OIL TEMP GAUGE, PROPER READING? |
CTNL74914 |
Jun 16 2012, 11:04 PM
Newbie Group: Members Posts: 6 Joined: 3-June 12 From: New London, WI Member No.: 14,516 Region Association: Upper MidWest |
Finishing up on restore of interior of my '74 - 2.0 with stock D-jet.
Factory center console (w/3 gauges) is back in place and hooked up. Question is; when the key is turned on, the needle on the oil temp gauge comes to life (flickers) but after that never travels past the low end white mark, even after a hard drive. Is this normal? What do you guys recomend for a numbered replacement gauge? Any from VDO? Thanks in advance. |
Elliot Cannon |
Jun 16 2012, 11:21 PM
Many people don't like VDO gauges but I've had one in my car for 8 years and it works great. McMark had a post not long ago about a good gauge he recommended. A search might find it. I have found that the biggest problem I have had with VDO gauges are the wiring and connectors. Not always the best quality and should be checked out often.
ThePaintedMan |
Jun 17 2012, 07:43 AM
Is your thermostat hooked up? Mine isnt and it takes me sometimes 30 minutes or more to see normal oil temps.
Lo-Fi Version | Time is now: 2nd January 2025 - 01:23 PM |
