56 Pages V « < 8 9 10 11 > »
> Cary's 73 1.7 Rustoration Thread
cary
post Mar 4 2013, 11:31 PM
Post #166
Here's the motor mounts that where sent by Worn.
Thank You ................
cary
post Mar 4 2013, 11:35 PM
Post #167
Taking a time out to get the other car ready for season opening AX on 3/15-16.
New front trunk seal with a little rust repair.
And welded the engine lid hinge bracket solid to the firewall.
cary
post Mar 11 2013, 10:33 PM
Post #168
Back to work. Super In Law (82) back working on the inner fender patch.
Its our first use of the Millermatic 180.
cary
post Mar 11 2013, 10:43 PM
Post #169
Me, I'm getting the other car ready for this weekends Drivers Skills Clinic and AX.
Just ordered a new set of Falken Azenis RT-615Ks.
FourBlades
post Mar 12 2013, 07:05 AM
Post #170
From Wreck to Rockin
Good work on saving another teener!
(IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif)
John
cary
post Mar 12 2013, 10:23 PM
Post #171
Working on setting things up to install the drivers long.
Asked for a little help on welding shrinkage.
http://www.914world.com/bbs2/index.php?sho...p;#entry1833832
Here's where we ended the day. Continuing to work on the fit.
cary
post Mar 13 2013, 10:36 PM
Post #172
Still working on the drivers long.
Had a little trouble with creating the patch under the jack point.
I did finally got the doors properly aligned.
cary
post Mar 20 2013, 09:38 PM
Post #173
The day finally came. We installed the drivers long.
Here it is prepped and ready to go.
1. Flanges painted with brush on weld thru primer.
2. Cavity painted with Rustoleum.
Inner fender prepped with brush on primer and Rustoleum.
cary
post Mar 20 2013, 09:46 PM
Post #174
Here it is tacked in place and back on the rotisserie.
Both sides at exactly the same level. (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif)
Started with a door gap of 5.5mm, finished at 5mm. (IMG:style_emoticons/default/welder.gif)
cary
post Mar 20 2013, 09:54 PM
Post #175
Here's the inner fender to long welds.
Mine are the two bottom ones.
1/2 plug, 1/2 tack. I don't want the bitch moving.
Super In Law got a little carried away on his.
By the end of this project I'll either be a master welder or a master grinder.
cary
post Mar 25 2013, 08:41 PM
Post #176
Things are looking up ..............
We patched the bottom of the drivers wheelhouse. The spot under the rear floor jack point. Super In Law had a little trouble trying to get the puddle to move without blowing holes in it.
I'll try and do some more work on the right side ................
Both sides are new metal. Don't know exactly what the problem was.
I think he's out too far with the wire.
Inside is just about prepped for the inner box.
cary
post Mar 25 2013, 08:43 PM
Post #177
Starting to look like a whole car again ................
Sorry for the low light phone picture.
cary
post Mar 25 2013, 08:49 PM
Post #178
Laying out the next project..............
Complete passenger side wheelhouse replacement.
It's going to nice working with new metal.
saigon71
post Mar 26 2013, 05:48 AM
Post #179
(IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/welder.gif)
Good work...Keep on rollin man!
I agree, working with new metal is a real treat!
nathansnathan
post Mar 26 2013, 06:54 AM
Post #180
QUOTE(cary @ Mar 25 2013, 07:49 PM) *
I've been following along, glad to see someone going deeper into a 914 than I have. (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/smile.gif)
Just remember the replacement panels are galvanized - best to sand it off anywhere you're going to weld.
worn
post Mar 26 2013, 08:32 AM
Post #181
QUOTE(cary @ Mar 25 2013, 06:49 PM) *
Uhhmmm, Cary. Does the super in law do house calls? You are one lucky guy. Nice work. Trying to follow close behind with my 6 conversion. Thanks for keeping your 914 from the scrap heap.
cary
post Mar 26 2013, 11:09 PM
Post #182
I'm thinking that Super In Law isn't wire brushing between welds.
Along with having too much wire out form tip.
Nathan, I usually hit it with the grinder. Probably a bit harsh.
I think I'll pick up a few 80 grit Rolocs.
Thanks for the heads up.
cary
post Mar 26 2013, 11:13 PM
Post #183
Switching days off.
We'll be back at it tomorrow.
Stopping at a cute little cafe for breakfast.
We've been driving by it for 3 years.
cary
post Mar 27 2013, 09:50 PM
Post #184
Super in Law is working on the insert sleeve.
Took 2 shots at it. Not quite tight enough.
So we'll try it again.
cary
post Mar 27 2013, 09:54 PM
Post #185
While he was working on the insert pattern.
I thought I'd look at the seam sealer behind the door latch plate.
There is quite a pile of seam sealer in there.
Right behind the door handle too.
- Lo-Fi Version Time is now: 18th January 2025 - 05:04 AM
