Cary's 73 1.7 Rustoration Thread |
cary |
Dec 10 2012, 10:34 AM
Off to more spot weld drilling.
Taking off the outer console today. Hopefully my little tool store will have some 1/4, 5/16 and 3/8 replacements for my RotaCut spot weld cutter. If they don't, he'll order them for me. They broke because I got pissed that my HF cutter wasn't cutting deep enough. So I tried to recut with the better cutter. Caught an edge and it snapped off. (IMG:style_emoticons/default/sad.gif) It looks to be a copy of the Blair. He has Blair replacements for the standard (NAPA,HF) cutter on the shelf. So he can probably get both. One more cup of coffee and off we go. |
cary |
Dec 10 2012, 10:38 AM
Oh yeah,
The replacement drivers long is coming together. And I have another member working on a pair of engine mounts also. Inch by inch ............. Shooting to be done by the WCR in June. |
FourBlades |
Dec 10 2012, 11:22 AM
From Wreck to Rockin Group: Members Posts: 2,056 Joined: 3-December 07 From: Brevard, FL Member No.: 8,414 Region Association: South East States |
Nice work! You are getting there. Should be good for another 40 years. John |
cary |
Dec 10 2012, 09:41 PM
Thanks John ..............
After the stop at the tool store. Last picture shows the broken 3/8 cutter. The shop was out of 3/8, but I did get the 1/4 and 5/16's. Spent $20 on each package of refills. If I remember correct. I think the original kit was about $80. |
cary |
Dec 10 2012, 09:45 PM
Here's where we started today ............... Outside half of the suspension console.
Cart full of weapons ............. |
wingnut86 |
Dec 10 2012, 09:49 PM
...boola la boo boola boo... Group: Members Posts: 1,053 Joined: 22-April 10 From: South Carolina Member No.: 11,645 Region Association: South East States |
Hah!
And my wife complains when I have 2 a/c grinders, 2 portable drills and 3 or 4 air tools on my tool cart... I'm sharing your image with her (IMG:style_emoticons/default/biggrin.gif) |
cary |
Dec 10 2012, 10:03 PM
First reinforcement is removed ...........
What I found was, it seems its best to cut out the material. Then come back and cut and grind off the weld. The trick being not cut into the piece underneath. Missed a couple spots. But I'm getting the hang of it. Be patient. Seems I'm using the cuttings wheels and grinder in all kinds of positions. |
cary |
Dec 10 2012, 10:10 PM
While I'm taking off the outer console.
Super In Law is working on the fit of the inner console to the new inner wheelhouse. |
cary |
Dec 10 2012, 10:27 PM
Well after about 3 hours of work the outer console is off.
I'm a little more optimistic after I found these two consoles in pretty good shape. I left the outer console sprayed down with Ospho. I'm real happy with the Rotacut spot weld cutter. I followed Perry's input. I dipped the cutter into a cup of cutting oil. Cut the hole about 1/2 way. Blew out the hole and the cutting tip. Then finished cutting the hole. It cut like it was a milling machine. Real impressive. It was a good day ................ |
cary |
Dec 10 2012, 10:31 PM
Hah! And my wife complains when I have 2 a/c grinders, 2 portable drills and 3 or 4 air tools on my tool cart... I'm sharing your image with her (IMG:style_emoticons/default/biggrin.gif) I was thinking today I might need a couple more grinders. I need both a cutting wheel and a grinding wheel with and without guards. Might need a couple more Makitas ....... (IMG:style_emoticons/default/santa_smiley.gif) (IMG:style_emoticons/default/santa_smiley.gif) |
cary |
Dec 18 2012, 01:59 PM
I have a drivers long (Perry), pedal box (Bruce) and a pair of engine mounts (Warren) coming.
Hopefully I can back to work New Years weekend. |
NARP914 |
Dec 18 2012, 04:59 PM
Newbie Group: Members Posts: 15 Joined: 18-March 08 From: Mission Viejo, CA Member No.: 8,826 Region Association: Southern California |
Great work, nice to see another car being saved.
cary |
Jan 5 2013, 08:30 PM
Perry's drivers side long has arrived.
jersey914 |
Jan 5 2013, 08:56 PM
Member Group: Members Posts: 161 Joined: 6-September 12 From: Marlton, NJ Member No.: 14,895 Region Association: North East States |
cary |
Jan 6 2013, 07:28 PM
cary |
Jan 6 2013, 07:39 PM
Dis-assembly begins ...............
Started with removing the portion of the rear door jam. |
cary |
Jan 6 2013, 07:41 PM
Door sill removed ................
cary |
Jan 6 2013, 07:49 PM
Now getting to the portion that I really wanted to look at.
Removing the longs door hinge support. Getting out the leaded flange on the upper portion was a bitch. But I got .................... |
cary |
Jan 6 2013, 07:56 PM
Heres a couple shots of the outer long under the door hinge support.
As you can see the front fender end isn't welded at all. Well that's not going to work. I'm thinking I'll seam seal it. The top only has 2 spot welds. |
cary |
Jan 7 2013, 05:54 AM
Bad news for the Tool Whore's wallet.
They just opened a new HF in Hillsboro. On a side note: Buying two more grinders. NAPA has a pair of 6 amp Porter Cables 4 1/2 ones sitting on their left over Christmas gift display. On a sad note: Being transferred to the companies most outdated and under-performing store. Dandy. Owners explanation. You get paid the most, go fix it. He had a pretty tough time breaking the news .............. Start today at 5am ................. |
Lo-Fi Version | Time is now: 18th January 2025 - 08:36 PM |
