56 Pages V « < 5 6 7 8 9 > »
> Cary's 73 1.7 Rustoration Thread
cary
post Jan 6 2013, 07:39 PM
Post #121
Dis-assembly begins ...............
Started with removing the portion of the rear door jam.
cary
post Jan 6 2013, 07:41 PM
Post #122
Door sill removed ................
cary
post Jan 6 2013, 07:49 PM
Post #123
Now getting to the portion that I really wanted to look at.
Removing the longs door hinge support.
Getting out the leaded flange on the upper portion was a bitch.
But I got ....................
cary
post Jan 6 2013, 07:56 PM
Post #124
Heres a couple shots of the outer long under the door hinge support.
As you can see the front fender end isn't welded at all. Well that's not going to work. I'm thinking I'll seam seal it.
The top only has 2 spot welds.
cary
post Jan 7 2013, 05:54 AM
Post #125
Bad news for the Tool Whore's wallet.
They just opened a new HF in Hillsboro.
On a side note:
Buying two more grinders. NAPA has a pair of 6 amp Porter Cables 4 1/2 ones sitting on their left over Christmas gift display.
On a sad note:
Being transferred to the companies most outdated and under-performing store. Dandy. Owners explanation. You get paid the most, go fix it.
He had a pretty tough time breaking the news ..............
Start today at 5am .................
Archie
post Jan 11 2013, 10:29 PM
Post #126
QUOTE(cary @ Nov 7 2012, 05:50 AM) *
Now back to work .....................
What have some some folks done to seal up the sail panel cavity so we don't get debris up in there.
This is looking at it hanging upside on the rotisserie.
You have to wonder, Cary. I found some of that round-section, open-cell construction foam pushed up into this gap between the sail panel and the outer fender panel. I thought it was stock! Seems like there should be nothing in there!!
cary
post Jan 12 2013, 06:41 AM
Post #127
I thought the same thing.
But when we started the body work on this car a couple years ago. There it was.
I'm sure Scotty, Perry, Jeff and those that having been restoring these cars for years could give you a better explanation.
I think I remember one of them explaining what the factory was thinking. But I can't remember what it was.
cary
post Jan 17 2013, 06:58 AM
Post #128
My dad just passed away from a fast acting Leukemia. He fainted on Dec 10th. and passed away yesterday. He was 75 and was in what appeared to be perfect health.
They did make an attempt with Chemo, but it didn't work. They say it had a 66% chance.
When you're a kid your dad seems like Superman. It was tough to see him shrink to almost nothing.
Slink
post Jan 17 2013, 08:45 AM
Post #129
Cary
My deepest sympathy to you and your family.
wingnut86
post Jan 17 2013, 01:02 PM
Post #130
...boola la boo boola boo...
Cary,
My family's condolences on the loss of your dad. Mine passed in 2006 - battled cancer 3 times and won. Appendix burst one evening and the infection took him 3 weeks later, he was 78.
Hang in there.
Dave
cary
post Jan 21 2013, 09:33 PM
Post #131
Well time to get back to work.
Got my 2 new grinders out of the truck.
Looks like the last nice day at the man cave for a while. Freezing rain coming tonight.
cary
post Jan 21 2013, 09:45 PM
Post #132
I'm back at disecting the drivers long that I bought from Perry.
First I'll cut the long with the plasma cutter.
Could use a cut off wheel. But I thought I'd give the plasma cutter a whirl.
That was cool. I'll have to get a pair of torch goggles.
Welding helmet is too dark. I couldn't see the line.
cary
post Jan 21 2013, 09:48 PM
Post #133
Look like we'll have about 100 spot welds to drill out.
Whoa ............
cary
post Jan 21 2013, 09:53 PM
Post #134
I got 85 spot welds drilled out with one Rota Cut bit. (IMG:style_emoticons/default/piratenanner.gif)
Using Perry's dip into cutting oil technique.
Works like a champ.
Did go through about 5 HF 7/64 pilot hole drill bits. (IMG:style_emoticons/default/mad.gif)
sixnotfour
Post #135
Hold or clamp a straight edge and burn....
cary
post Jan 21 2013, 09:56 PM
Post #136
Outer long removed in one solid piece. (IMG:style_emoticons/default/biggrin.gif)
Easy deal .................
cary
post Jan 21 2013, 09:58 PM
Post #137
Here she is opened up. Looks good.
cary
post Jan 21 2013, 10:15 PM
Post #138
Perry gave me lots of material. Looks like I'll have the entire front inner fender portion too.
But the bottom of the long as it starts to go up the wheelhouse will have to be created.
This one is pitted and has a couple holes in the outer layer. Better than mine, but not a good as I want it to be.
That's the section under the rear jack point.
Could do a small patch. But to me, seems that's about the most important section on the entire car.
Had a great day.
Had a tearful moment when Eric Clapton came on the radio.
Tears in Heaven
Took a couple minutes to listen to entire song. Then got back too it.
cary
post Jan 28 2013, 10:47 PM
Post #139
So back to dissecting the long.
Next will be to remove the engine shelf. I want to remove it totally intact so it could be used in the future.
Camera doesn't like the halogen lamps......
Taking off the backend with the end piece attached. No way to remove it without damaging the shelf.
Got it out in one piece. (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif)
cary
post Jan 28 2013, 10:52 PM
Post #140
Here's the wheelhouse cut off with the plasma cutter.
- Lo-Fi Version Time is now: 16th January 2025 - 11:51 PM
