How does this target AFR table look?, VE table results after autotune |
falconfp2001 |
Apr 9 2012, 01:19 PM
Pancho Pantera Group: Members Posts: 451 Joined: 5-December 10 From: Downey, CA Member No.: 12,456 Region Association: Southwest Region |
What is the total cable length that comes with the AEM? My Megasquirt is under the dash and the gauge is off the ash tray. I need it to go from the muffler to the dash. Sorry if I'm being a pest. no problem. I think you need only the O2 sensor cable to reach that far, and it will easily reach that far. Even if for some reason it didnt, I believe there is an extension available. The power and signal wires are short but they might reach since your gauge and ECU are so close. If not, they're easy to extend. The AEM website should have specs on the cables. I checked The site and they didn't. I even called but then decided to order it anyway. |
VaccaRabite |
Aug 7 2012, 07:30 AM
En Garde! Group: Admin Posts: 13,542 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Its been a few months. Any updates? This thread is saved as one of my favorites, and should be a classic on FI AFR tuning.
Zach |
rwilner |
Aug 7 2012, 07:42 AM
No Ghosts in the Machine Group: Members Posts: 953 Joined: 30-March 10 From: Boston, MA Member No.: 11,530 Region Association: North East States |
Its been a few months. Any updates? This thread is saved as one of my favorites, and should be a classic on FI AFR tuning. Zach Zach-- I'm glad you found value out of this discussion, it was a fun and intense learning experience for me to tune this FI system. I don't have the tables in front of me, but I did run an autotune session getting the car up to redline in a few different gears. The final table is similar to the one posted earlier in the thread and I haven't touched the spark advance table. I've been running the car with these tables since April -- I've put between 1500 and 2000 miles on the car. I'll post the tables when I get home tonight and have access to the tuning laptop. Even with 10% ethanol gas, my head temps never break 300 in around town driving. The highest I've seen is around 370 for very short periods, that's 90 mph uphill in 5th gear. Note that I'm using premium and put in a dose of the ethanol (Green) stab-il at every fillup. I suspect I would get hotter, but still acceptable head temps with a lower grade of gas. I am very pleased with the performance of the MS system and this AFR table. The AEM UEGO sensor/gauge setup has worked flawlessly from the day I installed it and I highly recommend it. I am averaging about 25mpg combined. I think I could probably tune it to get another 2 or 3 combined mpg but the car is running strong and cool, so I think I'll just leave it alone. I do have some refinements to do in the MS configuration regarding startup and warmup, but those are unrelated to this AFR/head temp discussion. |
pda914 |
Aug 10 2012, 12:23 PM
Newbie Group: Members Posts: 40 Joined: 22-July 10 From: Verona WI Member No.: 11,966 Region Association: None |
Would you be willing to post all your tables? I am about the turn on my megasquirt conversion and your tables should be a lot closer to reality than the standard ones from the tools.
rwilner |
Aug 10 2012, 12:26 PM
Lo-Fi Version | Time is now: 18th September 2024 - 06:28 AM |
