rwilner |
No Ghosts in the Machine ![]() ![]() ![]() Group: Members Posts: 953 Joined: 30-March 10 From: Boston, MA Member No.: 11,530 Region Association: North East States ![]() |
surprised no one has mentioned hex sockets / allen keys -- you'll need those to remove the pedal board (5mm IIRC) or install a backed-out cone screw (4mm).
mrbubblehead |
Twodollardoug ![]() ![]() ![]() Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California ![]() |
surprised no one has mentioned hex sockets / allen keys -- you'll need those to remove the pedal board (5mm IIRC) or install a backed-out cone screw (4mm). i made my own cone screws with hex head bolts, drilled and saftey wired. no more of those dang cone screws (IMG:style_emoticons/default/barf.gif) . |
Woody |
Sandbox Rabblerouser and head toilet scrubber ![]() ![]() ![]() ![]() Group: Members Posts: 3,858 Joined: 28-December 10 From: San Antonio Texas Member No.: 12,530 Region Association: Southwest Region ![]() |
I carry fuses and the associated tools to change em out. (IMG:style_emoticons/default/confused24.gif) "Associated tools to change em out"? What, like a few spare fingers? The Cap'n Yeah so?? (IMG:style_emoticons/default/beer3.gif) |
larss |
Member ![]() ![]() Group: Members Posts: 428 Joined: 10-September 09 From: Sweden Member No.: 10,787 Region Association: Scandinavia ![]() |
On longer trips I have quite a few tools and spare parts in the trunk, some of them are:
-Socket set 100pcs WITH socket for CV joint -Multimeter -Jackstand -Gloves -Carpet piece to lay down on -Bolts, nuts, washers -Terminals male/female -Tie raps -Tape -Fuel hose -Fuel hose clamps -Breaker points -Condensator -Ignition coil -Spark plug -Alternator belt -Alternator relay -Injection valve -ECU -Fuel pump -MPS -Resistor (potentiometer) that can replace any temp sensor -CV Joint -Engine oil -Starter cables -Nippers, knife -Polygrip tonge Still there is room in the front trunk to take some additional luggage! /Lars S (IMG:http://www.914world.com/bbs2/uploads_offsite/www.lsmteknik.se-10787-1338546460.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/www.lsmteknik.se-10787-1338546462.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/www.lsmteknik.se-10787-1338546465.3.jpg) |
type47 |
Viermeister ![]() ![]() ![]() ![]() Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region ![]() |
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,113 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
for a long trip, a known to be good bulb for the generator warning light and at least one known to be good round relay.
CrashDown |
Fake Carbon Fiber MASTA! ![]() ![]() Group: Members Posts: 159 Joined: 8-June 09 From: Union City, CA Member No.: 10,453 Region Association: Northern California ![]() |
Flathead screwdriver, fire extinguisher, extra oil, generator blub, fuses. And latest edition of Playboy + 2-4hrs of porn loaded on my Nook Tablet. Ya know, incease I have to wait for the Tow Truck driver.
Lo-Fi Version | Time is now: 25th June 2024 - 05:06 PM |
