3 Pages V < 1 2 3 >
> 914 transmission disassembly, Step by step, so it can go back together
bondo
post Oct 5 2004, 05:09 PM
Post #21
Once you get the shafts out of the intermediate plate, the two bearing races that were holding them on will fall off. In the picture here, the intermediate plate would go between the shafts and the races on the right (note matching races still on the shaft)
bondo
post Oct 5 2004, 05:11 PM
Post #22
Ok, for a while we'll concentrate on the pinion shaft (that's the shorter one). Remove the other bearing race. To get it to come off you may need to hold the gears and tap the end of the shaft with the brass hammer.
bondo
post Oct 5 2004, 05:16 PM
Post #23
Next is the second tapered washer. The washer is about 6.6 mm thick at its thickest, and the flat side is against 2nd gear. Then remove second gear and it's associated roller bearing and inner race.
bondo
post Oct 5 2004, 05:17 PM
Post #24
Now remove the 2/3 slider and its hub.
bondo
post Oct 5 2004, 05:24 PM
Post #25
Next 3rd gear comes off, with it's roller bearing and inner race.
bondo
post Oct 5 2004, 05:25 PM
Post #26
Then take off the 2.5mm thick flat washer.
bondo
post Oct 5 2004, 05:27 PM
Post #27
Next take off 4th gear. The ridge goes against the spacer.
bondo
post Oct 5 2004, 05:28 PM
Post #28
Now take off the spacer that's between 4th and 5th gears.
bondo
post Oct 5 2004, 05:29 PM
Post #29
Then remove 5th gear (ridge goes twoards spacer)
bondo
post Oct 5 2004, 05:30 PM
Post #30
Now remove the 4.2mm thick flat wahser.
bondo
post Oct 5 2004, 05:33 PM
Post #31
The last thing to come off the pinion shaft is four shims, about 0.3mm thick each. The number and thickness may vary between transmissions.
bondo
post Oct 5 2004, 05:35 PM
Post #32
Now we move on to the input shaft. Clamp it in a vice like this: (make sure you grab the splines well, and don't pinch any gears anywhere.. Gently rotate it back and forth as you tighten the vice so it gets seated tight. Get the vice very tight.
bondo
post Oct 5 2004, 05:37 PM
Post #33
Now pound the locking tab with a screwdriver and a hammer until it flattens out like this:
bondo
post Oct 5 2004, 05:39 PM
Post #34
Here's where the big-ass crecent wrench comes in.. Put it on the nut, and pound until it comes loose. Be sure to pound in line with the vice, like this:
bondo
post Oct 5 2004, 05:42 PM
Post #35
Once you get that nut and locking washer off, take the whole thing out of the vice and flip it over. Hold on to the gears and bearing, especially towards the bottom. Now pick up the whole shaft and lightly drop it on the anvil part of the vice like this: (being ready to catch the stack of bearings, washers and gears that will come loose)
bondo
post Oct 5 2004, 05:54 PM
Post #36
The input shaft parts come off in the following order:
Bearing (flatter side of the brass part towards 5th)
5.9mm thick tapered washer (flat side towards 5th)
5th gear, associated roller bearings and race
4/5 slider and hub
4th gear, associated roller bearings and race
3rd gear (flat side towards washer, ridge towards second gear)
2nd gear does not come off of the shaft, it's part of it.
bondo
post Oct 5 2004, 05:56 PM
Post #37
Whelp, there you have it. I hope this helps people take on their transmission troubles without fear. I will probably add a couple of syncro details later, but this is it for now.
ambergris
post Oct 5 2004, 06:30 PM
Post #38
(IMG:style_emoticons/default/beer.gif) (IMG:style_emoticons/default/aktion035.gif)
Holy cow! Cheers and you rock! Great article, and awesome timing, as I am just starting my own tranny disassembly. Instant classic, I say.
bondo
post Oct 5 2004, 06:46 PM
Post #39
Thanks! Glad to help.
Rusty
post Oct 5 2004, 08:06 PM
Post #40
Wanted: Engine case GA003709
Damn. That's a great article.
I nominate for Classic Thread status. Anyone second me?
-Rusty (IMG:style_emoticons/default/smoke.gif)
3 Pages V < 1 2 3 >
- Lo-Fi Version Time is now: 3rd April 2025 - 08:02 AM
