Cary's 73 1.7 Rustoration Thread |
cary |
Nov 7 2012, 08:21 PM
I'm not getting too much flash rust. They've been sitting like that for about 4 months. Go figure.
But my compressor generates about a pint every two weeks. In Montana I only generated a cup every year. That's why I built the paint tent. So I can roll the car in there and shoot epoxy primer as I finish up a section. |
cary |
Nov 11 2012, 11:04 PM
The more I look at that drivers long. The more I'm thinking about changing it out. I have a couple members looking to see if they might have what I need.
If that doesn't come thru. I may rework a new RD passenger long. It wouldn't have the handbrake indentation. But it would be new and a correct fit. Thoughts ................ Super In Law bought a Lenco Panel Spotter at a garage sale yesterday. Got a hold of Rick and he gave me a couple hints. Waiting for my new heater elements and contactor to show up from Better Engineering to finish up the parts washer restoration. |
cary |
Nov 14 2012, 08:12 AM
cary |
Nov 18 2012, 09:43 AM
I decided an amputation is in order.
Heading to the shop to cut out the drivers long. With what I've already invested in the restoration. It would be a shame not to do it right. The monsoons have begun here in PDX so I don't know when I be able to finish the sand blasting. Kind of waiting till the floor pans come out. I still have 2 members working on a couple driver long pieces. But if that doesn't come to be I'll do the RD passenger long flip over. I'm going to double check that a couple time before I cut. Wish me luck. A little music, a little beer and some rain on the tin roof. Should be a relaxing day. Oh yeah ............lots of sparks flying. (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/smile.gif) |
cary |
Nov 18 2012, 08:21 PM
cary |
Nov 18 2012, 08:29 PM
cary |
Nov 18 2012, 08:33 PM
cary |
Nov 18 2012, 08:36 PM
cary |
Nov 18 2012, 08:39 PM
cary |
Nov 18 2012, 08:52 PM
Now for the bad news. I didn't look at the passenger long close enough. The top and the bottom front corners aren't the same radius. (IMG:style_emoticons/default/sad.gif) (IMG:style_emoticons/default/sad.gif)
So hopefully I'll be able to come up with a drivers long. |
cary |
Nov 18 2012, 08:55 PM
cary |
Nov 18 2012, 08:57 PM
cary |
Nov 18 2012, 10:11 PM
Tomorrow I'll start on the passenger long.
Should go pretty easy now that I'm all schooled up. |
wingnut86 |
Nov 19 2012, 05:41 AM
...boola la boo boola boo... Group: Members Posts: 1,053 Joined: 22-April 10 From: South Carolina Member No.: 11,645 Region Association: South East States |
Cary,
Who did you buy your spot weld drill bits from, and what's the cost? How many shots do you get, in other words, before they are worn out... Thx, Dave |
cary |
Nov 19 2012, 08:47 AM
HF......................
http://www.harborfreight.com/catalogsearch/result?q=7/64 The trick. Speed. They say high speed. They wish. As you can see I use a De-Walt 12v to drill with. I use it in the #2 speed . The first couple holes are the most important. Don't push too hard. To answer the question, I'd say maybe ten. But if I don't get a good cut on the first hole. Dump it. .40c each. Chinese junk. But the Irwin bits aren't much better. I tried those too. |
cary |
Nov 19 2012, 09:23 PM
Well decided against moving on to the passenger long.
Don't want to detach both sides at once. I do have confidence in my measurements and bracing but I don't want to push my luck. LOL. With that being said. I'm going to build a couple new door braces. This time with Hiem joints. I don't like what I see when its flipped over on the rotisserie. |
cary |
Nov 19 2012, 09:32 PM
cary |
Nov 19 2012, 09:37 PM
cary |
Nov 19 2012, 09:41 PM
Using some of Mark's work as a pattern.
I'm taking a bigger bite. But the picture gives me a good start. |
cary |
Nov 19 2012, 09:46 PM
First attempt with the shrinker we made the apex of the corner too tight.
Won't give me a tight enough fit for spot welding. That's were the day ended. |
Lo-Fi Version | Time is now: 19th January 2025 - 02:25 AM |
