4 Pages V < 1 2 3 4 >
> Rear Trunk Cable Release, Pop your trunk from inside the car
Kevin Phillips
post Jul 3 2005, 07:14 PM
Post #21
Hi,
I put in your kit but I think I have the latch lined up funny. It
sticks a bit and unless my kids or wife assist with the lid it can't lift.
Any ideas on how to adjust the two latch parts.
I remember you are an engineer and have a way with things mechanical.
I, on the other hand, am just a musician.
Thanks for any advice.
kp
Engman
post Jul 3 2005, 07:49 PM
Post #22
Zoisite
Take the release portion off of the cable and check to see that the lever moves freely between the two halves. Lossen the bolt if necessary and or pry the two halves apart some if needed. The lever was checked here for this, but perhaps it needs some minor adjustment.
The oyther possibility is your spring on the latch located on the trunk lid latch. This may be too tight. It is adjustable.
Let me know what you find.
M
montoya 73 2.0
post Jul 7 2005, 04:02 PM
Post #23
Lack of consideration to others, and Selfish!
i have the same exact problem, but i have a question. does the trunk need to release (pop-up) a little to allow the catch to clear? my trunk doesn't do that so when i pull the release and then let it go, it re-catches. not to mention it looks like someone put some weld on the catch to build it up. should i file it down?
Engman
post Jul 7 2005, 05:33 PM
Post #24
Zoisite
Check a couple of things...
1. Rear hood pin alignment - this is adjustable.
2. The 'catch' located in the rear trunk lid is adjustable also up and down - it is screwed in and there is a nut on the back. You may have it either too loose or too tight.
It really sounds like the problem is in this area.
M
montoya 73 2.0
post Jul 7 2005, 05:37 PM
Post #25
your kit was installed in about 20 minutes. it's great, i love it! i recommend it highly. i agree on the problem being in that area. so is the trunk supposed to pop-up a little to allow the pin to clear? i always had to push the button and lift at the same time to open the trunk.
Engman
post Jul 7 2005, 06:59 PM
Post #26
Zoisite
Yep it will pop up - but only a little - just enough for the latch to clear the catch.
Still have 2.
M
montoya 73 2.0
post Jul 7 2005, 07:06 PM
Post #27
i guess my springs are sprung? my trunk doesn't do that. will have to replace. thanks again! your kit went in with no problems! my car has the problem!
Kevin Phillips
post Jul 7 2005, 09:19 PM
Post #28
M[/QUOTE]
[/QUOTE]Take the release portion off of the cable and check to see that the lever moves freely between the two halves. Lossen the bolt if necessary and or pry the two halves apart some if needed. The lever was checked here for this, but perhaps it needs some minor adjustment.
The mechanism works great. It is binding up because the top is not lined up. If I take it off the lidd and press it in it will fly when I pull the magic nob. I have something out of line.
kp
Engman
post Sep 29 2005, 06:25 AM
Post #29
Zoisite
I have been able to purchase some of the componets in smaller lot sizes, sooooo these will be back in 4-6 weeks.
I do have 1 left currently.
M
WRX914
post Oct 27 2005, 11:38 AM
Post #30
2.5 WRX STI hybrid powered beast
I have bought two items from Mark, the trunk cable release, and the third stop light. Both items are what the doctor ordered! Mark is a honest man, he delivers exactly what he advertises... Great products Mark!
You da Man!
Keith
(IMG:http://www.914world.com/bbs2/html/emoticons/clap.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/pray.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/aktion035.gif)
Engman
post Nov 28 2005, 03:23 PM
Post #31
Zoisite
Cables arrived!
Back in production!
M
914LUST
post Aug 26 2006, 07:19 PM
Post #32
QUOTE(Engman @ Nov 28 2005, 02:23 PM) *
Cables arrived!
Back in production!
M
Hi -
Do you have any stock? My solenoid just died and untimely death... if yes, how much and lead time?
Thanks,
Rich (IMG:style_emoticons/default/smile.gif)
Engman
post Sep 1 2006, 11:07 AM
Post #33
Zoisite
PM sent
I have these in stock. As well as all of my other stuff as well.
M
zeetas
post Oct 15 2006, 11:27 PM
Post #34
Hi,
Do you have any of these left I am interested in buying one.
Thanks (IMG:style_emoticons/default/driving-girl.gif)
Engman
post Oct 16 2006, 07:00 AM
Post #35
Zoisite
Yes - PM or email me.
Thanks
Mark
iamchappy
post Nov 9 2006, 09:35 PM
Post #36
It all happens so fast!
One please, PM'ed
Chap
FB914
post Nov 10 2006, 11:05 PM
Post #37
74 alaska blue 2.0
QUOTE(iamchappy @ Nov 9 2006, 07:35 PM) *
One please, PM'ed
Chap
If you still have one left, I'd like to buy it. Thanks
Frank B
Engman
post Nov 12 2006, 02:38 PM
Post #38
Zoisite
PM's sent.
I have several of these currently in stock.
stepuptotheMike
post May 8 2010, 08:45 AM
Post #39
medium pimpin
Are these still available?
Mike
my928s4
post May 12 2010, 08:55 AM
Post #40
Finally got around to needing this and now I cannot see it on the Engman website.
- Lo-Fi Version Time is now: 23rd November 2024 - 07:39 PM
