56 Pages V « < 10 11 12 13 > »
> Cary's 73 1.7 Rustoration Thread
cary
post Apr 29 2013, 08:56 PM
Post #206
Now measure, measure & re-measure ................
Align bottom edge ....................
Everything is starting to come together.
cary
post Apr 29 2013, 09:01 PM
Post #207
Now we start to work on the the two pieces of the wheelhouse.
The two pieces overlap each over. So using both, I'll need to lap them together.
Measure FOUR, times cut once.
cary
post Apr 29 2013, 09:23 PM
Post #208
So I measure the upper wheelhouse so I can cut off the lower portion.
So we start the lap weld after we crimp a flange on it.
I think one is a AA part and the other an RD part. I'll let Pete answer that.
Right about were the AA part is wavy. They don't line up perfect.
Master grinder should be able to tidy it up. LOL.
I still have trouble seeing, even using the $200 helmet.
I'll get it figured it out. Over over-welded it in a couple spots.
I'll take a picture of the penetration when I come back to pickup the enclosed trailer.
It is freeking cool. Perfect.
All in all, a good day ............ Had a great time. Left the shop with a big smile. (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif)
cary
post May 6 2013, 08:37 AM
Post #209
Back to work.
Back on the lift it will go.
It want to make sure everything is aligned perfect before I tie these three pieces together.
Kind of a slow process. But part of learning what you can and can't do.
Plus I'll get Super In Law to drill some new holes in the rotisserie so it goes on the lift perfectly flat.
Meaning, when the car is perfectly flat on the lift. We have to lift one end of the rotisserie up to bolt it on. Which tweaks the nose a couple MM.
cary
post May 14 2013, 07:37 PM
Post #210
Well, back to work again.
Getting tired of getting poked in the back.
cary
post May 14 2013, 07:42 PM
Post #211
Getting ready to put the car back on the lift and get it back into alignment.
So we're building a couple more lift jacks.
cary
post May 14 2013, 07:43 PM
Post #212
Cutting patch patterns ...................
cary
post May 14 2013, 07:59 PM
Post #213
Test fitting the outside suspension console.
Getting aligned back on the jig.
Getting closer to welding in back together.
cary
post May 19 2013, 09:19 AM
Post #214
So it's s back on the lift.
Now the tedious job of getting the doors gapped to 5mm.
I need to start looking for a used bench ...................
This is a PIA.
cary
post May 19 2013, 09:28 AM
Post #215
Now to start adding parts.
First is RD P351 Inner longitudinal member, engine compartment, Right side.
Gave up on trying to weld up against the shock tower on the inside.
I'll tack it at the top. Thought about some self tapping SS screws. But the rosette and hole punched welds are some much larger that the spot welds I think we'll be ok.
Thoughts ???
cary
post May 19 2013, 09:40 AM
Post #216
Going to have to do some tweaking on the P351 to get it to align with the P331.
Inner wheelhouse, lower right.
The flange on the long is wider than the flange on the wheel house.
So we'll squeeze the long a bit to get the fit we want.
Should have squeezed the long BEFORE I welded it in. (IMG:style_emoticons/default/mad.gif)
Only looking for a couple MM's so it was no big deal.
Did use Pete's self tapping screw idea. Worked great.
Looking forward, I'll use it when dry fitting multiple layers/pieces together. (IMG:style_emoticons/default/welder.gif)
I'll get a picture of the box of screws I got at Home Depot. #10 wide & flat.
cary
post May 19 2013, 09:55 AM
Post #217
Let my son have the white 914 to drive the last couple weeks at Oregon State. Graduating Summa Cum Laude in a couple weeks.
Getting a BS in Finance. Should hear back on his CFA Level 1 test in June.
He has been accepted into the School of Law at the U of 0.
Hopefully he'll get a spot. Applied late. Was hoping to go to Sanford.
But his LSAT test was 2 points too low to even attempt to get it in.
Born leader ...................anything less than becoming a CEO will be a let down.
Oh yeah .............I miss the car. Even though its only been a couple weeks.
He took it to the beach from Corvallis last weekend. Dad what did you do to the car? It runs like a dream.
I explained the MPS and AFR adjustments.
He's the son that drove it all 4 years of high school in Montana.
cooltimes
post May 19 2013, 05:54 PM
Post #218
That was a real 914 thriller.
Getting it all together and seeing expert craftsmanship in a real timeline.
Thanks to you and your Great In Law for sharing each moment in your skills of keeping your 914 alive with us.
MikeCool
TN.
worn
post May 19 2013, 08:32 PM
Post #219
QUOTE(cary @ May 14 2013, 05:37 PM) *
I am glad to see someone else tennis balling their project. I figure I have it coming if blood is running into my shirt, but the helpers don't deserve it. Steve Zissous said it best when he said you didn't point a gun at an intern.
Kraftwerk
post May 21 2013, 10:37 PM
Post #220
Great work, and a great deal of work. You really saved this one.
cary
post Jun 19 2013, 08:05 PM
Post #221
I'm back ....................
We'll get back to it for a couple days.
I've been busy.
1. Took a backpacking trip with my brother.
2. Got told that the supermarket that I manage was going to close and I would be moving to another store,again. Another one they're talking of closing or selling.
Hmmmmm, not good at 57 years old.
3. Two hours later I have a new job. Going back to Albertsons where I started.
4. Start liquidating the inventory of the store. Tough duty. All that work going down the drain.
5. Watch my son get his BS in Finance at Oregon State. (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/smile.gif)
6. Give two week notice at old job. Going to take the two weeks as vacation.
Hopefully I'll get to burn some metal tomorrow. Its been a month. Seems like forever.
worn
post Jun 19 2013, 09:33 PM
Post #222
QUOTE(cary @ Jun 19 2013, 06:05 PM) *
I've been busy.
2. Got told that the supermarket that I manage was going to close and I would be losing my job. Hmmmmm, not good at 57 years old.
It may be joe albertsons supermarket, but I'm glad you are on your feet. Wish we had em out here, and great that you get two weeks.
cary
post Jun 20 2013, 08:44 AM
Post #223
Might not, waiting for the text to tell me when they what me to start.
It could be Monday. (IMG:style_emoticons/default/sad.gif) (IMG:style_emoticons/default/sad.gif)
Hopefully I can negotiate taking a couple weeks unpaid after I get things figured out.
Oh well ......................
Finishing my coffee. Then we'll be heading out to the shop.
cary
post Sep 19 2013, 08:37 AM
Post #224
4 months later and I finally get a chance to get back to work.
Working my way thru the new job.
Returning after 21 years
Already promoted and making more than the job that I left. All is good.
Now its time to burn some metal........................
cary
post Sep 29 2013, 10:28 PM
Post #225
Ok been too busy at work to pull the JPGs off the phone.
Regap the doors ...............
Gettin back into the swing of things
- Lo-Fi Version Time is now: 17th January 2025 - 11:08 PM
