56 Pages V « < 19 20 21 22 23 > »
> Cary's 73 1.7 Rustoration Thread
cary
post May 15 2015, 09:08 PM
Post #401
QUOTE(peteyd @ May 15 2015, 08:23 AM) *
Cary,
Nice work! keep up the good pace. Your rosette welds are looking great too
Pete
I think I could have gone a little hotter. Maybe that would have flattened them out a smidgen. But I was really focused on the penetration level. Of the 100 welds on the tunnel I only touched up 6 from the bottom side. Those were caused by the metal not being tight enough together. I didn't grind the old side of the tunnel flat enough. (IMG:style_emoticons/default/mad.gif)
And I only blew through three on the 200 rossettes I did on those two days. And all of them were up under the steering wheel on the old tunnel metal. Even with the rotisserie and a welding helmet they were kind of a bitch to get too. Bad angle. Hotter on one side.
As a rule I was counting to 7 on each weld. Seemed to work for me.
Those rosettes will grind right off with a flapper disk. I love those things. I wish I had found them sooner.
Thank all of you for the words of encouragement. Now I wait for another week. (IMG:style_emoticons/default/sad.gif)
worn
post May 16 2015, 07:38 PM
Post #402
QUOTE(cary @ May 8 2015, 07:56 AM) *
Another Tool Whore segment. In Adam's RD video he mentions that he drills the rosette weld holes. That's way too much work. I use my air punch wherever I can. I does have thickness and depth limitations. But it works in most places.
http://www.harborfreight.com/air-punch-flange-tool-1110.html
Another Tool Whore word of advice. Don't buy HF air fittings, they SUCK. I use NAPA or Home Depot with nice leak free results.
Drill!?! I don't think so. That is a necessity if I ever saw one.
cary
post May 16 2015, 08:16 PM
Post #403
I just wish it made a little bigger hole. I use a #10 self tapping screw and it almost cuts the same size hole. Bigger hole would give you a little more to weld to.
But I'm figuring it out .................
cary
post May 17 2015, 07:57 PM
Post #404
The AX went awesome. My best performance ever.
Was 5th overall. Moved up 10 places. 5th out of 73.
Beat both GT3's. (IMG:style_emoticons/default/piratenanner.gif)
Two other 914World members came in 1st and 2nd.
Doug Skinnerd and Gary Chapman. Gary in his 914-6 (1st). Doug in Kermit, 911 RSR.
Han Solo
post May 18 2015, 11:09 AM
Post #405
Just read through complete thread. Great work! Sobering to think what I might have to do to my '76.
cary
post May 18 2015, 11:17 AM
Post #406
I would think this would be a worst case scenario.
I decided to take on my worst case first.
I 'm building this to be my daily driver. It will probably be over welded and over seam sealed for most folks.
Han Solo
post May 18 2015, 12:10 PM
Post #407
QUOTE(cary @ May 18 2015, 12:17 PM) *
Pretty much what this one has...
'76 Parts Car or Keeper?
cary
post May 25 2015, 07:38 AM
Post #408
Last Friday was pretty uneventful. After servicing the truck I knocked down the rosette welds and the floor pan seam. I'm real happy with the seam. If it was going to be seen and out in the open, I could make the weld disappear. I have only one spot were it wasn't perfectly even. But the bottom will be undercoated and the interior covered with sound mat.
cary
post May 30 2015, 07:08 AM
Post #409
Today I fitted the inner firewall pieces. Once again, it takes some fiddling to get a nice fit. Every time you fit a piece you question whether the car is square. So you double check everything again. But at this point it isn't going to move too much.
It's really starting to become fun and rewarding.
I'm about half way thru with welding it in. Pretty tedious. Back and forth, up and down. The metal tells you when its getting too hot. The edge of your punched hole blows out. Stop, cool everything, take a break.
Oh yeah, once again dumb ass used too much weld thru primer. What a frikking mess and hassle. What a waste of wire and gas.
One thing I did learn, or teach my self. Using the 1/4" Blair/Rotacut spot weld cutter to cut the rosette holes makes a much nicer weld when combined with the self taping screw. Makes a nicer, flatter weld. If some one else was paying me for my time on a no expense spared restoration that's how'd I'd do every hole. Screws, 7.5c (Fastenal), Blair cutter head $7.50 (Airgas Online), they add up. But then so do grinding disks, flapper disks and Rolock disks. LOL.
I'll be back to it on Monday. Hopefully get that finished up and move on to the cross members.
nathansnathan
post May 30 2015, 08:53 AM
Post #410
Looks awesome, man. Inspiring work here. (IMG:style_emoticons/default/beer.gif)
cary
post Jun 1 2015, 10:21 PM
Post #411
Finished up the welding. Not real happy/proud of the flange on top of the tunnel.
Should have cut it off and replaced it.
Added a little brush on seam sealer.
cary
post Jun 1 2015, 10:30 PM
Post #412
On to the jack points.
Prepped and ready to go ................
Welded in, ready for the grinder.
Front jack point located.
cary
post Jun 1 2015, 10:37 PM
Post #413
After years of welding I'm finally getting the grinder pile down to a manageable level.
Time for a couple tools shots. (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/welder.gif)
peteyd
post Jun 2 2015, 09:29 AM
Post #414
QUOTE(cary @ Jun 1 2015, 08:30 PM) *
Im lovin' it!
great progress and job.
cary
post Jun 3 2015, 01:12 PM
Post #415
Back at again .........
But first, a new computer station. Repurposed an old TV wall mount.
Then I got tired of picking the the air hose (cooling) and the wire feed pliers off the floor. Which caused an outburst of profanity ....... Used a magnet from HF and a eyelet bolt.
Might build a bigger one for the pick hammer. Must be the IE in me. Spent too many years teaching folks how to do it faster and with less energy.
Off to lunch ...............
raynekat
post Jun 3 2015, 06:20 PM
Post #416
Was going to come out tonight (Wed, June 3), but not sure if you work at nights or just during the day?
Let me know a good day and time to come visit.
-Doug
cary
post Jun 3 2015, 07:48 PM
Post #417
I'm only out there during the day. I usually stay till 5:30.
I'll be back out there on Friday.
raynekat
post Jun 3 2015, 07:49 PM
Post #418
QUOTE(cary @ Jun 3 2015, 06:48 PM) *
OK....I'll see you this Friday then.
cary
post Jun 3 2015, 11:02 PM
Post #419
First order of business after lunch. Change the outside splatter shield. Whoa, it was hammered. No wonder it was a little blurry.
Yesterday I turned down the sensitivity. I can finally see what I'm working on. Nice.
Dad also did an oil change on the Princesses car.
cary
post Jun 3 2015, 11:26 PM
Post #420
First was tidying up a few spots on the bottom of the pan. The welding is getting easier. Don't know if its the miles and hours, or I'm working on a little less rust.
Then I moved on to the inside bottom edge of the front firewall to floor pan.
Not exactly my finest hour, I should have put a new bottom edge on them.
But it welded up much better than I thought it would, and it will be covered by seam sealer. Oh well ................ lesson learned for the next one.
Then I SE primered the bottom. I'll start epoxy primering after I'm done welding.
I hate the weld thru primer splatters. Black specks ............
This put a big smile on my face. (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/cheer.gif)
- Lo-Fi Version Time is now: 17th January 2025 - 07:38 AM
