 05:54 AM) *
I believe we need two more.
ww914
post Mar 18 2012, 10:43 AM
Post #24
914 Convert
So, where is Michael7810 and Rand? Are you guys not interested anymore?
hot_shoe914
post Mar 18 2012, 10:51 AM
Post #25
on ramp passer
I talked to Mary Shortridge this morning, she may be interested. She is going to check it out.
mrbubblehead
post Mar 18 2012, 11:49 AM
Post #26
Twodollardoug
just a heads up, dakota digital sells 18 foot 14mm type k tc's for $26.00
if someone had a line on 14mm ring terminals, the tc's are super simple to make.
i'll price the type k wire at work tomorrow. i bet i could make them for 5 bucks a piece.
mrbubblehead
post Mar 18 2012, 11:54 AM
Post #27
Twodollardoug
and since cold junction isnt an issue, we could put nice little quick disconnects close to the ring termimal. for easier engine removal. thats how i have mine set up.
mrbubblehead
post Mar 18 2012, 12:01 PM
Post #28
Twodollardoug
checked one price. a 200 ft real of type k is 134.00. of course, the bigger the real the price goes down. i could probley fab 100 tc's in an hour...
ChrisFoley
post Mar 18 2012, 07:11 PM
Post #29
I am Tangerine Racing
A 14mm ring terminal is nothing more than a 1/2" cad plated copper electrical ring terminal with the hole drilled out. A 12mm ring terminal is really a 1/2" ring.
stugray
post Mar 18 2012, 07:38 PM
Post #30
I used to make TCs for the Space sim lab at Lockheed Martin.
To do it right you need to twist the ends and spot weld them with a tiny bench-top welder.
Then we would put the tip in an oven and heat them to ~200C and then dip them in Liquid Nitrogen (-180C), then right back in the oven. If they survived that, they were good to go.
That type would be acceptable for clamping directly under a spark plug once or twice.
I wouldnt trust that much more than that unless you had a "washer" type protective sheath.
If you wanted to make them for EGTs, then they would need a threaded "probe".
Stu
mrbubblehead
post Mar 18 2012, 08:34 PM
Post #31
Twodollardoug
QUOTE(Racer Chris @ Mar 18 2012, 06:11 PM) *
23.00$ for 100 pack
mrbubblehead
post Mar 18 2012, 08:43 PM
Post #32
Twodollardoug
QUOTE(stugray @ Mar 18 2012, 06:38 PM) *
Stu
ya, i didnt use that process when i made mine. i used the ol strip and crimp method. might not be good enough for the space shuttle, but it worked perfectly on my 914. (IMG:style_emoticons/default/beerchug.gif)
jsayre914
post Mar 18 2012, 08:59 PM
Post #33
Speed Up !!!
so far i see......
1) jsayre914
2) ww914
3) rwilner
4) rnellums
5) Vacca Rabite
6) falconfp2001
7) Racer Chris
8) Jake Raby
9)
10)
2 more guys (IMG:style_emoticons/default/piratenanner.gif)
jsayre914
post Mar 18 2012, 09:08 PM
Post #34
Speed Up !!!
QUOTE(mrbubblehead @ Mar 18 2012, 01:49 PM) *
Thanks for the offer, but I really like the company I have already chosen. They have an excellent reputation. If anybody would like to back out of the group buy and purchase the guage direct and sensors from mrbubblehead, just send me a pm and I will remove you from the list. (IMG:style_emoticons/default/beerchug.gif)
(IMG:style_emoticons/default/flag.gif)
tadink
post Mar 18 2012, 10:26 PM
Post #35
somewhat interested but where would you mount the thing? anyone have any pix of an idea about where to put it? thx td
plas76targa
post Mar 19 2012, 06:12 AM
Post #36
Joe,
I'll go in for one of these sensor kits. that gets you closer to 10 !
PM me when to send moola.
rnellums
post Mar 19 2012, 06:49 AM
Post #37
Professional Enthusiast
QUOTE(tadink @ Mar 19 2012, 12:26 AM) *
I was thinking about modifying the dash and mounting it where my heater controls are.
ww914
post Mar 19 2012, 08:15 AM
Post #38
914 Convert
I am going to install a center console and replace the clock.
jsayre914
post Mar 19 2012, 09:23 AM
Post #39
Speed Up !!!
ONLY NEED 1 MORE TO MAKE THIS HAPPEN TODAY !!! (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif)
1) jsayre914
2) ww914
3) rwilner
4) rnellums
5) Vacca Rabite
6) falconfp2001
7) Racer Chris
8) Jake Raby
9) plas76targa
10)
(IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/popcorn[1].gif)
jsayre914
post Mar 19 2012, 09:39 AM
Post #40
Speed Up !!!
I did a quick photochop of where I am going to put it.
- Lo-Fi Version Time is now: 27th November 2024 - 03:52 AM
