914-4 Steering Column Bearing replacement, how I did it |
lennyhope |
Oct 26 2016, 01:17 PM
Member Group: Members Posts: 168 Joined: 2-November 11 From: prescot Member No.: 13,736 Region Association: England |
I pulled the steering column, disassembled the shaft and tapped the bearing out. Took an hour to complete. Glad this got bumped; I'm getting ready to do this ! (IMG:style_emoticons/default/smile.gif) Question: I will replacing the the steering shaft housing too; what will it take to pull it off the shaft ? HOW DO YOU PULL THE COLUMN?...WHAT NEEDS TO BE UNDONE? |
euro911 |
Oct 26 2016, 05:30 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,858 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
HOW DO YOU PULL THE COLUMN?...WHAT NEEDS TO BE UNDONE? IIRC, this is how I did mine:Remove the steering wheel. Remove the circlip from the shaft Remove the lower dash pad Unscrew the steering column support (two Allen screws) Remove the ignition and stalk wiring plugs from behind the support Pull the support off of the shaft |
jim_hoyland |
Oct 26 2016, 05:41 PM
Get that VIN ? Group: Members Posts: 9,515 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
HOW DO YOU PULL THE COLUMN?...WHAT NEEDS TO BE UNDONE? IIRC, this is how I did mine:Remove the steering wheel. Remove the circlip from the shaft Remove the lower dash pad Unscrew the steering column support (two Allen screws) Remove the ignition and stalk wiring plugs from behind the support Pull the support off of the shaft So it's gonna slide right up and off... (IMG:style_emoticons/default/smile.gif) |
euro911 |
Oct 26 2016, 08:14 PM
So it's gonna slide right up and off... (IMG:style_emoticons/default/smile.gif) Pretty much. I forgot to mention that there's a couple of plastic tubes for the windshield squirter nozzles that need to be disconnected from the stalk too. |
jim_hoyland |
Oct 26 2016, 08:23 PM
So it's gonna slide right up and off... (IMG:style_emoticons/default/smile.gif) Pretty much. I forgot to mention that there's a couple of plastic tubes for the windshield squirter nozzles that need to be disconnected from the stalk too.Thanks Mark. |
jim_hoyland |
Oct 27 2016, 05:11 PM
Got a question: I have two bearings, the larger bearing goes on the top as previously discussed. Where does the smaller bearing fit ? The housing doesn't have a recessed area for the smaller bearing like top top one.
euro911 |
Oct 27 2016, 05:56 PM
jim_hoyland |
Oct 27 2016, 07:35 PM
Hmmm.....looks like The Who assembly would have to be pulled to install the smaller Bearing (2) ?
euro911 |
Oct 28 2016, 01:38 AM
I only replaced the one closest to the steering wheel. It cleaned up a lot of the free-play (IMG:style_emoticons/default/smile.gif)
Aualexa1 |
Jul 3 2020, 10:18 PM
Newbie Group: Members Posts: 45 Joined: 17-June 17 From: South Jersey Member No.: 21,189 Region Association: MidAtlantic Region |
HOW DO YOU PULL THE COLUMN?...WHAT NEEDS TO BE UNDONE? IIRC, this is how I did mine:Remove the steering wheel. Remove the circlip from the shaft Remove the lower dash pad Unscrew the steering column support (two Allen screws) Remove the ignition and stalk wiring plugs from behind the support Pull the support off of the shaft Bringing back an old thread. My wheel has a decent amount of play in all directions. A previous owner has already put the metal repair bushing, but its the actual bearing where the motion is. Trying to clarify how to remove the old bearing. Where it says "pull the support off the shaft" the "support" is the shaft cover tube and the housing. Is that correct? And when you remove those things, the bearing will come off with the shaft cover tube and then you press it out, reinstall the cover tube, and press in the new bearing? Edit: Figured it out. The support is just the black surround piece on the steering column. Slides off with some force after undoing the Allen bolt underneath. |
Aualexa1 |
Jul 4 2020, 06:41 PM
Here’s a link to another description of this project. Shows the complete removal of the steering shaft support as well as replacement of the lower bearing.
http://www.performanceforum.com/wesvann/91...ing-column.html |
cassmcentee |
Jul 5 2020, 07:28 AM
Member Group: Members Posts: 219 Joined: 12-July 18 From: Squaw Valley, CA Member No.: 22,304 Region Association: Central California |
Couple pics of mine that I just finished...
Hope it helps... |
wolfswest |
Jan 23 2024, 06:32 AM
Newbie Group: Members Posts: 8 Joined: 24-November 21 From: Belgium Member No.: 26,104 Region Association: Europe |
Hi,
in the first post is mentioned: Upper Steering Shaft Bearing, 914 1.7/1.8/2.0 (1972-76) prt# 911-347-771-02-M100 => does this mean that a '69- '71 uses another type of bearing? If so, any details on that part? It's seems that the early cars use lot's of different parts and not every distributor knows this or documents this, it's frustrating... THANKS ALOT! |
930cabman |
Jan 24 2024, 11:00 AM
Advanced Member Group: Members Posts: 3,695 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
Looks straightforward, I have been wiggling my steering wheel for years, maybe there is an easy fix.
Looks like pulling the upper column is the answer Thanks all |
Lo-Fi Version | Time is now: 23rd November 2024 - 10:25 PM |
