56 Pages V « < 21 22 23 24 > »
> Cary's 73 1.7 Rustoration Thread
cary
post Jun 5 2015, 10:14 PM
Post #426
Here are the fiddling weapons I was talking about.
Metal. Different shapes an sizes.
Something to hold the metal and wood.
Something to pound on.
cary
post Jun 5 2015, 10:32 PM
Post #427
Decided I'd cut out the e-brake light switch while the brace was out. Took the location and size off the yellow (74) car.
It's just a smidgen shy of a 1/2" square. Drilled a hole in each corner. Then cut between the holes with the Dremel. Should have used a smaller cutting disc. But I like the reinforced one ................ Does blow apart when you breath on it.
cary
post Jun 5 2015, 11:08 PM
Post #428
Now for the task at hand ...................
Forgot to shoot pictures of installing the adjustment brackets. Pretty simple. 245mm from the long. Square up. Weld in the rosettes.
Rosettes welded in. The larger ones are caused by not letting or the getting the metal cooled down.
Beautiful ending to wonderful day .................
raynekat
post Jun 6 2015, 07:16 PM
Post #429
Hey I need to do that passenger side movable seat install on my car.
Tried to come by on Friday, but I couldn't really find the shop.
Guess I need better directions next time.
Saw a horse stable and a farm, but nothing looking to inviting.
Better luck next time I suppose.
cary
post Jun 6 2015, 09:10 PM
Post #430
You were there .............
It's up behind the horse stable. Turn at the third driveway.
Sorry I didn't give the phone number with the address. (IMG:style_emoticons/default/sad.gif) (IMG:style_emoticons/default/sad.gif)
Let's call it a unique arrangement, .15c sq. ft. utilities paid.
cary
post Jun 6 2015, 10:36 PM
Post #431
QUOTE(raynekat @ Jun 6 2015, 06:16 PM) *
Yours is fixed ?
Andyrew
post Jun 6 2015, 10:51 PM
Post #432
Spooling.... Please wait
Great looking work!! Turn your wire speed down or your temp up on your mig, your welds are a hair large (IMG:style_emoticons/default/smile.gif)
cary
post Jun 7 2015, 07:02 AM
Post #433
I think I'm going to tinker with turning the wire speed down just a hair. This is a good test area because I can look a the penetration from the back side.
On this beautiful RD Galvanneal I run the Miller 180 (220v) at 17 on the thickness gauge (heat) and 45 on the speed.
Thanks for the critique ....
cary
post Jun 13 2015, 07:53 AM
Post #434
So we have another day to play. First half of the was spent unloading the enclosed trailer full of the middle kids stuff into the warehouse.
Then onto the seat mount/hinges. Watched the RD video a couple times, Adam does a nice job. Tried doing the hinge tack on the first one. Just didn't work with the door braces in the way. Really pretty simple. The hinge pin is supposed to be centered right at the peak of the mount. Just scribed a line on the mount and aligned the hinge pin the line.
First step was to get everything in place. Bad part, looks like the seat frames will need a little restoration. Handle shaft has some rust. I'm thinking yellow cad plating on the handle ?
A couple shots of the hinge welding.
Once again lots of time spent cooling the metal. Rosette welds still a little too big. Turned down the wire speed, which made them flatter. But still to wide.
Maybe Next Time. But the welding is just about over. Next will be the door sills.
Sitting here watching the first hour of Lemans on Fox Sports 2.
Then off to my first PCA Arrive and Drive rally in the Carrera. 100 mile drive with 40 or 50 Porsche's. Tomorrow will be spent at the Rose Cup races at PIR.
Might squeeze in a 30-40 bike ride after the arrive and drive.
saigon71
post Jun 14 2015, 04:20 PM
Post #435
Fine work tackling some serious rust! (IMG:style_emoticons/default/beerchug.gif)
cary
post Jun 22 2015, 10:38 PM
Post #436
Back to work. Finished grinding down the spot welds and touching up the backside.
Kind of tricky grinding. A lot of using the outside edge.
