Rick - I need your help, chassis twist |
jdlmodelt |
Jan 8 2013, 08:20 PM
James D. Lane Group: Members Posts: 345 Joined: 30-November 12 From: Colorado Member No.: 15,210 Region Association: Southwest Region |
Good to follow that thread. I have the problem that the PO messed up my passenger door gap when restoring the hell hole. He welded in the inner wheel house without supporting the longs, so my door gap is 1mm at the top. My plan is to but the car on jack stands. Push the door gap open like you did and then weld in the Engman kit with little heat as possible. (IMG:style_emoticons/default/welder.gif) Do you think that would work, or do I have to cut the longs? (I don’t like that idea (IMG:style_emoticons/default/unsure.gif) ) Peter If there was no chassis stiffening done yet you should be able to move the gap. Once there, be sure to brace it before welding. Don't forget to check the targa top opening as you go. Do I understand that to mean that if there was no chassis stiffening done then there is no cutting to do...just put the power jack in and straighten? |
Lo-Fi Version | Time is now: 17th January 2025 - 12:12 AM |
