56 Pages V « < 20 21 22 23 > »
> Cary's 73 1.7 Rustoration Thread
cary
post May 18 2015, 11:17 AM
Post #406
I would think this would be a worst case scenario.
I decided to take on my worst case first.
I 'm building this to be my daily driver. It will probably be over welded and over seam sealed for most folks.
Han Solo
post May 18 2015, 12:10 PM
Post #407
QUOTE(cary @ May 18 2015, 12:17 PM) *
Pretty much what this one has...
'76 Parts Car or Keeper?
cary
post May 25 2015, 07:38 AM
Post #408
Last Friday was pretty uneventful. After servicing the truck I knocked down the rosette welds and the floor pan seam. I'm real happy with the seam. If it was going to be seen and out in the open, I could make the weld disappear. I have only one spot were it wasn't perfectly even. But the bottom will be undercoated and the interior covered with sound mat.
cary
post May 30 2015, 07:08 AM
Post #409
Today I fitted the inner firewall pieces. Once again, it takes some fiddling to get a nice fit. Every time you fit a piece you question whether the car is square. So you double check everything again. But at this point it isn't going to move too much.
It's really starting to become fun and rewarding.
I'm about half way thru with welding it in. Pretty tedious. Back and forth, up and down. The metal tells you when its getting too hot. The edge of your punched hole blows out. Stop, cool everything, take a break.
Oh yeah, once again dumb ass used too much weld thru primer. What a frikking mess and hassle. What a waste of wire and gas.
One thing I did learn, or teach my self. Using the 1/4" Blair/Rotacut spot weld cutter to cut the rosette holes makes a much nicer weld when combined with the self taping screw. Makes a nicer, flatter weld. If some one else was paying me for my time on a no expense spared restoration that's how'd I'd do every hole. Screws, 7.5c (Fastenal), Blair cutter head $7.50 (Airgas Online), they add up. But then so do grinding disks, flapper disks and Rolock disks. LOL.
I'll be back to it on Monday. Hopefully get that finished up and move on to the cross members.
nathansnathan
post May 30 2015, 08:53 AM
Post #410
Looks awesome, man. Inspiring work here. (IMG:style_emoticons/default/beer.gif)
cary
post Jun 1 2015, 10:21 PM
Post #411
Finished up the welding. Not real happy/proud of the flange on top of the tunnel.
Should have cut it off and replaced it.
Added a little brush on seam sealer.
cary
post Jun 1 2015, 10:30 PM
Post #412
On to the jack points.
Prepped and ready to go ................
Welded in, ready for the grinder.
Front jack point located.
cary
post Jun 1 2015, 10:37 PM
Post #413
After years of welding I'm finally getting the grinder pile down to a manageable level.
Time for a couple tools shots. (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/welder.gif)
peteyd
post Jun 2 2015, 09:29 AM
Post #414
QUOTE(cary @ Jun 1 2015, 08:30 PM) *
Im lovin' it!
great progress and job.
cary
post Jun 3 2015, 01:12 PM
Post #415
Back at again .........
But first, a new computer station. Repurposed an old TV wall mount.
Then I got tired of picking the the air hose (cooling) and the wire feed pliers off the floor. Which caused an outburst of profanity ....... Used a magnet from HF and a eyelet bolt.
Might build a bigger one for the pick hammer. Must be the IE in me. Spent too many years teaching folks how to do it faster and with less energy.
Off to lunch ...............
raynekat
post Jun 3 2015, 06:20 PM
Post #416
Was going to come out tonight (Wed, June 3), but not sure if you work at nights or just during the day?
Let me know a good day and time to come visit.
-Doug
cary
post Jun 3 2015, 07:48 PM
Post #417
I'm only out there during the day. I usually stay till 5:30.
I'll be back out there on Friday.
raynekat
post Jun 3 2015, 07:49 PM
Post #418
QUOTE(cary @ Jun 3 2015, 06:48 PM) *
OK....I'll see you this Friday then.
cary
post Jun 3 2015, 11:02 PM
Post #419
First order of business after lunch. Change the outside splatter shield. Whoa, it was hammered. No wonder it was a little blurry.
Yesterday I turned down the sensitivity. I can finally see what I'm working on. Nice.
Dad also did an oil change on the Princesses car.
cary
post Jun 3 2015, 11:26 PM
Post #420
First was tidying up a few spots on the bottom of the pan. The welding is getting easier. Don't know if its the miles and hours, or I'm working on a little less rust.
Then I moved on to the inside bottom edge of the front firewall to floor pan.
Not exactly my finest hour, I should have put a new bottom edge on them.
But it welded up much better than I thought it would, and it will be covered by seam sealer. Oh well ................ lesson learned for the next one.
Then I SE primered the bottom. I'll start epoxy primering after I'm done welding.
I hate the weld thru primer splatters. Black specks ............
This put a big smile on my face. (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/cheer.gif)
cary
post Jun 3 2015, 11:48 PM
Post #421
Now on to the center braces .................... I thought I'd never get here. Like everything, it takes fiddling to get that perfect tight fit. It's beginning to become fun.
Left side fitted. Clamped in place. (IMG:style_emoticons/default/biggrin.gif)
I forgot to say. I have the 74 to measure and get dimensions off of. Measured off the back wall to get the correct location.
Started tinkering with the right side. (IMG:style_emoticons/default/beer.gif)
Then I decided to prep the seat adjusters. Drilled out the rosette weld holes. Then cleaned off the cutting oil in the parts cleaner. They are ready for weld thru primer on Friday.
cary
post Jun 3 2015, 11:52 PM
Post #422
A tool whore shot. The shear sure makes short work of the trimming. (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif)
But I wish I had a big shear that would cut thru 3ft. of 16 gauge mild steel. Maybe when I win the Powerball.
FourBlades
post Jun 4 2015, 05:37 AM
Post #423
From Wreck to Rockin
You are kicking ass now! (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/welder.gif) (IMG:style_emoticons/default/beer.gif)
John
worn
post Jun 4 2015, 07:25 PM
Post #424
QUOTE(cary @ Jun 3 2015, 10:52 PM) *
I got that for Christmas. I think my son wanted one so I have it! Great things fathers and sons. Wish I had a super in law, but perhaps I will simply become one someday. Forlorn hope I suppose.
cary
post Jun 5 2015, 06:50 AM
Post #425
Next shop project.
We're going to build a two sided panel to store/clip all the plastic bags of parts on. It will be on wheels so it can be moved around.
It's almost time to send stuff off to be plated. So Ill go thru every bag. Photo every bag. Rename if needed.
Hmm ........... I need to find that e-brake tube/spring bracket. Having to dig thru the tub of bags isn't real handy.
On the way to the shop this am we're stopping at HF for a couple more magnets. Ace Hardware for some eye bolts and maybe some copper tubing.
Oh yeah, maybe some taller wheels for the bag panel at HF.
Time to make some coffee .................
- Lo-Fi Version Time is now: 17th January 2025 - 05:30 PM