Then proceeded to apply the first layer of brush on seam sealer.
Spent the first half of the day putting new pads and rotors on the pickup. What a messy job ................ That brake dust gets everywhere.
Then took out the lower door brace so I can start working on the door sill.
cary
post Jun 22 2015, 10:42 PM
Post #437
Another Tool Whore shot.
Bought a good set of butt weld clamps for re-attaching the rear fender.
I've already bent the crap out of the HF ones.
cary
post Jun 23 2015, 08:48 AM
Post #438
Just finished reading Michelko's, Digging into Hell. Kind of wish I'd used POR15 along the way. Looks so nice and tidy after he finished a section. Oh Well ...
Looking at buying a fresh air respirator before I start shooting the epoxy primer.
http://www.ebay.com/itm/Supplied-fresh-Air...k-/380153845245
I'm going with prepping the metal with OSPHO, then SPI epoxy primer. After that, spray on seam sealer, for the factory look.
I am brushing on sealer sealer over SEM self etching primer in the spot/rosette welded areas as I go.
raynekat
post Jun 23 2015, 02:24 PM
Post #439
Dude.....you gonna come out and work on mine too sometime?
(IMG:style_emoticons/default/welder.gif)
Seriously....after looking at your rotisserie, I'd like one but don't have the lift to get the shell onto it.
Need to do the seat bracket thing on my car for sure.
But I think the paint & body shop I'm going to use can handle it.
All in all, you're the "man."
So much work you've been knocking out.
Do you really have a "real" job too?
hehe
Where do you find the time?
Plus you must have a godzillion dollars worth of new-ish tools as well.
Well done young man.....
(IMG:style_emoticons/default/flag.gif)
cary
post Jun 23 2015, 02:49 PM
Post #440
If you buy a rotisserie most have a lift built in.
I try to do as much done as I can in two days per week that I have ............. This is my sanity check
But now it will be three weeks before I get back. AX this Sunday and the STP bike ride the week after.
cary
post Jun 23 2015, 08:47 PM
Post #441
Very Productive Day .............
Started by removing my frame/jig that has been on there a couple years. (IMG:style_emoticons/default/mad.gif)
Now we're making progress.
Without jig. That allowed me to tidy up the seams and rosettes that I couldn't get to with the jig in the way.
cary
post Jun 23 2015, 09:13 PM
Post #442
On to the task at hand.
Installing the door sills.
Rosettes went real well. A little more heat, a little less wire speed.
But it almost feels like cheating, welding new metal to new metal.
Then I installed the braces. Used the tri square to line up the top screws.
Added a third brace. Salvaged off the old stuff.
cary
post Jun 23 2015, 09:54 PM
Post #443
Then I moved on to the door jam .............. That's dandy piece. Not an RD manufactured part and it shows. If you look at your door jam. All the bends are acute 90 angles. But on this piece they're all rounded. So there as quite a bit of reworked to get it to fit nice.
Then Mr. Patience let the metal at the butt weld get too hot. I had it almost perfect on the first pass. Ground down the weld with the flapper disk. Then went to add just a smidgen in the low spot.
Made a mess ................ time to walk away. Should have had another project going at the same time. Dammit (IMG:style_emoticons/default/hissyfit.gif) (IMG:style_emoticons/default/hissyfit.gif) ...............
I'm going to have to look into cooling gel.
cary
post Jun 23 2015, 10:01 PM
Post #444
So I went to look at the fender that needs to be welded back on. Looks like I need to remove the old door jam material from the backside of the fender. (IMG:style_emoticons/default/mad.gif) (IMG:style_emoticons/default/mad.gif)
That's going to take some doing to get it out of there without bending the fender.
I didn't leave myself a lot of space to work. There's about 10 spot welds to drill out.
trojanhorsepower
post Jul 1 2015, 04:57 PM
Post #445
Cary,
Was that 245mm from the long to one edge of the bracket? If so which edge? Or center?
- Lo-Fi Version Time is now: 17th January 2025 - 07:45 PM
